Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 08-31-2016, 10:08 PM
jefflieb's Avatar
jefflieb jefflieb is offline
Self taught
Mein Auto: 335d, 535is
One more time ?
2017 i3 Tera
2013 Tesla Model S
2013 X3 3.5i sport sky blue/chestnut loaded
2012 535i M-Sport carbon black ED 11/19/11
2010 335d Saph blk/saddle sport (retired)
2008 X5 4.8 Sport (retired) 2005 545i SMG (retired)2004 X5 4.4 (retired) 2001 530i stick (retired) 2001 X5 3.0 5-speed (retired)1997 540i 6-speed (retired)1994 530ia 1990 525i 1985 535i
Old 08-31-2016, 10:42 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by jefflieb View Post
One more time ?
PM sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 09-08-2016, 06:31 AM
jjj240 jjj240 is offline
Mein Auto: i3
is there coding option to change strength of regen braking? my i3 seems much LESS aggressive compare to my brother's i3, i.e. virtually impossible to exercise one foot pedaling.
Old 09-08-2016, 06:43 AM
God-Follower God-Follower is offline
Moderator
Mein Auto: 2015\2016 i3s, F10 535d
Unfortunately not, at least not that we have discovered yet.
Old 09-08-2016, 10:00 AM
Mein Auto: i3
after reading the coding guide, it appears that "Change FA (VO) to Remove 6NH from VO & Add 6NS to VO" shall be done before any coding for i3. is it correct understanding?
what does FA stand for? VO?
also do i need to create new FA before any coding?
sorry about the novice questions... the guide seems detailed, but lacks cookbook type guide for first timer...
Old 09-08-2016, 10:11 AM
VO Coding should always precede FDL Coding, as it will override all previous coding.
FA is German for Fahrzeugauftrag, which is Vehicle Order or just VO.
Old 09-08-2016, 10:40 AM
Mein Auto: i3
1) my i3 do not have 6NH. What should i do?
still add 6NS?
2) Without add anying in FA, I proceeded with the guide, and it failed when reading SVT.
Click on "Coding" button.
Read FA (VO).
Activate FA (VO).
Read SVT <--- failed
if i try to read ECU, it read.
3) Another question is my vehicle i-step is I001_16_03_505.
database is I001_15_03_502
why don't i get any errors like not found or whatever?
4) I just downloaded PSdzData.Lite.v3.59.3.002 which contains I001_16_07_503
may i just delete "I001_15_03_502" folder and copy "I001_16_07_503" in to "C:\Data\psdzdata\mainseries\I001" and be fine with that? or should i replace entire psdzdata folder? E-Sys is 3.25.3
Old 09-08-2016, 10:59 AM
still add 6NS?
Read FA (VO).
Activate FA (VO).
1. Yes, just Add 6NS.
2. Yes, just use Read ECU. This is how i3 is.
3. That is question for BMW AG as if this is the case, they simply have not updated any of your ECU's firmware between 15_03_502 and 16_07_503.
4. No. Delete entire PSdZData Folder and replace with new one. And for 59.x PSdZData, make sure ytou are running E-Sys 3.27.1.
Old 09-09-2016, 06:57 AM
Mein Auto: i3
Just out of curiosity...
If E-Sys 3.25.3 is used with PSdzData.Lite.v3.59.3, what'd be the ill effect?
Simply would not work? or would it brick the car?
Old 09-09-2016, 07:32 AM
Not possible. It won't work. 59.x requires E-Sys 3.27.1 or higher to even work.
Old 09-11-2016, 06:46 PM
jhawk19 jhawk19 is offline
Mein Auto: 2009 535i
I just bought an i3, Thursday. Having it coded next week to enable the 2.4 gallon tank (among other things). Can anyone tell me what kind of range I can expect with code change?
Also having the following coding done:
Auto unlock doors when engine is stopped
Enable PSI and temperature in TPMS
Enable GTS style blinking brake force lights
Enable i3 REx 2.4 gallon tank
Enable i3 REx "Hold" mode
2014 i3 REx - Laurel - Giga Classic Natural Leather and Carum Spice Grey Wool Cloth - 20" Wheels - Clear Bra
Coding:
Fold/Unfold Mirrors with Key Fob
Enable Door Handle LEDs when Reversing
http://i.imgur.com/jOifZ8tm.jpg
Old 09-11-2016, 09:23 PM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT; i3 BEV
You should get about 25% more REx range than the EPA Monroney sticker that came on the car says.
