E36 (1991 - 1999)
Old 07-09-2005, 10:02 PM
nads12345's Avatar
nads12345 nads12345 is offline
Officially Welcomed to The 'Fest!
Mein Auto: 03 325xi
what are the recalls on 95 e36??
Old 07-09-2005, 10:33 PM
nads12345's Avatar
Mein Auto: 03 325xi
found recalls
i found the recalls, can i now, 11 years later go and fix them and holw do i know if they changed the stuff already.
Old 07-12-2005, 01:11 AM
aidensocal aidensocal is offline
Mein Auto: 325is 1995
if you found them why dont you post them for everyone?
Old 07-16-2005, 10:20 AM
nads12345's Avatar
Mein Auto: 03 325xi
my bad
Automotive Recall and Technical Service Bulletin Titles for 1995 BMW 325is (E36) L6-2494cc 2.5L DOHC (M50 TU).
Safety Recalls
TSB Number & Issue Date TSB Title
170198 FEB 01 Recall - Radiator Cap Replacement
000194 JAN 00 Campaign/Recall - Codes Index
350197 OCT 97 Recall - Cruise Control/Throttle Cable Breakage
720796 DEC 96 Recall - Restraint System Labels/Warnings
320296 AUG 96 Recall - Airbag Contact Ring
610896 AUG 96 Recall - Brake Light Switch
3203944074 OCT 94 Recall - Occupant Crash Protection
1304923657 JUL 94 Recall - Fuel Feed Hose Hardens/Leaks
General Recalls
3202954198 SEP 95 Campaign - Standardization of Equipment Levels
Service Bulletins
640403 OCT 04 A/C - Musty Odors From Heater and A/C Systems
650104 APR 04 Radio - Reception Problems, Antenna Diagnosis
240302 AUG 02 A/T - A4S270/310R (GM4), Piston Cover Fluid Leaks
160201 SEP 01 Fuel Gauge - Incorrect Reading
110101 JUN 01 Engine - MIL ON/Codes Set/Tapping/Rattling Noise
640101 JAN 01 A/C System - Musty Odors
721100 NOV 00 Child Seat Tether Anchor - Installation
720897 OCT 00 Airbags - Deactivation
340100 SEP 00 Fuel System - ASC Lamp ON, Fault Codes 40 or 50 Set
620400 AUG 00 IC Conversion - Km/h to Mph or Mph to Km/h
610500 JUL 00 Electrical Connnectors - Stabilant 22A Contact Enhancer
720496 JUN 00 SRS - MIL ON, Codes 16/17 or 24/25 Set
160498 MAY 00 Instruments - New Fuel Level Sensor Testing Caution
240100 APR 00 A/T - Fault 111 (Component Slippage/Speed Monitoring)
610200 APR 00 Airbag Systems - Wiring Repair Procedure
040900 MAR 00 Service Information Ruling for OBD
070296 MAR 00 Updated DIS Software CD 21
040800 FEB 00 Tools - New Special Tool CD
002292 JAN 00 Spark Plug/Engine Oil Capacity Reference Chart
620297 DEC 99 Instrument Cluster - Revised Design
640399 AUG 99 A/C - Blows Hot
040899 JUN 99 New Self Adjusting Clutch Clamping Fixture
070296 JUN 99 Updated DIS Software CD 18.0
001098 MAY 99 Electrical Trouble Shooting Manuals - Available on CD
040699 MAR 99 Electrical Connector Kit 4 - Supplement
230299 MAR 99 M/T - Jumps Out of 1st & 2nd Gear Under Load
040199 MAR 99 Windshield - Replacement Tools
320299 FEB 99 Ignition Lock - Sticks
230199 FEB 99 M/T - Difficult to Shift, Diagnostic Tips
120399 JAN 99 ECM - Reprogramming W/P16.0 Version Software
320199 JAN 99 Starting - Ignition Lock Spins Freely
651798 NOV 98 CD43DIN/C43DIN Radio - Security Code Information
620295 OCT 98 Instrument Cluster - Transfer of Odometer Reading
510998 OCT 98 Windows/Glass - New Adhesive Kit
340398 SEP 98 ABS System - MIL ON DTC 145 Set
080398 AUG 98 MoDic III(R) - Questions and Answers
080198 JUL 98 MoDic III(R) - System Description/Operation
070296 JUL 98 Updated DIS Software CD 14.0
