E46 (1999 - 2006)
Old 06-14-2005, 07:47 AM
RyanUH RyanUH is offline
Mein Auto: BMW M3
2 Quick Questions, Bluetooth and Sirius
I have a 2003 M3 Coupe. I have just received the latest module and the install kit. The pairing button that came wit the install kit has the identical picture that is on the steering wheel. Will the button on the steering wheel pair the phone to the car??? Also, I already have TVonNav and I am installing Sirius satellite radio. The mounting bracket and location for the sirius is where the TVonNav goes. What did you do to install sirius, where did you put it and how did you mount it? Any suggestions would be great...
Ryan
Old 06-14-2005, 08:40 PM
SRFast's Avatar
SRFast SRFast is offline
Mein Auto: 2003 BMW 530i
The steering wheel button cannot be used to pair the BT ULF and your BT phone. If you don't want to mount the pairing button, connect it to the wiring harness, pair the phone and then disconnect it. The ULF will work without it. You can also leave it connected and tuck it away under the center console.
If you cannot mount the Sirius receiver in the intended location, be creative. As long as the CD changer prewiring can reach the unit, you can mount it anywhere. It can be mounted in any position becuase there are no moving parts.
Hope this helps.....JL
2003 530i 5spd/SP/PP/CWP/PDC/RSAB/Xenons
Similar Threads
new owner of 2001 740il bluetooth & sirius question reneauds 7 Series & 8 Series 5 09-25-2004 02:54 PM
No Sirius, no Bluetooth with BMW Assist rkahn 3 Series & 4 Series 31 03-29-2004 12:39 AM
Sirius Questions dizuel Car Navigation, Audio & Electronics by BAVSOUND 2 11-12-2003 06:34 AM
Bluetooth, Sirius, and BMW Assist Fritz 3 Series & 4 Series 4 09-15-2003 10:49 PM
2 Questions on Bluetooth & Sirius Sat Radio langbr01 3 Series & 4 Series 6 09-01-2003 12:45 AM
