Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 06-07-2005, 05:51 PM
jeshie7 jeshie7 is offline
Mein Auto: 2000 bmw m5
2000 bmw m5
i bought a 2000 bmw m5 may, 28th 2005 it only had 24000 miles on, it was a perfect car and was rarely driven now june 7th with 26,000 miles my clutch gave out completley and now im gettin my clutch and flywheel replaced at bmw for $2400. but its kind of odd for a clutch to blow out at 26000 miles anyone had a simliar problem?
Old 06-07-2005, 07:03 PM
01Byte's Avatar
01Byte 01Byte is offline
Pastafarian Extraordinair
Mein Auto: 335d
I'm looking to get a M5 and have been doing some research. I can offer you this...
First, the clutch on the M5 is the weakpoint of the drivetrain. It does not stand up against abuse. If the driver before you tracked the car regularly (or drove it like he did), then the clutch might suffer premature failure.
Second, you could save yourself about $1,000 dollars if you did the work at an independant mechanic. $2400 seems high.
Anyway, look at it this way, you will have a true Beast with a new clutch that if treated right will last a long time.
Congrats on the car and hopefully this is the only glitch you'll find.
May we be blessed by His noodly appendage and His almighty sauciness.
Old 06-08-2005, 09:12 AM
KevinM's Avatar
KevinM KevinM is offline
Mein Auto: '02 M5, Sterling Gray
Yes, I have heard of this. Go to www.m5board.com and do a search on clutches; you will find much information.
As posted above, the OEM 9" organic clutch can prematurely fail due to the large amount of torque the S62 engine produces. The car does not even have to be tracked for this to happen; if the previous owner let the clutch slip under hard accleration frequently, the clutch will not last. BMW's unofficial policy is to allow one clutch replacement per car under warranty (I assume your car is out of warranty).
On the other hand, an OEM clutch, when driven with care, can last for a LONG time.
Congrats on the car; there is nothing like it!
Kevin
2016 F80 M3 Mineral Gray/Golden Brown (ED 6/3/16)
ED delivery thread: http://f80.bimmerpost.com/forums/sho....php?t=1291837
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
1999 Mercedes ML320 (hauler...)
Old 06-08-2005, 12:36 PM
2000 m5 clutch
thankx guys, i got the car fixed bmw had it for 3 days i had dropped it off there monday and got it back today.... the clutch is really soft compared to what it was, new clutch and flywheel ran me $2300 but it rides awsome now still have my doubts about the job they did, now when i close my door i get a rattlin sound from the bottom .....
Old 06-21-2005, 11:46 AM
polshrk polshrk is offline
Mein Auto: 00' BMW M5
clutch
The OEM SACHS/LUK clutch can be bought on eBay for round $300, just bought two @ $284 each, this is true what everyone says that it will last LONG time if properly broke in and driven nicely. Make sure you follow the break-in procedure on www.m5board.com do a search for it and you will find tons of info. After replacing it it will a lot softer than before the job, however will come back to the normal feel after a week or two, depending on how much you drive.
Let me know if you have any questions about anything, I am a 13year BMW master tech and own my own shop in VA (www.eastcoastexotics.net) I have two 2000 M5's and love the beasts!
regards
adam
Similar Threads
Wall Street Journal Article on BMW's Past, Present and Future Salvator General BMW Questions 65 12-25-2010 08:22 PM
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 03:59 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
The Bmw Group Moves Into A New Dimension tim330i General BMW Questions 6 03-21-2004 11:11 AM
BMW drivers selected for Nürburgring 24 Hours tim330i Motorsports, Racing & Track 5 03-17-2004 07:37 AM
