Old 10-08-2013, 12:06 AM
deb10042 deb10042 is offline
Mein Auto: F20
F20
Settings tested in my F20 (120d)
- here, only the lower cluster of the instrument display changes its color from orange to white
- normal analog displays (e.g. speedometer) remain in orange color
- lower cluster changed to white color doesn't look too ggod at night with orange rest of the displays
- lower cluster in white color is too bright at night and might dazzle you while driving
--> I reverted it back to the original settings
Old 04-09-2014, 03:43 PM
leezer leezer is offline
Mein Auto: 550 xDrive 2011
I am having good luck coding (so far!) Now have TPMS temp and pressure, no disclaimers, fogs with high beam, etc. Now for the problem I had hoped to solve...cluster lights. I have read this forum and tried changing a couple of settings (daytime always and orange/grau)...but no good. With switch in auto my daytime dash is all dark...no detectable light at all.....if it comes on (by switch or night) it is orange. It seems this changed after dealer did software update. Any suggestions?
2011 550i X-drive built 9/15/2010
Old 04-10-2014, 12:05 PM
Oh! Looks like I don't have the 6wa just standard. Bummer! That explains all but my poor memory!
Old 12-18-2014, 07:51 PM
KARR KARR is offline
Mein Auto: 550i
There is no way to have the white color backlight on the F30 as the F30 does not have the full black panel 6WA like the one F10 and F01 do. Only this cluster has white backlight for the numbers, but for the F30 the numbers are already printed. So its a hardware difference, no amount of coding can help.
Old 07-15-2015, 03:02 AM
giarC71 giarC71 is offline
Mein Auto: 2012 528xi
I have a 2012 528xi F10. I just had my car coded but couldn't get the
Daytime white on my cluster display. I don't have the extended display.
Is there Any work around for my display?
Old 08-26-2015, 07:56 AM
420iF36 420iF36 is offline
Mein Auto: 420i Xdrive F36 M Sport
BMW 420i Xdrive M Sport (F36) born Sept. 2014.
I have successfully coded many enhancements (thanks to Shawn for Esys/pzdata) but have hit the brick wall on attempting to set day time lights permanent – in addition to knowing how to get Amber/White dials permanent instead of the occasional appearance.
I believe I have the enhanced cluster - Day time giving me the red/white text (occasionally White\Orange dials) then all Amber at night. I’ve switched off analogue dials on iDrive to get rid of the Efficient Dynamics stuff….
Changes made for permanent Day Time cluster lights(without any joy) –
KOMBI 3007 DIM_NACHT_EIN werte = FF
KOMBI 3000 HINTERGRUND_FARBE_TAG (does not exist)
KOMBI 3000 CC_TEXT_FARBE weiss_orange
I also have HU-NBT 3000 M_VEHICLE aktiv - Gauges in Sports Display from BMW Amber to Red & Silver
The last change I made was to set DIM_NACHT_AUS to nicht_aktiv in case it was competing with DIM_NACHT_EIN….
Any advise/comments welcome.
Old 09-02-2015, 08:40 PM
ken05 ken05 is offline
kjt
Mein Auto: X3 F25 LCI
it set this to Grau KOMBI-->3000 Anzeige_Konfiguration-->HINTERGRUND_FARBE_TAG
and had this KOMBI->3007 KI_Dimmung, 24->DIM_NACHT_EIN->werte=FF
and i also tried but I am still getting orange at night with my light switch set to auto.
any ideas why it does not work
thanks in adavance
Old 10-15-2015, 07:24 PM
Skyline1337 Skyline1337 is offline
Mein Auto: 335i e93
Hey guys.
Any updates on this?
I've recently tried the following on a F11 535 built 09\10\2015 but it doesn't seem to work:
and tested additonally:
Old 10-18-2015, 07:25 PM
ac_schnitzer ac_schnitzer is offline
BMW user
Mein Auto: "12 F10 520dMtech/G400CDI
All F01 accept this function , for F10 you need 6WA cluster with big display like in F01 , for F30 you need have 6WA in your FA ( i dont test it ) , do any have news about 6WB full digital tacho - in my car i try almost every CAFD combinations to make it work but no sucess .
BMW 520d 11/11 M tech. 8TF , 704 , 6FL , 615 , 616 , 5DF , 522 , 508 , 502 , 494 , 316 , 2TB , 609 , 4U2 , 4AT , 1CC /// retrofits : 6WA , 6WB , 3AG , TOP HIFI 677 , ASD , NBT EVO ID6 w car play , LCI M6 performance steering wheel , Twin Scrool TURBO with PPK software DDE 250 hp , 550d performance exaust , LCI Headlights AHL/Taillights/mirrors , KAFAS2 with HBA , LDW , SLI , HBA , FCW , glarefree , HUD LCI full color ..waiting for more ..
Old 10-18-2015, 07:55 PM
ruben_17non ruben_17non is offline
Mein Auto: Bmw E92 LCi / Bmw X4
if not possible by coding. why not physical mod? i asume kombi have photo resistance for change color. depend of exterior luminosity, maybe is possible remplace photocell by resistance, of low ohm. it can checked with tester.
this is possible way?
I never want orange color. i not have problem with disable this.
Old 10-18-2015, 08:59 PM
Ruben do you have and F10? Extended display?
Old 10-19-2015, 02:13 AM
F25, With 6WA retrofit
Old 10-19-2015, 03:40 AM
Sii770i7 Sii770i7 is offline
Mein Auto: BMW F30 320i
My F30 do have option 6WA but during daytime my cluster is not lighted up with white light. So as to say there is missing hardware and impossible to code? I did coded it some time back but with no luck. Anyone able to advise?
Sent from my iPhone using Tapatalk
Old 10-20-2015, 01:46 PM
I check today LDR sensor:
Just With normal Light conditions Like day.
High OHM in Night
With full light, low value of OHM
If i remplace LDR by fixed standard resistance of low value 0.15ohm
Will work? Any idea?
Old 10-20-2015, 02:37 PM
I mean in resistence of 15k-20kohm
Old 10-23-2015, 11:37 AM
BMW user
I think switching from day to night mode is not only tacho sensor related
Old 10-23-2015, 12:14 PM
Daytime Instrument Cluster at Night
you can code RLS by sensor for day/night mode. But originally only use tacho sensor for kombi and NAV.
I try only remplace photosensor by fixed resistance and work now. Allways white
The unique problem is, dim function not work.
I check if this is possible fix by code.
Old 11-06-2015, 07:56 AM
beamx6 beamx6 is offline
Mein Auto: Bmw X6
anybody got this to work on 6WB
Old 11-06-2015, 01:09 PM
wtgt205 wtgt205 is offline
Mein Auto: BMW 750 Ld X-Drive
Hello.
I BMW 750 Ld F02 Year 2014. Can anyone give coding values ***8203;***8203;so speedometer is illuminated in night mode in white ? All coding values ***8203;***8203;that I have found here in the forum , unfortunately, do not work with me .
Howdy from Switzerland .
Old 11-06-2015, 01:10 PM
Hello.
Old 11-06-2015, 01:41 PM
Originally Posted by wtgt205 View Post
Hello.
No possible
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
