New new version of the official E36 OT thread.
There isn't a gun big enough to get claustrophobic me up in that thing!Unfortunately I couldn't go up because the visitor center was closed but it was cool to see the archway close up anyways.
What were your readings before the shimming?Shim kit installed. Back on the allignorant rack it goes.
Hopefully it fixed my front camber issue. We shall see.
They're reusable, but the rubber seals which go around them should be replaced to prevent leaks. Also, when replacing the valve cover gasket, I highly recommend using a torque wrench. The nuts get tightened down to 89 INCH-pounds, and the studs are very easy to strip. Fortunately, if you do strip a stud, they are easily replaced (even without having to take off the valve cover).Hey guys are the E36 valve cover nuts TTY or reusable? I have a small oil leak on top of the VANOS cover.
