E46 (1999 - 2006)
Old 06-21-2005, 02:06 AM
gs023 gs023 is offline
Mein Auto: Bo
Reset Oil Service - Help ?!
I Need reset OIL servis
Service reset
Notes:
To skip the 'Oil service reset' or 'Brake fluid reset', press button 1 for appr. 5 sec.
If another immediate reset of the 'Oil service' is necessary, it is only possible after a trip of 10 km or more. OK
If another immediate reset of the 'Brake fluid service' is necessary, it is only possible after a 20 day period. OK
To abort the procedure at any time: turn the ignition to "0".
Oil service reset:
Turn the ignition to "0"
Press button 1 and turn the ignition to "1".
Keep button 1 pressed until the display shows: "Inspektion Re / Reset". - See always TEST..., then Time, KM and again TEST!Cut dead never Inspektion Re / Reset. (I can see no Inspektion Re / Reset). Help pleas ??? How at it?
Press button 1 again (***261; 5 sec.) until Re / Reset flashes
Press button 1 shortly.
The next oil service interval will be shown and will disappear.
The brake fluid service interval is shown. The display shows: "Re / Reset".
Brake fluid service reset:
Press button 1 again (***261; 5 sec.) until "Re / Reset" flashes
Press button 1 shortly. The display shows: "END SIA".
Car BMW E46_323i 01/2000
I am search, that I must Activation "reset distance service", but I don't know where set ?
Excuse please my English!
Old 05-18-2007, 12:49 PM
enertec enertec is offline
Mein Auto: X5 2002
BMW X5 2002 Oil Reset
BMW X5 Engine Oil Service reset
Press and hold odometer button and turn the ignition to "1".
Hold odometer button pressed for approximately 5 seconds until the display shows: "Inspektion Re /
Release and press odometer button again until Reset flashes
Release and press odometer button shortly.
Release and press odometer button again.
Oil service lamp is now reset
Note: To abort the procedure at any time: turn the ignition to "0".
Old 05-12-2009, 06:06 PM
craigmack1's Avatar
craigmack1 craigmack1 is offline
Mein Auto: 02' 325i
ooops.
wrong spot for post....sorry
Old 11-25-2009, 08:33 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
^ stop advertising your website, it is for the wrong model in the first place and these threads are OLD. I already made vids for spark plugs and the oil indicator for E46s!
Old 05-20-2011, 03:20 PM
Mosimoji Mosimoji is offline
Mein Auto: X5
2005 x5 bmw
Hi,
How can I Reset BMW X5 oil service lights.
Similar Threads
Oil change Guest84 Off-Topic 21 08-12-2014 03:30 PM
After Oil Service reset, does INSPECTION show on dashboard? marcio E46 (1999 - 2006) 6 08-26-2009 06:07 AM
Engine oil cap missing - Service engine soon light sk330i E46 (1999 - 2006) 14 05-07-2005 05:20 PM
LOW OIL LEVEL warning roadie 5 Series 16 04-04-2005 07:16 PM
Dirty oil after dealer 15k oil service?! (x post) sj330ciclvr General BMW Questions 51 08-03-2004 07:50 PM
