Old 07-10-2014, 04:16 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
Originally Posted by fmzip View Post
NAPA didn't list a rating on the connector, I looked for it. I was hoping to find a 20A rating. It can accept up to a 10GA wire. It seems pretty robust.
This one will handle the current the fan will draw.
Old 07-10-2014, 04:51 PM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
I wasn't worried but someone posted that I didn't flip it. What I noticed after I flipped the blade over as pictured and swapped polarity, the output was much, much higher. I used my wife's hair movement as my test subject (couldn't use my own as I am follicly challenged)
Simply reversing polarity does not provide the same air output, it's a combination of blade rotation, maybe it's different with these "s" type blades than straight blades but it certainly makes a huge difference in performance
Any suggestions on a better one, NAPA had nothing nor did Advanced Auto.I was hoping to use something like this and cut it in half but then again, no rating
http://www.amazon.com/Classy-Autos-W...ve+plug+2+wire
Now I just want to know if I flipped it in case someone asks. Can someone with this same fan chime in?
I checked my fan blade orientation and your reflipped blade is the same as mine. My fan assembly is opposite from yours (black is hot and blue is ground) but the fan orientation is (the same) correct. I guess your wife's hair is the ultimate test. lol.
Congrats of your fan runon after engine shut off setup. Love it. I might have to copy your setup in the future but not before I add Jim's 20% run all the time module to my wife Nancy's car.
I used a waterproof connector for the fan that I found at Summit Racing. It's rated at 20amps, is kind of expensive but is very cool IMHO. Here's the link:
http://www.summitracing.com/parts/aaf-all76266
Edit-BTW being a baker, I really like your cake pan fan mount. Very clean looking and is definitely better than my messy setup. But bottom line is that mine works and that's the way it is going to stay. Again congrats on coming up with that design.
Old 07-11-2014, 07:53 AM
fmzip fmzip is offline
Mein Auto: 330 cic
Thanks for checking that out and the compliments.
That connector is exactly what I was looking for at NAPA. In the link you provided, is that a male and female as it doesn't look like it.
I found this one on Amazon, does this look sufficient to hand the current, looks to be the same part?
http://www.amazon.com/Keep-It-Clean-...pr_product_top
Old 07-11-2014, 10:50 AM
johnstern's Avatar
The Summit part is male and female. Looks very similar to the Amazon connector, maybe the same although different brand name. Amazon does not list a capacity while Summit does but they are so similar that the Amazon connector must be able to carry 20 amps.
I can tell you that these connectors are very OE and went together easily. I soldered the pins onto the wires. Make sure you slide the little rubber seals onto the wires before sliding on the connectors and soldering but, of course, you know that.
Old 07-11-2014, 01:33 PM
Mein Auto: 330 cic
Thanks John.
yes, I agree these connectors are very OEM, it's exactly what I had in mind when I first went searching. I was very surprised not to find them at the auto parts store
Old 07-11-2014, 02:46 PM
johnstern's Avatar
Yeah! I looked in the autoparts stores too and was amazed that no one carried a weather proof connector. I think it's another bean counter problem-they are too expensive so customers mainly buy cheap spade connectors. Ridiculous!!!!
Old 07-13-2014, 06:46 PM
Mein Auto: 330 cic
I got the fan installed today, fits perfect.
Thought I'd first wire up the Derale according to the instructions first to set it properly. Still need to wire up the resistors and relays and button everything up.
Now for the pics :
Good for another 184,000!
Old 07-14-2014, 05:42 PM
Mein Auto: 330 cic
just ordered the weatherproof connectors
Old 07-14-2014, 05:47 PM
johnstern's Avatar
Congrats!! That looks great-neat and clean.
Old 07-14-2014, 08:28 PM
Mein Auto: 330 cic
Thanks John, couldn't have done it without everyone's help!
Old 07-15-2014, 11:31 AM
lordhifi lordhifi is offline
Fighting the good fight!
Mein Auto: 2003 530i sport package
Is there an updated parts list for the conversion from anyone or are we sticking with what Valex has done. I need to do this ASAP but I want to grab the latest fan and parts. Let me know.
Thx!
Old 07-15-2014, 12:05 PM
Mein Auto: 330 cic
Thx!
All parts are the same but I've created a fresh DIY here:
http://forums.bimmerforums.com/forum...ectric-Fan-DIY
Old 08-10-2014, 12:05 PM
Thanks for cross referencing to this thread, since it's now the canonical bimmerfest thread on the fan clutch delete:
EDIT:
For the record, another nice DIY with pictures was created today for the mechanical fan delete switch to electrical:
> E39 (1997 - 2003) > my fan clutch delete
See also:
- Mechanical fan delete DIY fan clutch to electrical fan (1) (2) (3) (4) (5) (6)
ID:	457689   Click image for larger version
ID:	457690   Click image for larger version
ID:	457691   Click image for larger version
ID:	457692   Click image for larger version
ID:	457694   Click image for larger version
ID:	457695   Click image for larger version
ID:	457696   Click image for larger version
ID:	457697   Click image for larger version
ID:	457699   Click image for larger version
ID:	457700   Click image for larger version
ID:	457701   Click image for larger version
ID:	457702   Click image for larger version
ID:	457704   Click image for larger version
ID:	457705   Click image for larger version
Please read the suggested threads, where the best always add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
Old 11-11-2014, 12:09 PM
See also this thread today:
> E39 (1997 - 2003) > Fan Conversion?
http://www.bimmerfest.com/forums/sho...61#post8700361
Originally Posted by alexbarbur View Post
Hey guys i've recently started learning more about engine cooling and what not and i was wondering if anyone has converted from the stock clutch fan to electric fan..is it possible? i mean the benefits would be through the roof..
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