340298 APR 98 ABS/ASC - Warning Lights On During Dynamometer Test
650898 APR 98 Alpine Alarm System - Siren Inoperative
090198 APR 98 Computers/Controls - Custom Configuration
650398 MAR 98 Audio - Faulty Gong Causes Sound Like Alternator Noise
651896 MAR 98 CD Player Malfunctions - Skips on Rough Road Surface
070198 MAR 98 DIS Schematic Information
040298 MAR 98 Electrical Repair Kit IV - Additional Connectors
110496 FEB 98 Engine - Removal and Installation Tips
080596 JAN 98 Updated MoDic(R) Diagnostic Software - D12.0
080396 JAN 98 Updated MoDic(R) Software - ZCS Coding
110198 JAN 98 VANOS System - Function Check
841397 DEC 97 Motorola Mobile Phones - Replacement Parts
240497 NOV 97 A/T - Does Not Upshift When Cold
041597 NOV 97 New BMW Special Tools.
041697 NOV 97 New BMW Special Tools..
080396 OCT 97 Updated MoDic(R) Software - C11.0 ZCS Coding
080496 OCT 97 Updated MoDic(R) Software - P11.0 Programming
240594 SEP 97 A/T - Pendulum Shifts, Delay Gear Engagement, Case Leak
640993 AUG 97 A/C - Replacement of Receiver Dryers: R12/R134a
001396 AUG 97 Microfiche Update - All Models
100396 AUG 97 TIS Software Update - 07/97
100396 JUN 97 TIS - Software Update
000897 MAY 97 Label for Service Action or Recall Campaign (#201-220)
0109954318 APR 97 Diagnostic Time - Warranty Reimbursement
010397 APR 97 Modified Vehicles - Warranty Exclusion
120397 MAR 97 Engine Controls - Difficult to Start When Cold
100396 FEB 97 TIS - Software Update 12/96
070296 FEB 97 Updated DIS Software CD 9.0
080396 FEB 97 Updated MoDic(R) Software - C9.0 ZCS Coding
080496 FEB 97 Updated MoDic(R) Software - P9.0 Programming
611996 JAN 97 Central Locking System - Locks by Itself
610788 DEC 96 Battery - Maintenance System
0101943986 DEC 96 Paint and Paint Repairs - Warranty Coverage
240694 NOV 96 A/T - Erroneous Fault Code 40, Pressure Regulator
410396 NOV 96 Body Lifting Pads - Wind Noise
611296 NOV 96 Electronic Immobilizer (EWS ll) - Malfunctions
611696 NOV 96 General Module - Sporadic Accessory & Lighting Operation
004089 NOV 96 Microfiche - Service Information Bulletins List
010396 OCT 96 Service/Warranty - Information Statement
651796 OCT 96 CD Player - Operational Whining Noise
010696 OCT 96 Certified Pre-Owned BMW Vehicle Program
010796 OCT 96 Flat Rate Manual - 8th Edition
840496 OCT 96 Phone Tray - Availability of New Style
002196 OCT 96 Service Action/Recall Campaign 181- 200 - Labels
070296 OCT 96 Updated DIS Software CD 8.0
080496 OCT 96 Updated MoDic(R) Software - P8.0 Programming
720696 SEP 96 Restraint System - Transportation of Infants/Children
100396 SEP 96 TIS - Software Updated
010290 SEP 96 Warranty Defect Code Microfiche - Revision
651696 AUG 96 Alarm System - False Alarms Due To Glass Breakage Sensor
651396 AUG 96 Cellular Phone Antenna - Installation
070396 AUG 96 DIS Maintenance and Operation
120996 AUG 96 ECM - EPROM Replacement/Application Chart
240496 AUG 96 EPROM - Replacement/Application Chart Order Form
720196 AUG 96 SRS - Warning Lamp ON/Fault Code 1 Set
042796 AUG 96 Wheels/Tires - New Wheel Weight Tools
990296 JUL 96 Paint - Approved Materials
720596 JUL 96 SRS Control Module (ZAE II) - Coding
042196 JUL 96 Special Tools - New Torque Angle Indicator
