E36 (1991 - 1999)
Old 05-23-2005, 02:18 PM
wamusser wamusser is offline
Mein Auto: 1999 M3 Convertible
A/C fan
My a/c fan just stopped working on me today. The Compressor is still working. Could this have anything to do with having a dirty microfilter?
Thanks,
Bill
1999 E36 M3 Convertible
Old 05-23-2005, 04:08 PM
ImperialDuckM3 ImperialDuckM3 is offline
Mein Auto: E36's
Thanks,
Bill
It your display unit that doesn't work. Its a common problem with most E36.
Old 05-23-2005, 04:35 PM
Display works as usual. All buttons function, light up, ..etc. Just no fan.
Old 05-23-2005, 06:45 PM
Mein Auto: E36's
Did you check the fuse? If there's power, then check your plug which are located at the bottom of the Aux Fan.
Old 05-24-2005, 05:01 AM
Yes I checked the fuses. I have no idea where the auxillery fan plug is.
Old 05-24-2005, 08:04 AM
Mein Auto: E36's
If you looked under your AUX Fan, you will see a connector. You Aux fan is located in front of your radiator. Take out the connector and try to power up the Aux fan. Run hot wire to the connector and see if it turn. If not, then your Aux fan is shot.
Old 05-24-2005, 09:47 AM
I'm confused as to why I need to do anything with the Aux fan. The heater blower fan is behind the firewall.
Old 05-24-2005, 06:01 PM
Mein Auto: E36's
Oh I thought you say your aux fan, which comes on when you turn on your A/C doesn't work.
So what you're saying is that there's NO AIR blowing inside your car, when you turn on the A/C?
Old 07-06-2005, 11:04 AM
Sulsa Sulsa is offline
Mein Auto: '99 Avus Blue 328iS
I am also having the same issue on my '99 328is. Have to check the fuse yet, but it just happened last night. I can hit all the buttons and they all work fine. I know it's not the actual control unit because I got that problem fixed already. It was a capacitor on the board that needed a bit of re-soldering. Hasn't happened since.
If anyone has any suggestions, please let us know. I'd like to fix this myself if possible. Dealer has limited hours and I can't get it into them very easily. Not to mention it's usually very expensive.
Old 07-06-2005, 04:26 PM
Bmwcat Bmwcat is offline
Retired Slacker
Mein Auto: A car.
Sounds like it MAY be the resistor package gone south or a Final Stage resistor. Parts could run 50-100 bucks. If you do a search the DIY is not too difficult. Good Luck..
"Patriotism is the last refuge of a scoundrel." -Samuel Johnson
Old 07-07-2005, 11:45 AM
tomas3314 tomas3314 is offline
tomas3314
Send a message via Yahoo to tomas3314
Mein Auto: SC 95 M3, 92 325i
Thanks,
Bill
Does it work (try it) only when on max setting but not when on 1-3? This would be your resistor pack (~$30 DIY fix)
P.S. this has nothing to do with a dirty microfilter.
Image Hosted by ImageShack.usA few mods too...
Similar Threads
A/C Fan Speed Question ltbong X5 E53 (1999 - 2006) 2 11-30-2004 05:16 PM
Erratic a/c & heater fan speed problem circuit info required enterprise 3 Series / 4 Series 3 08-15-2004 09:00 PM
Help: My Fan and A/C Completely stopped working palooka666 3 Series / 4 Series 4 06-26-2004 08:34 AM
Fan delete (S54) Ron Stygar E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 13 05-22-2004 11:03 PM
A/C Fan has gone haywire. Changes speeds even when not on auto. Anyone else? ESS 3 Series / 4 Series 3 09-30-2003 01:34 PM
