Old 06-19-2005, 04:55 PM
joeydosh joeydosh is offline
Mein Auto: X3, 3.0 - Silver
Satellite Prep
Can someone splain to me what this means?
X3 3.0L Silver Gray Metallic, Gray Leather, Premium, Heated Seats, PDC, Rear Air Bags (deactivated)
Old 06-19-2005, 06:32 PM
Liverman's Avatar
Liverman Liverman is offline
Mein Auto: '14 X3 35i / '03 F350
It is the wiring for satellite radio (Sirius) between the head unit in the dash, the location where the satellite receiver goes in the rear and the antenna on the roof. If you don't order the satellite prep, then the BMW satellite radio units (that work seamlessly with the audio system) cannot be installed no how, no way (as I understand it from reading the material available on the web). See http://www.bmwmotorsports.org/pdf/x3_sirius_install.pdf
You could probably add an aftermarket sat radio unit from someplace like Crutchfield that used an FM radio hookup or the AUX input (with separate controls, of course).
Greg
Old 06-20-2005, 06:32 AM
So, if the vehicle I purchased has the prep work what would I need to do in order to have satellite radio? Do I have to purchase a different radio and sub to service?
Old 06-20-2005, 07:52 AM
Liverman's Avatar
You would need to order the Sirius Receiver (84-11-0-153-365) and an istallation kit (84-11-0-390-240 if you have no Nav or 84-11-0-390-943 if you have Nav).
See this from Pacific BMW. This is my source of info...I have not actually done this my self, but I had the same question as you and this is what my research turned up.
Again, I do not know what it would or would not take to add another brand of Sirius receiver or if non-BMW receivers would even work.
Greg
Old 06-20-2005, 09:24 AM
Thanks, Greg - I will check it out. Appreciate the info!
Old 06-20-2005, 05:28 PM
DeanQ DeanQ is offline
Mein Auto: BMW 323IS
See my thread.
http://www.bimmerfest.com/forums/sho...d.php?t=102081
Just to clarify in order to have all the functions of the steering wheel to change stations and being able to save 18 sirius stations on the radio you will need to use a BMW sirius receiver. A aftermarket sirius receiver will not work with tha factory headunit. There is a device called a soundgate that lets you use a aftermarket sirius tuner with that factory radio but it is not worth it. The bmw radio will see the sirius receiver as a cd changer and you cant see any info like station name, artist or song title and you can't save any station presets and it's slow to scroll through all of 184 stations.
The best bet is to buy a bmw sirius receiver.
Similar Threads
Satellite Radio In Europe smokinlu E46 (1999 - 2006) 10 06-25-2005 03:45 PM
Wondering if this is possible. XM satellite question. Plupp E39 (1997 - 2003) 4 06-08-2005 07:03 AM
'05 X3 with nav - satellite / ipod question. JakeInVa Car Navigation, Audio & Electronics by BAVSOUND 1 11-15-2004 08:18 AM
Another satellite radio / nav question JakeInVa X3 E83 (2004 - 2010) 0 11-14-2004 02:25 PM
MP3 and Satellite Radio? sbrenner 3 Series & 4 Series 4 08-26-2003 08:42 PM
