E36 (1991 - 1999)
Old 07-01-2005, 03:58 AM
david mc clean david mc clean is offline
Mein Auto: 323i E36
david mc clean
comic sans MS
Hi I have recently bought a 1997 3231 (E36) 5 speed manual and the car is running very rough - I have had two new oxygen sensors fitted and this has helped but the car still doen't run smoothly when accelerating through the gears. When the accelerator is well down tha car goes well but when driving at low revs it seems to be missing -any suggestions
Old 07-06-2005, 10:43 AM
vintageorange vintageorange is offline
Mein Auto: 93 325is
The check engine light doesn't come on?
First place I would look is the rubber boot between your air flow sensor and you throttle body, these are notorious for getting small holes and tears in them and causing problems but not necessarily lighting the check engine light.
This is just one easy place to check, the first thing I would look for along with any loose vacuum hoses.
But if the check engine light is not on and the engine is running noticeably rough there is a strong possibility that a connection in the computer is going bad, or a broken wire in the engine harness somewhere.
Similar Threads
In remembrance of 9/11 AF Off-Topic 6 09-11-2003 11:12 AM
Snipers cringe at the work of a criminal Guest84 Off-Topic 9 10-15-2002 12:04 PM
Great info on Barak-Arafat-Clinton Talks joes325xi Off-Topic 3 04-21-2002 10:49 PM
