Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 06-28-2005, 04:07 PM
Robert A Robert A is offline
Mein Auto: BMW 530i
Rear swaybar swap for E39
Just ordered an M5 rear swaybar for my 2001 530i. It's supposed to be a very easy install, but when I look under the car isn't doesn't appear quite so simple. Has anyone done it themselves? Do I need to raise the car? What tools do I need?
Thanks,
- Robert A
Current: '07 530i, White/Black, MT
Retired: '01 530i, '94 325is, '84 325e, '83 318is
Old 06-28-2005, 04:53 PM
vexed's Avatar
vexed vexed is offline
Senior Slacker
Mein Auto: 9A1
It is easy with the right tools. The trick is there is a nut that is encased in a rubber boot on the opposite side of the bolt that you can see for the sway bar links You can't really see that nut but you can feel it. You need to get a open wrench to hold the "hidden" nut and then a wrench to turn the one you can see. I think they are 16mm but it's been a while. The bushing brackets are easy, the new bushings fit right in. I jacked my car up some have claimed there is no need to but IMO if you jack it up the swap is easier. Good luck!
Edit: I did use the swap as an excuse to buy a combo rachet wrench which really made it easier. With the right tools it is a 25 minute job.
vexed
Similar Threads
Option code list Terry Kennedy General BMW 16 05-14-2006 03:59 PM
Rear Fog Light Research (post-facelift E46) bluer1 3 Series / 4 Series 99 08-09-2004 12:46 AM
Why there are no rear foglights in the US ruteger General BMW 54 06-06-2004 11:56 PM
Custom Rear Package Tray for Rear Seat Delete PICS FlyingDutchMan M Series 20 09-15-2003 09:59 AM
VERY theoretical question: Which is easier... an engine swap or a tranny swap? TD General BMW 31 01-10-2003 03:09 PM
