I made these 2 videos for those of you who have a FaceLift Ask Unit & FaceLift MMI
that would like to do the Auxiliary plug Mod in your car . I also made them cause
some 1 accused me of taking credit for there work . There are 2 members on here
that can confirm I have had the Auxiliary feature in my 2002 745LI for just under
4 MONTHS . They have Both been in my car on several different occasions & have
seen it with there own eye's a few month's back .
Those 2 members are =
Rookie2008 ( real name is MARK )
http://www.bimmerfest.com/forums/member.php?u=225734
B7M4W5 (real name is CARLOS )
http://www.bimmerfest.com/forums/member.php?u=260565
DO AT YOUR OWN RISK
I AM NOT RESPONSIBLE FOR ANY DAMAGE YOU CAUSE TO YOUR CARS .
Published on Jul 28, 2012
FOR ALL OF YOU PRIVATE MESSAGING ME , IT IS EASIER IF YOU JUST LEAVE
ME A # I CAN CALL YOU AT INSTEAD OF AN EMAIL ADDRESS .
THE PRICE ON THIS MOD DEPENDS ON WHAT YOU PAY FOR THE PARTS NEEDED .
THESE PARTS ARE NEEDED FOR THESE YEARS OF YOUR E65 E66 =
1 = ASK UNIT IS NEEDED FROM = ( 02 TO EARLY 06 )
2 = MMI SCREEN IS NEEDED FROM = ( 02 TO 05 )
3 = AUX CABLE NEEDED ALL YEARS NOT EQUIPPED WITH IT
4 = AT TUNER NEEDED = ( WHEN APPLICABLE 02 TO EARLY 06 )
& YES YOU STILL HAVE TO HAVE THE AUX FEATURE CODED
SO IT SHOWS UP ON YOUR SCREEN . THE DEALER WILL NOT
CODE THE AUX FEATURE ON YOUR CAR . YOU WILL NEED TO
FIND SOMEONE TO CODE IT FOR YOU , OR YOU CAN LEARN TO
CODE IT YOURSELF ...
=== READ CAREFULLY ===
BE SURE TO CHECK THE BUILD DATE ON PARTS &
MAKE SURE THEY ARE FROM A CAR BUILT IN LATE 06
, 07 , 08
IF YOU HAVE AN 02 TO 05 YOU WOULD NEED
1 = MMI SCREEN ( BUILD DATE FROM 06 UP T0 08 )
2 = ASK UNIT / CD PLAYER ( BUILD DATE 07 UP 08 )
3 = AT/TUNER ( BUILD DATE 06 UP 08 )
FOR THOSE OF YOU WITH AN EARLY BUILD DATE 06 .
YOU WOULD NEED
1 = ASK UNIT/CD PLAYER ( BUILD DATE 07 TO 08 )
2 = AT TUNER ( WHEN APPLICABLE BUILD DATE LATE 06 TO 08 )
THIS WILL WORK ON ANY 745 OR 750 FROM 2002 TO 2008 AS LONG AS YOU HAVE THE CORRECT PARTS NEEDED ...
YOU WILL STILL NEED TO HAVE THE AUXILIARY FEATURE
CODED ONTO YOUR MMI SCREEN BY SOMEONE WHO CAN DO IT .
PREFERABLY AN EXPERIENCED CODER .
THE DEALER WILL NOT ADD THE AUX FEATURE TO YOUR CAR !!!
PIN POSITIONS =
2 = RIGHT = RED/WHITE
7 = LEFT = BLUE/WHITE
8 = GROUND = BLACK OR WHITE & BROWN
DO AT YOUR OWN RISK
I AM NOT RESPONSIBLE FOR WHAT YOU DO
TO YOUR CAR !!!
PLEASE WATCH BOTH VIDEOS .
http://www.youtube.com/watch?v=s4imynuJ2Oc&feature=channel&list=UL
http://www.youtube.com/watch?v=u9lkxUDMrDk&feature=channel&list=UL
IF YOU CLICK THE SHOW MORE UNDER THE VIDEO , YOU WILL SEE
THE PART # & A LINK TO PURCHASE THE PART ON AMAZON .
LEFT SIDE OF THE PICTURE IS A NON FACELIFT
RIGHT SIDE OF THE PICTURE IS A FACELIFT
DO AT YOUR OWN RISK
, 07 , 08
YOU WOULD NEED
PIN POSITIONS =
DO AT YOUR OWN RISK
TO YOUR CAR !!!