Jim DeBruycker
Old 09-16-2016, 08:31 AM
Mein Auto: i3
SOC display gone?
after enabling "Enable Hold-Mode for Range Extender", SOC display in dash board scr (behind the wheel) is gone. I can only see SOC from REX menu in center screen. is it expected behavior?
Few more coding questions:
1) with E-sys 3.27.1 & PSdzData.Lite.v3.59.3, "Enable Hold-Mode for Range Extender" shall be set to 02 (REX), not 01 (PZEV) as appeared in tutorial. anyone else to confirm?
2) what is "enable developer option"?
3) what is "navi trip-import"?
4) what is "video in motion"?
Old 10-05-2016, 03:24 PM
tommyj496 tommyj496 is offline
Mein Auto: Charlotte
Hi Folks!
I've got an interesting question for all you coders out there. So I coded by car earlier this year to my hearts delight. All the fun bells-n-whistles, but most importantly the fuel tank to 2.5g and the Hold SOC. So yesterday I brought my car up to take care of a service notification (2-yr brake fluid flush). While up there, the guys decided to reprogram my car due to a technical service bulletin, SIB612116. I was a little annoyed because it would wipe my settings, but I didn't fret since coding was easy. That night I hooked up the ole' laptop and downloaded the latest psdzdata lite (59.4.004) from my fav link (I already have the latest E-sys). I then connected to my car and went to work. And this is the odd part...when i connected and read the ECU, I only had 2 modules. Simply BDC_Body and BDC_GW. And BDC_Body had the only CAFD to read and edit. No HU or KOMBI or any of the other modules that you'd look at to code.
Any ideas why this is? Could this simply be a case that I have newer software than the psdzdata? I will say that I could not find any information on the service bulletin when I googled it. I was about ready to take a trip on Friday and I really wanted to have...at a minimum...the Hold SOC since I'm heading to the Mountains and I want to make sure my car isn't putzing up the mountain because I can't insure I have enough charge beforehand.
Old 10-05-2016, 03:40 PM
Originally Posted by tommyj496 View Post
....Any ideas why this is? ...
You need to connect via VIN and not Gateway URL and using the correct connection target.
If car was reprogrammed though, after you connect in order to read and code all modules, you will need latest PSdZData, and if you do not have E-Sys 3.27.1, it will necessitate you udpate to it as well. PM sent.
Old 10-05-2016, 03:51 PM
Thanks Shawn. I am connecting via the VIN. And I should have the latest psdzdata (59.4.004) and e-sys (3.27.1). Maybe I'll try reinstalling with the PM stuff you sent later tonight. I appreciate it!
Old 10-05-2016, 03:56 PM
When you only Gateway Module (BDC) showing in SVT, normally it is an issue with your connection parameters, not your software. But as I said, you need to update anyway if you recently were programmed.
Old 10-05-2016, 06:58 PM
Well...I am a dumba$$. I didn't have the car fully turned on!
Everything is all coded up!
Thanks again!!!!
Old 10-07-2016, 08:11 PM
Inspectorgad Inspectorgad is offline
Mein Auto: BMW i3
i3 Coding
Shawn can you please PM me with the links to the latest psdzdata & esys.
Old 10-07-2016, 08:13 PM
PM sent.
Old 10-07-2016, 08:50 PM
Mein Auto: BMW i3
PM sent.
Thanks Shawn!
Old 10-19-2016, 08:39 AM
zegler zegler is offline
Mein Auto: e21, i3
hello i did ask that in another thread, so here i think is the right place for that question
Did someone code driving assistant plus (self steering). So that it could be used on all roads, not only autobahns (freeways). And maybe removed the top speed of 60km/h (40mph) ?
tnx
Old 10-19-2016, 09:17 AM
fridgeS3 fridgeS3 is offline
Mein Auto: i3
tnx
changing the topspeed to 60km/h was did with the last BMW software update to I001-16-07-506
Old 10-19-2016, 09:22 AM
Mein Auto: e21, i3
what was before that? i think it would be perfect with about 110 km/h so we could track slow trafic with self steering. Can it be coded?
Old 10-19-2016, 09:26 AM
Mein Auto: i3
older i3, like my 2013th, could use selfsteering up to 40 km/h