640196 MAY 96 A/C - Reduced Air Output or White Mist
240992 MAY 96 A/T - Gasket/Plug Leaks
340496 MAY 96 Brakes - ABS Warning Light Glows
120195 MAY 96 Electrical - 2 and 3 Pin Plug Connector Seal Information
620296 MAY 96 Speedometer - Maximum Permissible Error
070296 MAY 96 Updated DIS Software
640296 APR 96 A/C - Temperature Control Function Change
640695 APR 96 A/C System - Warranty Claim Noise Questionnaire
650296 APR 96 Audio - 6-Disc Alpine CD Changer Troubleshooting Guide
041196 APR 96 New Environmentally Safe Parts Washer
720496 APR 96 SRS - Warning Lamp ON For 2 Minutes After Startup
720396 APR 96 Safety Belts - Child Restraint Feature
080396 APR 96 Undefined MoDic(R) Software
041896 APR 96 Windshield - Bonding Adhesive Cutter
610296 MAR 96 Driveaway Protection Modules - Coding After Replacing
610196 MAR 96 EWS II Control Modules - Coding of Replacement
340196 MAR 96 Instruments - Impaired Diagnostics/Implausible Faults
041696 MAR 96 Special Tool - Clutch Disc Wear Gauge
041096 MAR 96 Special Tools - Electrical Connector Release Tools
310193 MAR 96 Suspension - Replacement of Shock Absorbers
100396 MAR 96 TIS Software Update
340296 FEB 96 Brakes - Master Cylinder Reservoir Seal Damage Caution
070296 FEB 96 DIS Software Update
000496 FEB 96 Electrical Troubleshooting Manual - Supplement #2
620196 FEB 96 Engine Control - BC V Fault Codes 6 & 15
610396 FEB 96 Illuminated Key - EWS ll Equipped Vehicles
320196 FEB 96 P/S - Identification & Diagnosis
720296 FEB 96 Safety Belt Pretensioner Arming Cable - New Style
040596 FEB 96 Tools - Air Bag Triggering Adapter Cable
360296 FEB 96 Wheel - Size/Configuration
0026903100 JAN 96 Engine Repair Manual - Microfiche Update
510296 JAN 96 Sun Visor - Pops Out of Retaining Clip
0026903100 JAN 96 Technical Data - Updated Microfiche
360196 JAN 96 Tires - Application Chart
040196 JAN 96 Tools - New Special Tools
1108944139 DEC 95 Engine - Will Not Start In Cold Weather
2405954294 NOV 95 A/T - EGS/AGS Control Module EPROM Replacement
6203954233 NOV 95 Check Control - 'Brake Light Circuit' Message Erroneous
6510954284 SEP 95 Cellular Phone - Cannot Be Programmed
5108944129 SEP 95 Dash - Warped Above Center Vent
1208954274 SEP 95 ECM - EPROM Replacement
6107954287 SEP 95 EWS II and DME Control Module - Alignment Not Possible
6201954172 SEP 95 Odometer/Coding Plug/Instrument Cluster - Replacement
3204933869 SEP 95 Steering Gear/Rack - Warranty Return Policy Information
5408954270 SEP 95 Sunroof Lid - Revised Mounting Method
6403954271 AUG 95 A/C Belt Tensioner - Rattles, Noisey When A/C Engaged
1111903149 AUG 95 Engine Oil Capacities - All Current Models
1203851085 AUG 95 Ignition - Spark Plug Application Chart
5403954250 AUG 95 Sunroof Cassette - Installation Instructions
2401933748 AUG 95 Warranty - Technical Liaison for ZF Products
9901954218 JUN 95 Aluminum Components - Painting Procedure
0411954232 JUN 95 Electrical Connector Kit - Repair Listing
1207944116 JUN 95 Engine Controls - ECM Programming Data Update
0026903100 JUN 95 Repair Manual - Microfiche Update
IDC1017957 JUN 95 Service Information - Updated TIS Software
0410954230 JUN 95 Special Tools - Breakout Box Adapter Lead
6102954200 MAY 95 Electronic Immobilization System - Parts Information
0427944120 MAY 95 Special Tools - E36 Compact
