i3 coding - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 07-17-2016, 01:59 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by Brice_i3 View Post
WoW that's a quick answer ! Thank you for that.
I'm just a little bit confused. What is the way to read the ECU's so this file is generated then ? I'n don't fully understand the concept (I did read the help file on the software, but still ...) If you can en-light me, that would be much appreciated
Right-click on any ECU with a CAFD, and select Read Coding Data.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 07-17-2016, 02:27 PM
Brice_i3 Brice_i3 is offline
Mein Auto: BMW i3 REx
I'm in my car, laptop on my knees, typing on my smartphone, and I would like to say thank you again.
I realized that I missed THE documentation file to actually read the ECU. Now it makes more sens and I generated all the files.
Thank you again !
Old 07-17-2016, 02:28 PM
Thank you again !
Old 07-18-2016, 01:44 AM
Alright, I'm going to give a little feedback here.
First some context: I purchased a brand new i3 from 2016, produced in April 2016. It has the last version of the firmware (I think). I got the car from my dealer on June 15th.
So yesterday, like you noticed, I was trying to modify some values in the code of the car. With the help of shawnsheridan (thanks again), I managed to connect, read the code etc...
So now was the fun (that was I thought). I tried to make a first test:
TEST NUMBER 1
- Remove the seatbelt reminders for passengers AND driver's side.
Here is what I modified:
3001***61664;SBR-PreWarning_Fahrer (Driver) Set to: nicht_aktiv
3001***61664;SBR-PreWarning_Beifahrer (Passenger) Set to: nicht_aktiv
I applied the modifications, no error messages on the software BUT weirdly, I received a message on the dashboard nav screen: " error on traction control (ESP), drive slow and check with your dealer later. "
I thought " ok, that's weird". I disconnected the software properly, turned off the car, turned it on again, the message was not here anymore, no problem to start the car.
Test drive time : the seatbelt warning still appeared after approx 30 secondes of driving (or when, I supposed, I reached the speed threshold of 30 km/h).
So... that's a failure. I left it like this, and checked this morning after the car had a long rest over the night : same thing. The seatbelt gong is still present.
TEST NUMBER 2
I saw something fun to try yesterday evening : No need to hold the break pedal to start
Modified this:
Start Car by pushing button (hold brake not needed)
3000***61664;TC_STARTLOCK_BRAKE set to: nicht_aktiv
3000***61664;TC_STARTLOCK_DRIVINGREADINESS set to: nicht_aktiv
-> Little scary: I could not start the car AT ALL
Basically, after pressing the Start/Stop button, the car turns on, but impossible to get directly to the " GO " position. I'm not sure if anybody tried it with an i3, and if that's really possible to apply, but I had no success.
Hopefully, reverting the code made the car OK again, no problem anymore. And FYI I also tried to modify the STARTLOCK BRAKE value only, but same result.
I will try again more features today and during the week and see if I managed to apply any of the modification I had on a doc file, and let you know if I had any success. ( I especially want to try the read video while driving, and the Change Mirror Un-Fold Automatically at XX Speed ... We'll see).
Old 07-20-2016, 07:28 AM
Alright !
Little update, it's all good now.
I modified the codes I wanted:
- Seatbelt reminders - Off
- Lights on doors while backing up - Active
- Being able to read Xvid files (and VCD etc..) - Active
- Video player while driving (not for me as a driver, obviously) - Active
- Being able to save video file on internal HD - Active
- Change the I logo with the M logo just for fun but I'll change it back.
Now I can start digging a bit more.
As it was said everywhere, changing parameters for the NAV system, reset all your settings (8 shortcuts).
Thank you again for your help on this I'll report my experience and discoveries (in french) on my blog
Old 08-02-2016, 09:10 AM
toni8284 toni8284 is offline
Mein Auto: F80 M3
what is the coding parameter for this?
Old 08-02-2016, 09:13 AM
God-Follower God-Follower is offline
Moderator
Mein Auto: 2015\2016 i3s, F10 535d
Should be:
3000 > ENT_MC_VIDEO_SUPPORT > set to: aktiv
However I have not had much luck getting it to do it. I also run mixed content on my flash drive, both music and video. Maybe it works with just video on the flash drive?
Old 08-02-2016, 09:17 AM
Mein Auto: F80 M3
Originally Posted by God-Follower View Post
Should be:
I set to aktiv already. but still cant save video for my mp4.
