Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Old 05-21-2012, 12:49 PM
NotNormal NotNormal is offline
Mein Auto: BMW 335d E92 MSport
Here's a picture of my removed egr valve, this is aprox 100,000 miles old :
It's done 30,000 miles on what ever fuel, I don't know, and 70,000 miles on 98% v-wer diesel and 2% BP ultimate diesel
It's also been running my DTUK CRD-T tuning box at 340bhp and 510lbs ft.
Very mixed driving, town, distance, high speed, town speed.....and I've had zero issues.
Old 05-21-2012, 04:06 PM
cssnms cssnms is offline
Mein Auto: '11 335d
Tom - Your EGR valve does not look to bad all things considering.
Old 05-22-2012, 12:00 AM
Chris, I agree.....it's very minimal carbon build up
I'm mere than pleased eight he results of removing it though, my cars low down ight throttle is a lot stronger.
It's also nice or have the piece of mind that I'm not contributing to the build up of crap inside my engine, especially at nearly 100.000 miles.
Old 05-22-2012, 05:02 AM
3ismagic#'s Avatar
3ismagic# 3ismagic# is online now
HerrDoktorProfessor
Mein Auto: '11 335d
When ever I see the title of this thread my mind reads it as
Duck Turd vs JBD.
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video: https://vimeo.com/60051914
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 05-23-2012, 05:54 PM
EYE4SPEED's Avatar
EYE4SPEED EYE4SPEED is offline
Mein Auto: 335d M-Sport LCI
So can we use the EGR bypass on US spec?
Old 05-24-2012, 11:02 AM
Going on the information on the picture of the EPC posted above, the kit I have fitted isn't compatible as a straight plug and play kit
You need to have the car mapped to suit, removing the egr mapping within the ecu
Old 05-30-2012, 01:41 PM
m54b25 m54b25 is offline
Mein Auto: BMW RT 335i & AMG RT C63
If you remove the EGR, it will increase the exhaust gas temp & possible DPF removal needed...if you remove DPF, then you will also need to remove Bluetec injection. It will require a car tested remap on North America Canada & US Spec cars.
Old 11-28-2012, 10:28 PM
Bimmerx53 Bimmerx53 is offline
Mein Auto: BMW X5 35d
Hi, I just had two questions regarding these mods, Does chip tuning with these modules affect the reliability of the engine? and if your car is still under warranty, can you just remove the chip and plug in the original to keep the warranty in tact for service?
"Time flies like an arrow. Fruit flies like a banana."
Old 12-08-2012, 02:21 PM
Yes, with the tuning boxes you can simply unplug them before your visit to the dealer and they're non the wiser
Thus, shouldn't effect your warranty
Old 01-18-2013, 12:48 AM
Mob17 Mob17 is offline
Mein Auto: E92 335D SE (coming soon)
I have used a CRD-T on my E90 320D for about a year with no obvious issues. I will be getting a 335D tomorrow (UK spec) and i only need to purchase the wiring loom, software is free!
Just wondering about warranty, shouldn't we make sure we read and delete any error codes as well as removing the box?
Old 01-18-2013, 04:34 AM
Axel61's Avatar
Axel61 Axel61 is offline
Mein Auto: 335d
Lenny have you been able to get someone to go and have it done @ RENNtech? BTW I will be in Orlando Monday picking up the WAGNER IC
Old 04-13-2013, 04:07 PM
taibanl taibanl is offline
Mein Auto: 335d (e90)
Update:
1) pbmw60 give you GBP 60 off of a crd-t
2) new review in current performance bmw mag
Old 03-19-2014, 06:42 PM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Interesting thread over at E90post comparing JBD and DTUK http://www.e90post.com/forums/showthread.php?t=959866
Old 03-20-2014, 11:31 AM
Not meaning to change topics, but real quick question while you guys are talking about EGR Valves, my e70 has 40k miles on it and when I took it in for service they said it sprung a leak. From what I can see, the EGR unit wasn't replaced, only a little sliver pipe running from it. Would you guys say I should simply overlook this or is it worth it to get that extended warranty?
Much appreciated.
Old 03-20-2014, 11:38 AM
finnbmw's Avatar
Sounds like cracked EGR cooler, fairly common issue. Did you smell diesel fumes or was there soot around the silver pipe? The dealer probably replaced the bracket for the cooler as there is a recall, but you might want to double check.
I'm at 54k on my 2010 and I did not purchase extended warranty as the truck has been relatively trouble free.
Old 03-21-2014, 12:32 PM
Yes, it was the one with the heat-sink around it so I guess it was the cooler.
And I did smell that, I thought it was the urea from the exhaust so I didn't think anything of it.
Huh okay I'm going to see this thing acts up again on its way to 50k but so far I'm going to go for no extended warranty if this isn't a big deal.
Thanks!
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