6502954168 APR 95 Cruise Control - Set Speed Drops Slightly
IDC002 APR 95 DIS tester Software - Update
0104954209 APR 95 Dealer Communications System - Enhancements
6202954174 APR 95 Instrument Clusters - Transferring Odometer readings
IDC1016 APR 95 MoDic - Software Errors Coding Version 12.0
0040891999 APR 95 Service Information - Microfiche/Diskette Bulletins
0407954197 APR 95 Special Tools - New Engine Tools
7201954178 APR 95 ZAE Airbag Systems - Servicing
5108944129 MAR 95 Dash - Warping Above Center Vent
0428944128 MAR 95 New Special Tool - MoDic(R) Replacement Cable
0405954166 MAR 95 Tools - Infrared Transmission Device (IR)
0404954155 FEB 95 Electrical Connector Kit Supplement
6101952144 FEB 95 Electronic Immobilization System - Description/Operation
IDC1015 FEB 95 MoDic(R) - Software Update V12.0
IDC1014 FEB 95 MoDic(R) - Updated Software V5.1
0403954154 FEB 95 Portable Telephone - Special Tool
0203954170 FEB 95 Winter Tire - Recommendations Brochure
0202954164 FEB 95 Winter Tires - Recommendations Brochure
4101954150 JAN 95 Body - Structural Adhesives
6204944127 JAN 95 Central Locking System - FC 5 & 13
0003954149 JAN 95 ETM Manual Supplement
IDC024 JAN 95 MoDiC(R) - Diagnostic Software Update
IDC023 JAN 95 Service Manual - Updated CD for TIS
6402944082 DEC 94 A/C Compressors, R-12 - Spare Parts Discontinued
0426944118 DEC 94 Tools - New Frame Anchoring Adapters (Celette)
6106944069 DEC 94 Turn Signal/Hazard Flasher System - Erratic Operation
6403944095 NOV 94 A/C - Fault Codes 34/61 Mixing Control Wheel Mixing Flap
0423944094 NOV 94 Door Lock Plate Cover - Removal Tool
0425944115 NOV 94 New Special Tool For Recall 94V-151
6504944049 OCT 94 Cellular Phone - CMT 2000VR Number Memory
6201933753 OCT 94 Fuel Gauge - Inaccurate Fuel Tank Level Troubleshooting
1203944020 SEP 94 Electrical - B+ Lead in Engine Compartment
0404943981 SEP 94 Special Tools - Simulator Tool For Bosch Oxygen Sensors
0002942141 AUG 94 New Systems Overview
3202944041 AUG 94 Starting - Ignition Key Cutting Services Caution
3301903168 JUL 94 Rear Axle - List of Ratios Updated
1303933826 JUN 94 MIL ON - DTC 12 or 73 (Throttle Position Sensor)
6411933929 MAY 94 A/C - Oil Charge Procedure for R12 & R134a
5101943943 MAY 94 Central Locking System - Multiple Malfunctions
3301923667 MAY 94 Differential - Final Drive Synthetic Oils
7202933794 MAY 94 SRS - Collision Repair Guidelines
5103943982 MAY 94 Trunk Lock Actuator - Linkage Comes Loose
0024891938 JAN 94 0024891938 - 01/01/94
3401932136 SEP 93 Brakes - Automatic Stability Control W/ Traction Control
0413923561 MAY 92 ELO Diagnostic Cable - New Special Tool
6401922121 APR 92 A/C Systems - New HFC-134A Description
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
5113913416 NOV 91 Central Locking System - General Information
6401912116 JUN 91 A/C - Integrated Regulation
0001912113 JUN 91 New Model General Information
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
ATRATB8930 OCT 89 A/T - Math Part II
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
1203891838 MAR 89 Engine - High Pressure Steam Cleaning Warning
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
this is from alldata.com
sorry i didnt post it. i assumed if i found it any1 can.
