Old 11-19-2012, 10:25 PM
marshalpaul745 marshalpaul745 is offline
Mein Auto: 745Li
Emissions related fault Service engine soon!"
I found this on my 03 745 Li today, and i know there is some threads on this topic, I did not plug it up to check on any codes thats my next step, but I'm going change my oil for $99 tomorrow at NorthHouston Beemer that's an independent Mechanic shop, I wonder should i check my hoses before i go up their found a thread were someone said it was his middle air duct tube, I have that extended warranty thru a third party that i got from Advantage BMW in Houston, question will this warranty cover anything like could be causing this problem I have read it could be many things, thanks for reading and helping, also had a another msg stating the oil was low something said top off something like that car has about 85,000 car was kept up from my research.
I need Help yall to catch with the Pros, from Houston,Tx
<img src=http://s1.bimmerfest.com/forums/images/smilies/thumb.gif border=0 alt= title=Thumbs Up class=inlineimg /><img src=http://s1.bimmerfest.com/forums/images/smilies/thumb.gif border=0 alt= title=Thumbs Up class=inlineimg /><img src=http://s1.bimmerfest.com/forums/images/smilies/thumb.gif border=0 alt= title=Thumbs Up class=inlineimg /><img src=http://s1.bimmerfest.com/forums/images/smilies/thumb.gif border=0 alt= title=Thumbs Up class=inlineimg /><img src=http://s1.bimmerfest.com/forums/images/smilies/thumb.gif border=0 alt= title=Thumbs Up class=inlineimg />[SIGPIC]
Ads by Google
Old 11-19-2012, 11:39 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Does it smoke after sitting at idle for a while? The valve stem seals are known to be in issue on these cars, as is coking of the secondary air passages in the heads which cause the secondary air codes to come up (P0491, etc..) luckily the emissions issue can be resolved with software, but the valve stem seals are a grand or two if you don't do the work yourself.. more depending on who you go to..
Old 11-20-2012, 08:25 AM
bmwla bmwla is offline
Mein Auto: 2005 BMW 745i
Service engine soon yellow light came on also on mine ....emissions related fault ..... i read the thread. Could be loose gas cap or loose hoses on intake manifold, stuck thermostat, oxygen sensor.
PAPER - do you have time to read the actual fault code? I'm good anytime this week! Thanks!
Old 11-21-2012, 11:14 PM
Mein Auto: 745Li
Update on Emissions related fault
So i was telling you guys about my lil problem, I brought it to North Houston Beemer here in Houston,TX these guys are good and up front and show and explain the problem, but here's the problem after they ran it thru a series of test, some white smoke comes out the back when u get on it and after it idles a little, they talking about some value heads getting carbon inside and they show me where its located stating they have to be taken out, thanks fellas oh and the warranty covers it good news, he said he BMW was gonna do it they would charge about 10,000 to do, he said he would have to get in the engine but the work will take a couple days, an inspector from the extended warranty company must verify thats the problem but my Tech at NHBEEMER knows his stuff, so the extended warranty will put me in a rental plus fix the problem, what u guys think about that, when the tech sat in the car while in park and got on the gas we all saw smoke come out the tail end, and before i even got the oil changed, another msg came op on dash saying oil low, please add oil.
Old 11-21-2012, 11:16 PM
Mein Auto: 745Li
Mein Auto: Nothing
You have bad valve stem seals.. very common on these motors.. luckily you have a warranty or you would be paying a few grand to fix. 10k is dealer price, which is obviously a joke..
Old 11-22-2012, 01:31 AM
allaboutdaz allaboutdaz is offline
Send a message via AIM to allaboutdaz Send a message via Yahoo to allaboutdaz
Mein Auto: 745
Keep is posted on what the final out come is
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 12-18-2012, 09:44 PM
Mein Auto: 745Li
Update on Emissions related fault(Thanks NHBeemer)
Ok friends and fellow BMW owners I got my car back today and the guys at NorthHouston Beemer took card of the problem they replaced the valve gasket, bolts, pan redone the heads looks brand new, this would have cost me close to 5,000, i walked out only paying 378.00 had to pay 200.00 deductable, and they replaced and seal around the oil, i was not in a rush to get the car, so i told them take their time, i don't believe in rushing people, but I included pics on the work, before and after pics, I will break down all what they did
ID:	353809   Click image for larger version
ID:	353810   Click image for larger version
ID:	353811   Click image for larger version
Old 12-18-2012, 09:45 PM
Mein Auto: 745Li
More pics
More Pics
ID:	353813   Click image for larger version
Old 12-18-2012, 10:30 PM
Mein Auto: Nothing
So what exactly did they do? Valve stem seals? I have 130k on my car and I can let it idle for 20 plus minutes and I don't get a spec of smoke, does that mean someone has already fixed it? I thought they all do it?
Old 12-19-2012, 02:19 AM
Mein Auto: 745Li
My problem solved(what caused smoke)
After they went thru it they found out that both cylinder heads were leaking oil thru valve guides, so they replaced valve guides, replaced both cylinder heads gasket sets and all the seals, this included head bolts head gaskets, steel gasket and head gasket set, replaced the oil and coolant, no more smoke, also replaced oil filter, torx bolt, central bolt, valley pan, 2 O Rings and a Pipe, These guys at NH Beemer gained my trust
Old 12-19-2012, 04:45 AM
Tsa1 Tsa1 is offline
Mein Auto: 08 E90 335i
What is the company you have the extended warranty through and how much did it run you if you dont mind me asking?
"The money powers prey upon the nation in times of peace and conspire against it in times of adversity. The banking powers are more despotic than a monarchy, more insolent than autocracy, more selfish than bureaucracy. They denounce as public enemies all who question their methods or throw light upon their crimes. I have two great enemies, the Southern Army in front of me and the bankers in the rear. Of the two, the one at my rear is my greatest foe."
Abraham Lincoln
Old 12-19-2012, 09:17 AM
Mein Auto: Nothing
He says it all above.
Old 12-20-2012, 08:47 AM
Mein Auto: 745Li
Good morning the extended warranty I purchased from Advantage BMW was the MAP "motor assistant plan" i got the full coverage Platinum which covers everything, the most they will charge is a $200. deductible meaning if 1 thing is wrong that's a $100.00 2 things wrong $200 3 to 4 things wrong the most they will charge is $200.00 hope that explains it
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
