Old 06-19-2017, 02:34 PM
jammy78 jammy78 is offline
Mein Auto: F31 328i
Kombi update after NBT reftrofit?
Hi all,
I've retrofitted a NBT in my 1112 F31 and after coding everything works..... except the Kombi.
The mode button doesn't work / can't see the radio station or tel in the Kombi?
After I try coding the Kombi, I get this message BUT I get the same message when coding the Kombi when the original entry hu is installed?
So my questions:
1. Why am I getting this message (even when the car is stock)
2. does my Kombi really need updating to work with the NBT as I've not seen anyone else needing to do this.
3. If I do need to update the Kombi, will I need to update all the other ecu's?
Many thanks
Old 06-20-2017, 10:54 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Did you FDL Code HU_NBT => KOMBI_CIC to match your installed Kombi?
Old 06-20-2017, 11:22 AM
Mein Auto: F31 328i
I VO coded the NBT & Kombi & when I checked HU_NBT = KOMBI_CIC.
I have the basic Kombi
Old 06-20-2017, 11:24 AM
You must FDL Code it so that HU_NBT = KOMBI_CIC = kombi_low and HU_NBT => BASIS_KOMBI_MMI_LIST = aktiv.
Old 06-20-2017, 12:46 PM
Mein Auto: F31 328i
I feel a bit embarrassed..... I wasn't FDL coding after making the changes!
Many thanks.
Ps, I've been reading through the post re: 6WA retrofit.... will probably posting there, once I get the 270 programmer working!
Old 06-20-2017, 01:03 PM
Many thanks.