Old 11-17-2005, 05:17 PM
99rx300 99rx300 is offline
Hooah
Send a message via AIM to 99rx300 Send a message via Yahoo to 99rx300
Mein Auto: rx300, 97 740iL
so can we go in and get these fixed? my ign switch is jacked up too.
Old 11-17-2005, 07:21 PM
woody underwood's Avatar
woody underwood woody underwood is offline
ZHPper
Mein Auto: 330ciZHP Mini Clubman VUE
Didn't see the free clutch in there. (On the 318)
Old 03-05-2006, 12:59 PM
Acer Acer is offline
Mein Auto: 96' 318iS
what can you do with all these recalls? can i go to the dealer and get these things done for free?
Old 03-07-2008, 12:32 PM
Dr.EwsM3 Dr.EwsM3 is offline
Mein Auto: 95 M3, AA SC & 97 540i/6
bump
Old 03-07-2008, 04:23 PM
jordan325 jordan325 is offline
Driver
Mein Auto: 325i
Yeah, how do the recalls work? Is there a certain time limit in which the dealer will repair the issues?
Jordan325
Dmd. Swartz e36 325i | Host Daddy reviews
Old 12-02-2008, 02:09 PM
IppoJ IppoJ is offline
Mein Auto: E65 750i
I think Alldata pulled all the BMW TSB info from their site. I tried to pull up the list but, no joy.
The dealer will not fix them for free, it just gives them a proven fix for a known problem.
Old 12-02-2008, 03:17 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Yes. Nobody is getting any of this stuff fixed for free.
You guys crack me up.
Old 12-02-2008, 03:41 PM
Bearybear1 Bearybear1 is offline
Mein Auto: E36 cabriolet
LOL if your cars lasted 13 years think your self lucky but that list is like having a judge reading all the resons u should go to prison lol scary lol if its not fixed why break it! lol hic i love bourbon and ice..............
Old 12-02-2008, 06:19 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
If it's not fixed why break it? LOL Awesome.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-02-2008, 07:22 PM
Edev's Avatar
Edev Edev is offline
BMW Genius @ BMW Portland
Mein Auto: M Coupe
HAHAHAHAHAHA.
AHHHHHHAHAHHAHAHA. oh mannnnn. this is way funny. especially since the car is around 14 years old. im not sure how you used the word "dealer" and "free" in the same sentence.
BMW Genius @BMWPortland.
2000 Z3 M Coupe
Old 11-14-2009, 05:49 PM
minaloveu minaloveu is offline
Mein Auto: 318 i convertible
may i ask something , what is the recalls , what can u do with it , iam kind of new with bmw , anyhelp?
Old 11-14-2009, 05:54 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
Go Here
I Am The Machine
A) They don't mean anything to you, you can't do anything with these recalls as they're way old.
B) Yeah, help would be called searching and reading everything you can, starting with "How To Ask Smart Questions" on the main page.