Old 08-02-2016, 09:37 AM
You can only play Video back from USB and not internal Hard Drive.
Old 08-02-2016, 09:53 AM
So it was a myth then. Thank you Shawn for clearing that up
I think I have tried any kind of combinaison to get a special menu to be able to save a video (also tried just having videos on the USB /external HD) but nothing worked so I abandoned the idea.
Brice
Follow my connected adventure on BMW i3: My blog - mabmwi3.com ! (french)
Old 08-15-2016, 09:23 AM
jayshon carter jayshon carter is offline
Mein Auto: i3
I should be receiving mine soon and Im excited its my first BMW. God-Follower do you think you can code mine if you have time? Im not good with computers lol.
Old 08-15-2016, 09:33 AM
Moderator
PM'd
Old 08-16-2016, 09:19 AM
glenmbaker glenmbaker is offline
Mein Auto: All sorts of cars
Actually, the best source of information for i3 coding parameters is the Facebook group titled BMW i3. We have a full list of the currently known coding changes there, along with a detailed beginners guide on how to set up E-Sys and connect to the vehicle
If you have more questions, feel free to ask! I have coded a good number of i3s now, and am looking for new features/tweaks when I get spare time.
I've looked through the FB group and for the life of me I can't find the beginner's guide (did find files that had the coding parameters through). I'm about to try to drive from Portland to Seattle and I'm thinking that an extra bit of gas for the REX might be handy...any chance somebody could help me out with a PM for how to code this thing?
Old 08-16-2016, 10:06 AM
Rob@BA's Avatar
Rob@BA Rob@BA is offline
Mein Auto: F32 435i
If you need help coding we can assist. Check sig for details
Coding Specialist at Bimmer America LLC. E-Series and F-Series Remote Coding + NAV Updates. 10% off with promo code: "Rob"
Visit us at www.BimmerAmerica.com for the Complete BMW Enthusiast Source: News, Coding, Navigation Map Updates, Parts, Accessories, and Buying Guides.
Old 08-18-2016, 01:16 PM
rajusmc rajusmc is offline
Mein Auto: I3
I3 Coding Files
Hi All ,
I was wondering if someone could send me the files. I have the tutorial on how to code my I3 but do not have the files needed.
Raj
Old 08-18-2016, 01:21 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Originally Posted by rajusmc View Post
Hi All ,
Raj
Jump over to our BMW Coding forum for help getting setup to code your BMW.
Tim
Old 08-18-2016, 01:22 PM
Hi All ,
Raj
PM sent.
Old 08-18-2016, 07:04 PM
BMW_AUS BMW_AUS is offline
Mein Auto: 2016 i3 REx Tera
PM sent.
Hi shawnsheridan,
can you PM me too? About to pick up my first i3 next weekend. Would like to have some coding done... Thank you.
Old 08-18-2016, 11:18 PM
Originally Posted by BMW_AUS View Post
Hi shawnsheridan,
PM sent.
Old 08-19-2016, 08:37 AM
cordoor's Avatar
cordoor cordoor is offline
cor door sedan
Mein Auto: 2013 550i xDrive
Hey Shawn, me too? Thanks!
Current: 2015 i3 REx | Giga | Ionic Silver Metallic
2013 550i xDrive M Sport DHP | Jet Black | Venetian Beige | Dark Red Sycamore
2008 535xi Sport | Jet Black | Cream Beige | Burl Wood
Old 08-19-2016, 08:58 AM
PM sent.
Old 08-21-2016, 01:47 PM
stormace stormace is offline
Mein Auto: f01, fx35, f10
Hi Shawn please send to me as well! Thank you so much!
ED on 3.30.07 |'07 335i coupe|BlackSapphire|CoralRed|Nav|Comfort|Sports|Pr emium
Redelivered, Reunited! 5.24.07
2013 F10 535i|TiAg|BlackDakota||Tech|MSport|Premium|Multi Contour|Hifi|Rearview Camera|PDC
Old 08-21-2016, 02:12 PM
PM sent.
Old 08-25-2016, 04:39 PM
bradrachel bradrachel is offline
Mein Auto: 2014 i3 Rex
PM sent.
Hate to be that guy, but me too please? Thanks!
Old 08-25-2016, 05:43 PM
PM sent.
