Old 06-20-2005, 02:39 PM
Sonoman707 Sonoman707 is offline
Mein Auto: 2008 X3 3.0si
Rear Door Speaker Cover (or door panel)...
Anyone have any experience in removing either the door panel or (hopefully) just the speaker grill in the back door of an X3?
I have an annoying vibration coming from the speaker at certain frequencies... the service dept. failed to resolve it even after replacing the speaker.
The speaker grill looks like it may pry / snap off - but am hesitant to start prying.
Old 06-20-2005, 04:22 PM
mguhler mguhler is offline
Turn it up!!!
Mein Auto: 2014 F150 Platinum EBoost
take off the entire door panel
I replaced my front door speakers, I expect the rear is the same. the entire door panel must come off, then you can get to your speakers. If you are looking to replace, you'll need a shallow depth speaker. I used Pyle PLS for the front and have a great sound now.
Best of luck, the panels are easy to remove.
My Old Rides:
1993 318i sedan
2004 X3
2011 X5 50i - ZCW, ZPP, ZPS, ZRC, ZTP
Current Ride:
2014 F150 Platinum w/ EcoBoost
Old 06-21-2005, 10:57 AM
Cool. Any special tools required?
I'm assuming the arm rest is attached with screws... is the rest of the panel attached with those plastic "friction" plugs?
Thanks.
Old 06-21-2005, 12:00 PM
Turn it up!!!
patience
just a screwdriver, cloth and patience.
There are screws holding the panel on in the arm rest, behind the trim and might be another behind the cap of the inside door lever. Should be 4 or 5 in total. Once screws are undone, carefully pop a few of the plastic clips and work your way around one side of the door, then the other. Should be straight forward once you start.
Take your time so you don't do something you regret.
My Old Rides:
1993 318i sedan
2004 X3
Current Ride:
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Rear Fog Light Research (post-facelift E46) bluer1 3 Series & 4 Series 99 08-09-2004 12:46 AM
Is the rear window cover worth the time? Fish E36/7 Z3 (1996-2002) 5 08-02-2004 04:53 PM
Rear bumper gap revisited (long) biodan 1M & M2 2 09-14-2003 10:59 PM
Interior Car Cover Problems Brashland 3 Series & 4 Series 2 12-20-2002 01:50 PM
