Old 06-04-2005, 07:47 PM
kybriggs82 kybriggs82 is offline
Mein Auto: 1963 THUNDERBIRD ROADSTER
2005 E60 Bluetooth Setup Question
I Have A Motorola V551 And I Am Attempting To Setup This Phone With My Vehicle. Can Someone Tell Me How To Setup My Phone To Be Compatible With My Vehicle? What Settings Do I Need To Use On The Motorola V551 And What Settings Do I Use For My Vehicle Under Communications? I'm Confused!!! Help!!! Please Make It Very Basic For Me To Understand!!!!!! Thanks!
Old 06-04-2005, 08:45 PM
TL2E90's Avatar
TL2E90 TL2E90 is offline
Mein Auto: 2009 BMW 750i
You will need to browse E60 user manual as well as you phone's user manual (see bluetooth section)
From waht I know in general, there is a process called "pairing" that is when you pair your cellphone with your car. I did pair up my Sony-Ericsson T68i with my former Acura TL and albeit I don't remember details, I do remember that it was very simlple after reading user's manuals.
Old 06-04-2005, 08:52 PM
Here's the problem.. My Motorola phone worked before but BMW had to reset my computer and now my cell phone doesn't pair.. Oops I lost my Motorola v551 instruction booklet and now I'm stuck.. a little help please... Does my cell phone go inside the console to pair???
Old 06-04-2005, 09:11 PM
kd2789mo kd2789mo is offline
Mein Auto: Radio Flyer Z38/5.7m
http://www.motorola.com/mdirect/demo..._v551/V551.pdf
https://commerce.motorola.com/consum...ml/manual.html
Kd
04 745Li Silver/Grey, 19" Star, LOGIC7, CWP, Adaptive Cruise, LSP, CP, PDC, Shades, Xenon, Sirius
Old 06-06-2005, 04:47 PM
CapeBimmer CapeBimmer is offline
Mein Auto: - - - -
The phone can be anywhere inside the car to pair.
I too have a V551 and although I do not remember exactly what I did I do remember that it was very important to follow the BMW instructions to the letter.
The phone - go to the icon with the screw driver and wrench -
then to "connection", select bluetooth and it will look for the car and the car will look for the phone.
then to the "car settings", settings should be Auto answer "off", Auto handsfree "on"
not sure about the others but I have Power-off delay "30 minutes" and charger time "off".
I also recommend that when in the car keep the phone plugged in to a charger. I only get about 30 minutes of talk time if the phone is not plugged in.
Good luck . . .
Old 06-06-2005, 09:01 PM
This is because of the Motorola default setting for your phone to seek a compatible device is every 10 minutes. If you change the seek setting (located in initial setup menu) to 60 minutes, your talk-time will improve to 90-120 minutes.
The combination of the large LCD color display, and 20 second bluetooth seek every 10 minutes, rapidly discharges the battery.
Kd
Old 06-07-2005, 03:28 AM
Mein Auto: - - - -
KD,
Thank you - I will change the seting.
Steve
Old 06-07-2005, 06:03 AM
Mein Auto: - - - -
KD,
I can not find the seek setting in the intitial set up menu.
Old 06-14-2005, 08:36 AM
Mein Auto: - - - -
to KYBRIGGS82
I am having the same problem you had. My car went in for service and came back with software rev. 17.2 and my bluetooth does not work
What did you do to get your V551 to pair to the car?
Thanks,
Steve
Old 06-17-2005, 01:04 AM
TGray5's Avatar
TGray5 TGray5 is offline
Ultimate Driving Machine
Mein Auto: '13 F10 550i; '13 R1200GS
to KYBRIGGS82
Thanks,
Steve
Sorry to hear...sounds like v17.2 is bad news. Another poster mentioned that his auto headlights and rain sensor were all messed up after getting v17.2 as well. grrrrr
Old 06-17-2005, 05:25 AM
mrbelk mrbelk is offline
Send a message via MSN to mrbelk
Mein Auto: 07 335i/6sp
Sounds more like the technician that did the SW upgrade didn't bother to note that the BT functionality was enabled prior to the upgrade, and then the upgrade clobbered the configuration and removed the BT functionality. Just like when you reset a hardware device back to factory defaults; you'd better have a backup of the running config so that you can get it back to where it was.
-MrB
(ED 5/11/13) '13 328i M-Sport Estoril Blue II/Black, Trip Journal
(ED 5/25/10) '11 335i M-Sport Le Mans Blue/Oyster, Trip Journal
(ED 5/19/08) '08 X3 3.0si Alpine/Tobacco, Trip Journal
(ED 5/7/07) '07 335i/6sp TiAg/Lemon, Trip Journal
(ED 4/18/05) '05 X3 3.0 Blue Water/Black, Trip Journal
(ED 4/28/04) '04 545i Silver Gray/Beige
Old 06-17-2005, 06:51 PM
Mein Auto: - - - -
I did get my phone to pair with the car but only about 40% of the phone book downloads to the car. Strange . . . Also the phone talk quality is worse now. Signal is terrible - I am dropping a lot of my calls or the call fades in and out.
I've been away all week and plan to call my SA on Monday.
17.2 - there is no longer a (compass) direction indicator in the Nav system! I think the old arrow to north and then you had to figure out the direction was awful - it should tell you what direction you are going. But now there is nothing!
The car is now less "touchy". I think they detuned the active steering and the throttle response and/or shifting points (automatic tranny). Anyway I have only driven to and from the airport since I got it back.
Old 06-17-2005, 07:46 PM
TGray5's Avatar
With 16.2 there is no direction indicator on the nav screen either. I set the assistance window to show 'current position' and there is a North pointing arrow on that screen.
Similar Threads
Bluetooth Code for pairing. bmwxdrive X5 E53 (1999 - 2006) 5 03-05-2005 08:08 PM
2005 Bluetooth with Assist approved phones blockpavick Car Navigation, Audio & Electronics by BAVSOUND 2 02-26-2005 05:06 PM
Bluetooth Question wuzin X5 E53 (1999 - 2006) 1 02-23-2005 06:23 AM
Another Bluetooth Question Phase1 European Delivery 3 12-12-2004 05:53 PM
