E36 (1991 - 1999)
Old 07-02-2005, 10:03 PM
Charliewww Charliewww is offline
Mein Auto: 1994 bmw 325i
Bleeding air out of the radiator?
I have a 94 325i. The thermostat went out and I replaces it. It is still overheating and I get no heat to come out the heater. Im am trying to bleed the air out of the radiator but must not be doing it correctly. I removed the resivor cap and bleed screw filled the resivor untill the bubbles stopped coming out of the bleeder. I put the bleed screw back in, turned the heat full blast, started the car and let it run until it went past the 3/4 mark and shut the engine down before it hit the red. Let it cool check the resivor and started it again. It does the same thing over and over again and still no heat. Should I actually take it for a drive? Or am I missing a step of the bleeding?
Thanks for you Help!
Old 07-03-2005, 01:20 AM
Update. Again I started the car, let it warm up and had the bleed screw cracked. It hissed and hissed for over 5 minutes and I tightened it. Should I keep going or will it just keep hissing? How long could this take?
Old 07-03-2005, 11:22 PM
Fixed it water pump was shot
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
New euro-car runs on compressed air TeamM3 General Automotive Forum 14 10-11-2004 03:13 PM
Military Aviation Folks: Comanche Gets Cancelled Ajax Off-Topic 29 02-26-2004 07:11 PM
Mercedes-Benz Child Safety Rear Door Lock Complaint! adrian's bmw Off-Topic 33 01-31-2004 09:22 AM
