Old 04-20-2017, 03:26 PM
Robert A Robert A is offline
Mein Auto: BMW 535d
BMW Mobility Kit - Cross-post
My F10 needs tires and I'm considering non-RFTs. I'm posting here because some of you have the Track Handling package and non-RFTs with your F3X's.
Can you share what you know about the BMW Mobility Kit vs. other kits, and how helpful these kits are in general? I only have a day or two to make a decision on tires, which is why the cross-post.
Thanks,
Robert
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 04-20-2017, 04:04 PM
viator092 viator092 is online now
Mein Auto: E92
This is cheaper and does same thing.
http://www.continental-tires.com/car...ntimobilitykit
Old 04-20-2017, 05:45 PM
jparnes1 jparnes1 is offline
Mein Auto: 2011 Z4 35i, 2006 525xi
^this plus I carry a plug kit and a BMW jack set which includes a jack, tire chock, breaker bar, torque wrench and other goodies https://www.bmwdiscountparts.com/oem...et-71102182448
Barring bad weather, I can get myself fixed up and back on the road.
2016 340i XDrive, Estoril Blue / Black, 6 MT, M Sport, Track, Lighting, Technology, Driver Assistance Plus, Cold Weather.
2012 Z4 35i, ED 2/24/12, Melbourne Red Metallic, Black leather, 6 MT, ///M Sport, Premium Package, Premium Sound Package, Cold Weather Package, Nav, Comfort Access, LED Angel Eyes, BMWPedals pedal covers, stubby antenna, Luxon strut bar, CF engine cover, LCI side marker, powder coated calipers, Extra Enjoyment Package
Old 04-21-2017, 05:31 AM
Our BMW Our BMW is offline
Mein Auto: 328xi GT
So for those who have used the Conti kit, does the TPS need to be replaced when you have the tire repaired or replaced?
Seeing as it's latex based maybe it can be cleaned up and reused?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
Old 04-21-2017, 07:18 AM
Arthurrs Arthurrs is offline
Mein Auto: 2014 328i xdrive
I would get to the shop ASAP, and get the damaged tire off the rim before the stuff hardens, otherwise it's impossible to get off.
Personally I would dismount the tire and use a plug kit to seal the puncture.
Old 04-22-2017, 12:34 PM
imtjm imtjm is offline
Mein Auto: 335d, 328ix, hard bargain
The TPMS should not need to be replaced, just cleaned off. The issue isn't with sealant encrusting the TPMS, but the sealant blocking the the pressure sensor port, since that would lead to inaccurate air pressure reading. However, since these solutions are not intended to be a permanent fix, it doesn't matter. The previous generations of aerosol sealants like older fix-a-flat had corrosive properties which could damage both sensor and rims; however, the latest generations of water based sealants (which fix-a-flat now is) are not corrosive. Since the sensors are radio frequency based, it really doesn't matter if a crust of latex covers the sensor. My goodness, how do people think the sensors work through thick tire rubber? The stuff is not impossible to get off. Since they are temporary, you will want to get the tire repaired or replaced anyway. If repaired, the tire should be removed anyway in order to do the patch w/plug repair from the inside of the tire, which is the recommended method over just the plug.
Just understand, though, that the sealants have a shelf life. Terra-S makes BMW mobility kit, Slime, and Fix-a-flat, and has a shelf life of 4 years (Terra-S also makes for VW, SEAT, Audi). ContiMobilityKit lists up to 5 years shelf life. You aren't guaranteed that the sealant canister or the pump+sealant canister is going to be new. When I wen to buy spare BMW sealant, the dealership had 2 year old stuff. I re-ordered and got new stock.
At the time, I bought BMW mobility kit because it was cheaper than the Continental one. Ford, Volvo, GM, etc use Continental sealant and mobility kit, and you can get for cheaper than the contimobilitykit. Then again, the Slime kit, which uses the same sealant as BMW kit, also is cheaper.
Old 04-24-2017, 08:14 PM
Bigtuna00 Bigtuna00 is offline
Mein Auto: 2013 JSW TDI
I think many shops will tell you not to use sealant as they hate dealing with it afterwards
I carry a patch kit, in addition to the mobility kit. Would rather patch a hole than fill the tire with slime, if I can.
Old 04-26-2017, 08:46 AM
Then they probably shouldn't be in the tire repair/replace business if they don't like doing it.
Sealant is no brainer: hook up and inflate. Plug you need to remove wheel, try to find hole(s), plug, replace wheel, inflate.
Old 04-26-2017, 11:10 PM
ifoney ifoney is offline
Mein Auto: 335i
I bought one when I switched to Pilot SS. Never needed to use it so far. Switching to non-runflats is great.
Old 04-27-2017, 03:18 AM
bmwexpat bmwexpat is offline
Mein Auto: 328I
Carry a $7.00 plug kit and bought a $25.00 battery powered air compressor at Lowes. Both fit it the small recess area under the trunk deck. No need for a jack as the plug kit will work with the tire on the car.
Using the plug kit is pretty much a permanent fix but even you want to replace the tire the plug kit will get you home where you can figure out what needs to be done if anything.
Old 04-27-2017, 10:59 AM
plug kit works when tire is on the car? You mean so long as you can roll the vehicle to the hole and you can access the hole.
plug kit is not the approved method and is not pretty much permanent. Patch and plug from inside is.
Old 04-27-2017, 11:17 AM
Thanks,
Robert
1. First and foremost, they are temporary solutions.
2. Simple and easy to use. connect to valve stem and push a button. Some versions require connecting hose from sealant bottle to valve and inflator to sealant bottle, but it is pretty much one connection.
3. After a double flat, I carry a mobility kit with two bottles of sealant in each of my cars. I have the BMW mobility kit with the self contained sealant and a spare bottle sealant.
4. Understand BMW sealant has a 4 year shelf life, Conti has 5 year, Slime has 4 year, fix-a-flat 5 years. If you are getting fix-a-flat, ensure you are getting latest versions rather than the corrosive older versions.
5. I don't see any difference between BMW, Conti, Slime, since they all use the same set up and water based latex sealant. Slime, Fix-a-flat and BMW are all made by Terra-S, which is part of ITW Group, which makes also for: Volkswagen, Audi, Porsche, Mercedes, BMW M, BMW AG, BMW Mini Oxford, Skoda, Seat, Peugeot, Citroen, Honda Japan, Honda USA, Honda UK, GM and Suzuki Japan. Ford uses Conti.
6. air compressor can be used with or without the sealant bottle.
I know folks like plug kits, but it involves more work than the one hook up and button push of the mobility kits. Plus, with the mobility kit, you aren't having to search out the hole.