// Chad //
You're a derbanana
Old 11-14-2009, 05:59 PM
ok thx , i have a question , somebody ried to break into my cars he missed up me passenger and driver door locks , the dealer wants 1200$ to change the locks plus i will have another key fo the new locks , can i buy them from any junkyard and install them , and can i install in keyless entry or alarm system , will that help and how much is it or what kind will be good with bmw , since i called the dealership for that and they said they can't install it in my car , so any help out thre?
Old 11-14-2009, 06:01 PM
I Am The Machine
Wrong thread for this dude. Go make a thread or bump one that's related to the topic. Like I said, READ THE "HOW TO ASK SMART QUESTIONS" sticky before you post any more. If you're new to forums which it seems you are, go read up on how to use forums as well.
// Chad //
You're a derbanana
Old 11-14-2009, 06:03 PM
dude why are u being a smarta$$ u don't have to answer me u know u got somekind f problem
Old 11-14-2009, 06:21 PM
I Am The Machine
If you read the thread I referenced, you'd know. It's simple - you're posting completely off the topic of the thread. You need to go find a similar thread to the problem you're experiencing, or if necessary start a new thread. It's not complicated.
// Chad //
You're a derbanana
Old 11-14-2009, 07:18 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
So here's an idea.....on or about 4/1 we repost the list of E36 recalls with a notice that if you take the list to your local BMW dealer along with your E36, they'll fix all of the issues for free. Nobody would get anything fixed but it could be fun to watch!
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 11-14-2009, 07:34 PM
E36Dinan_801's Avatar
E36Dinan_801 E36Dinan_801 is offline
search is your friend
Mein Auto: Dinan 325I
Eff that. If BMW made recalls on parts they should still honor the recall if it hasnt been fixed yet. I used to have a 1989 nissan 240sx and someone posted the recalls for that.
So... I took my car in later that week and sure enough even after 19 years they special ordered and fixed the parts for the recalls I brought up. FOR FREE. Just like I told em.
They did however say "well we also noticed you have a small coolant leak and this and this and this and that.. want us to fix those?"
I said um.... no. printed up my reciept and walked out with new dealer installed parts with a ticket that read $0.
The point is, if there was a big enough problem to issue a recall on parts especially ones like these:
they are still problems today if they havent been fixed. I would guess you could go in and get these things fixed at no charge.
Just go in and tell them about the recalls, make them look it up, and ask them if its gonna cost you anything. If they say yes, walk away. simple as that.
EDIT: Holy christ. Just saw the original post date.... Talk about revival from the dead. jesus
LOOKING FOR SOME NOICE STYLE 5`S PM ME!!!
Member of the Official Secret Bimmerfest Text Club
Old 11-14-2009, 09:00 PM
I Am The Machine
OK dude, you go try that. Hell, manufacturers aren't even held responsible to begin recalls on cars older than 10 years old even if a brand new major problem is discovered. They're not gonna perform a recall the owner at the time should have brought it in for when they were notified.
// Chad //
You're a derbanana
Old 11-14-2009, 09:01 PM
dc_wright's Avatar
Usually anything with the SRS they'll fix it as long as the car is still on the road and they can still get the parts, particularly if it was part of a consent agreement with the NHTSA. CAT convertor and the emissions control computer are 7 years mandatory warranty by federal law. Anything else is open unless there is a class action suit that's been settled on it and then those typically have a limited period for action.
Similar Threads
My E36 v. E46 thoughts (very long) JST 1M & M2 49 12-18-2006 12:45 PM
95 E36 Convertible rattle 95RedE36Conv E36 (1991 - 1999) 3 04-11-2005 12:14 PM
E36 95 M3 rims/tires help please 18" RupTheKid Tire Rack's Tires, Wheels, Brakes & Suspension 4 02-17-2005 02:08 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
Any 530i Engine Recalls? DANABANA 5 Series 3 01-22-2004 09:07 PM
