i3 coding - Page 5 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 11-26-2016, 06:14 PM
jjj240 jjj240 is offline
Mein Auto: i3
Originally Posted by seasnoboarder View Post
Turn signal blink setting no longer working
I just received my i3 back from service on 11/10/16. They applied Programming B 61 21 16 for recall SIB612116.
I have been able to code back all my usual favorites like disabling the disclaimers and gongs, enabled the Range Extender Menu, and increasing the fuel tank usable size.
One of my favorite settings however no longer seems to work. I previously had been able to set the number of blinks of the turn signal by setting 3068 -> BLINKZYKLEN_ANZAHL_TIPP in the BDC Body Module equal to the zero based count of the blinks I want (04 for 5 blinks).
The initial value of this setting is now 00 (it used to be 02) and changing it does not seem to have any impact on the number of blinks (always 3 now).
Anyone else experience this issue? Is there any other setting that anyone is aware that can do this now?
blink does not work for me neither.
BTW, how do i confirm tank size got larger? the change seems minimal or negligible after changing from 7 to 8 ltr. also there is 8.5 ltr option in the latest sw. can it be set to 8.5?
Old 11-26-2016, 06:25 PM
doborder doborder is offline
Mein Auto: i3
Originally Posted by jjj240 View Post
after enabling "Enable Hold-Mode for Range Extender", SOC display in dash board scr (behind the wheel) is gone. I can only see SOC from REX menu in center screen. is it expected behavior?
Few more coding questions:
1) with E-sys 3.27.1 & PSdzData.Lite.v3.59.3, "Enable Hold-Mode for Range Extender" shall be set to 02 (REX), not 01 (PZEV) as appeared in tutorial. anyone else to confirm?
2) what is "enable developer option"?
3) what is "navi trip-import"?
4) what is "video in motion"?
Did anyone else figure this out about the battery meter (SOC) disappearing from the main dish board screen. Apparently this happened me after a recent visit to the dealership for software update
Old 11-26-2016, 07:10 PM
Almaretto's Avatar
Almaretto Almaretto is online now
Moderator
Mein Auto: Coded 2016 F10/ F15 Sport
If you have BDC_Body with updated firmware with factory value now at 00 (rather than previous 02), then changing soft blink no longer works.
For tank size, you immediately see difference on cluster. You are limited by physical tank size.
Old 12-24-2016, 08:22 AM
Mik3pho Mik3pho is offline
Mein Auto: I3
Hi Shawn, I have an i3. Can you please send me the latest Esys and PSdZData download links? Also a cheatsheet with codes. Is there an updated coding step by step documentation I can download too? Any help would be greatly appreciated. Thank you.
Old 12-24-2016, 08:55 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
PM sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 12-24-2016, 09:02 PM
mashad11 mashad11 is offline
Mein Auto: i3
Download links
Can you please send/PM me the latest e-sys etc download links? Tx.
Old 12-24-2016, 09:51 PM
PM sent.
Old 12-28-2016, 08:44 PM
I3guy I3guy is offline
Mein Auto: I3
Can anybody send me the links to download the software either psDZData?
Old 12-28-2016, 08:46 PM
PM sent.
Old 12-29-2016, 11:21 AM
robmwi3 robmwi3 is offline
Mein Auto: i3
tnx
Old 12-29-2016, 11:34 AM
tnx
PM sent.
Old 12-29-2016, 11:35 AM
fridgeS3 fridgeS3 is offline
Mein Auto: i3
Come on guys, use the right words on Google and you will find what you need?
Old 12-29-2016, 11:38 AM
Mein Auto: i3
Just making sure I am getting the latest available, as not all links work once you find them
Old 12-29-2016, 11:41 AM
Mein Auto: i3
With the words "bmw i3 coding tutorial" the second one shows a tutorial where you can find the actual links
Old 12-29-2016, 11:48 AM
Almaretto's Avatar
Moderator
There are also multiple solutions and some untrusted sites. Nothing wrong with going through Bimmerfest to get latest software and guides.
Old 12-29-2016, 03:40 PM
Mein Auto: i3
exactly!!
Old 01-09-2017, 10:18 AM
Starmanager Starmanager is offline
Mein Auto: i3
Hi @ All i3 Fans,
I did programm some options on an old i3 with software stand 11 / 14. Now I must bring the car to the workshop for a update while the Navi reboots and does not accept windows phones without reeboots. Is it possible to overwrite the new files with the old parameter files from e-sys after the service is done? Ist there a Manual available? What ist now the latest Software Version for the i3? What e-sys Version do i need for this version? Thank you to all the Fans.
Starmanager
Old 01-09-2017, 10:23 AM
Almaretto's Avatar
Moderator
Originally Posted by Starmanager View Post
Hi @ All i3 Fans,
Starmanager
If vehicle is programmed, you do not want to load NCD's from earlier firmware.
Old 01-09-2017, 10:55 AM
Mein Auto: i3
Thank you. So is there may be a tool what can see both versions old and new and show the difference to me? Is it possible to change the options offline and play it later back in the vehicle?
Old 01-09-2017, 11:26 AM
Almaretto's Avatar
Moderator
PM me FA and SVT and I will send back potential software updates. There are no release notes for features, if that is for what you are looking.
Yes, you can code offline (ie make changes in FDL-editor) and then re-connect computer when ready to apply changes. No extra tools necessary.
Old 01-09-2017, 11:38 AM
Mein Auto: i3
Thank you Almaretto, I will wait now until the car is updated and send you the old and new files if I can read them out with my actual version.
Old 01-09-2017, 11:47 AM
Almaretto's Avatar
Moderator
Alright. Just FYI (from my "getting started" docs):
Per above instructions, make sure to move CAF files before "Reading Coding Data," both so you do not overwrite existing files as well as avoid confusion with new files.
Old 01-28-2017, 10:11 AM
i3driver i3driver is offline
Mein Auto: i3
i3 coded SOC_HOLD_POSITION to be > 6% but it doesn't work
I see posts from other folks that have modified the SOC_HOLD_POSITION value to change the automatic start point for the REX above 6% and have noticed that the hold point on the display (small diamond) moves, but the REX still starts at 6%.
Has anyone figured out if this really can be changed or if it is simply a display change? I already have the manual REX hold option but want the default to be higher than 6% for other drivers of the car.
Old 01-28-2017, 02:39 PM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT; i3 BEV
That can be done, as DVD IN MOtion will sell you a program that will do it...but, I can't help on what it actually changes to make it work. The i3 Programming forum on FB probably can if you want to join.
Jim DeBruycker
Old 01-28-2017, 05:39 PM
Almaretto's Avatar
Moderator
DVD in Motion solution is script activation that does not change FDL's; it is not needed for ID4. Coding at no charge can be done for the I001.
