Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 06-25-2005, 06:06 PM
Shadyside Shadyside is offline
Mein Auto: 2002 330Ci SP
Pre 09/02 E46 Aux Input Kits
Hi All,
This is a very informative forum and a great site. Glad to post my first message. I just had installed an XM Roady2, (using a Bracketron mount which looks fine) and hard wired for power. My plan was to install the aux input cable in the glovebox and have the wire lead out and plug into the back of the SAT receiver. The problem is that the aux cable would NOT plug and play and didn't register on the HU when the Mode button was pushed. Thus, no SAT input. Upon reading the aux input instructions more carefully, it stated that the cable was only for vehicles produced after 09/02. My 2002 was produced in 06/02. The aux input kit is part number 82 11 0 149 389 and my HU is SV 16-02-41. Does BMW make an aux input kit that is plug and play for MY 06/02 and prior? Does anybody know what the aux input kit;s part number is? Thanks in advance.
Old 06-25-2005, 07:04 PM
iversonm's Avatar
iversonm iversonm is offline
3 pedals only!
Mein Auto: 2008 550i Carbon Black
Blitzsafe makes an aux input adapter that "fools" you radio into thinking it's a CD changer.
It plugs into the wiring harness that is in your trunk, and then you have to snake a wire up to the center console. I'd be happy to answer any other questions you might have about the installation.
2012 E88 128i, Alpine White/Black
2011 E90 328i, Crimson Red/Black
2008 E60 550i, Carbon Black/Natural Brown, ED 2 November 2007 (retired)
2006 E83 X3, Silver Grey/Black, ED 15 May 2006. (retired)
2005 E46 330i, Jet Black/Black (retired)
2002 E46 325i, Electric Red/Black (retired)
Old 06-26-2005, 02:43 PM
elserviola elserviola is offline
Mein Auto: '02 320d
Yes, but what happens when you already have a CD changer and want to use it? Is there any solution that would allow me to add an aux input connector and also be able to use my CD changer?
Thanks is advance.
Old 06-26-2005, 03:10 PM
Thanks, but I don't want to go that route. I just want to have a workable Aux input on/near the dash for my XM radio or an MP3 player.
Old 06-26-2005, 04:36 PM
ObD ObD is offline
Mein Auto: '08 535 6mt
Thanks is advance.
You can add an aftermarket CD changer with an aux input adapter which has both interfaces ... just not the BMW CD changer.
Old 06-26-2005, 04:37 PM
ObD ObD is offline
Run an extension cable to the dash area. Not hard.
Old 06-28-2005, 10:14 AM
Iversinm and OdB thanks for the help. The difference I am looking at is now between the direct hard wired approach, or using an FM modulator (NOT wireless). To go direct, I would have to buy the Blitzsafe and run an extention from the trunk to the dash, not hard, but there would be bucks and time involved. While I would like the extra, tiny bit of fidelity that could be noticed on the HK system, it doesn't seem worth the expense, the modulators apparently do a pretty good job, much better than wireless in any regard. Thanks again for your help. BTW: my AM radio sounds fine, so even with a TSB, out for replacing 2002 HUs, I can't make the claim for a new unit.
Old 06-28-2005, 10:15 AM
Sorry I just got your names wrong! Iversonm and OdB!
Old 06-28-2005, 06:31 PM
Galun Galun is offline
In a ton of debt...
Mein Auto: Cars
I tried the FM modulator and that didn't work for me at all - way too much static. I got the blitzsafe adapter and it was quite easy to put in. You will still need a ground loop isolator (from Radio Shack) to get clear sound.
I'd recommend getting a good FM modulator and try it out, and see if you can live with it. If not, return it and go the route of blitzsafe. That's exactly what I did with my old car.
'02 Porsche 911
'04 BMW 545i
'06 Chevy Silverado 1500
'07 BMW 335i
'08 Lexus RX400H
Old 06-29-2005, 08:33 PM
barney rubble barney rubble is offline
Mein Auto: 525
deleted
Last edited by barney rubble; 06-29-2005 at 08:39 PM. Reason: didn't include original poster
Old 06-29-2005, 08:37 PM
Mein Auto: 525
Does the Blitzsafe product work to your satisfaction? How difficult was the install and how did you snake the wire from the trunk thru the console - is it a neat install or are there wires hanging?
I've been trying to decide whether or not to purchase this for my '02 525.
Old 06-29-2005, 11:35 PM
tehkao tehkao is offline
Back to life
Mein Auto: 2004 330i ZHP
I just installed the Blitzsafe AUX adapter, easy to install and worked like magic, lucky for me I had the Cold Weather Package and pull down rear seats so I just snaked my AUX cable thru there, hehehe. Kinda cheezy but it works.
Now I can play thousands and thousands of MP3s with perfectly clear sound!!!! Who needs a CD Changer??
The Blitzsafe solution is probably not for people who can't stand a weird cable winding thru their BMW though....
Old 06-30-2005, 10:44 AM
Mein Auto: 525
Follow-up questions:1) did you also have to get the DSP adapter
2) For those of us w/out the Cold Weather package, what's the best way to hide the wires coming in from the trunk?
Old 07-01-2005, 03:36 AM
Back to life
Cool
There is a seperate DSP adapter if you have DSP in your BMW...to be honest, I don't even know what the heck DSP is...I doubt that most people have it...
Old 07-02-2005, 12:11 PM
janey janey is offline
Don't touch my Bimmer !!
Mein Auto: 2003 325I
where can i get the Blitzsafe AUX adapter
thanks
janet
Similar Threads
Question on AUX input adapter install/DVD in stereo... King X5 E53 (1999 - 2006) 7 10-01-2005 05:30 AM
Not another Aux Input question.. POWER? Domer E46 (1999 - 2006) 1 04-30-2005 01:43 PM
How is aux input sound quality? equ Car Navigation, Audio & Electronics by BAVSOUND 5 10-29-2004 06:13 PM
Anyone? Can i add an Aux Input to 2005 530i? tcumbo 5 Series 9 10-21-2004 07:28 AM
Aux input and Ipod connector, co-exist? eelnoraa Car Navigation, Audio & Electronics by BAVSOUND 6 10-15-2004 11:31 PM
