Oil Light stays on after ignition is turned off - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 07-11-2005, 06:06 AM
sunnykk's Avatar
sunnykk sunnykk is offline
24/7 Bimmer Addict
Send a message via MSN to sunnykk Send a message via Yahoo to sunnykk
Mein Auto: 05 330i ZHP
THis is wierd and happened twice. The oil light stays on (Amber color) after I turn my ignition off and take off the keys. After this happened, I turned on my ignition and turned it off again and everyting was normal (The light went off) Any one else seen this on their car?
Sunny Khatkhate
2005 Silver Grey 330i ZHP, ZCW, 6MT, Blk Lthr, Xenons,
66 K Miles (Mar05 - Jan12)
OEM: Alarm, Universal Trainsmitter, I-Pod, Mud Flaps; After Market: Clear Bra, 3M-Tint-27%, Passport 8500X-Hard Wired
DIY: Euro Tray, Al Foot-pedals & Foot-rest, ULO Front & Rear Clears, Clutch Stop, De-badged
Old 07-11-2005, 06:11 AM
Patrick Patrick is offline
Banned
Mein Auto:
Same thing has happened to me. I added some oil and everything was fine after that.
Old 07-11-2005, 06:27 AM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
Have you bothered to read your owner's manual?
How many posts could a repost post if a repost could post posts?
Old 07-11-2005, 06:49 AM
sunnykk's Avatar
24/7 Bimmer Addict
No actually I haven't. I didn't think that a brand new car should have a light coming on. If there was some kind of a problem, it should stay on (if I needed oil or something). The fact that its coming on only sometimes and goes off immediately, I thought that this might be some gliche in the system. Since you mentioned, I will see if the owner's manual says something about this.
Sunny Khatkhate
Old 07-11-2005, 07:08 AM
My TARDIS is a BMW
Mein Auto: '02 325i
Yes it most certainly does, as that is how I found out what it means when it happened to me. Your first step for any problem where a light comes on is to consult the owner's manual. But if you want to insist on not reading it first and want to ask about it here, then you first step here should be to search first, ask second.
Old 07-11-2005, 07:10 AM
Banned
Mein Auto:
How many miles have you driven?
My oil light came on after about 8,000 KILOMETERS. It came on again about 10,000 km later (after the first oil change).
The manual will cover this issue.
Old 07-11-2005, 08:56 AM
edsmax's Avatar
edsmax edsmax is offline
I shift my own gears!
Send a message via AIM to edsmax
Mein Auto: Orient Blue 01 330i Sport
I find it disturbing how many car owners do not read their owners manual. Also, they should consult this manual before posting on a forum...
Mods: BMW OE Clear corners, OE aluminum ///M shift knob, GruppeM CAI, UUC Clutch stop
Old 07-11-2005, 10:16 AM
sunnykk's Avatar
24/7 Bimmer Addict
Let me tell you exactly what's happening with my oil indicator light. It does not come on when I am driving. After I stop the car and turn off the ignition, it comes on (amber color) even after my ignition is shut off. After this happened the first time, I turned the ignition on again, the amber color changed to red and then it went off. After about 5 seconds, I turned off my ignition and everything was normal.
It has never come on when I am driving and that's why I don't think it is a problem with low oil.
My owner's manual does not say anything about this. It says that if the light comes on, it means there is low oil pressure. My light is on after my ignition is turned off and the keys are out of the ignition. I thought that was not normal and wanted to see if anyone else had a similar situation.
Car is about 4000 miles old.
Sunny Khatkhate
Old 07-11-2005, 10:18 AM
My TARDIS is a BMW
Mein Auto: '02 325i
Well, then you are in the wrong place because it seems that none of the newb's (and several of the old timers) post first (and repeat questions at that) and only look at the owner's manual when one of us ask why they haven't done that yet.
Old 07-11-2005, 10:30 AM
My TARDIS is a BMW
Mein Auto: '02 325i
Either they have removed that section from the manual (possible, but I seriously doubt it) or you missed it.
From the manual for my '02 325i:
Old 07-11-2005, 10:41 AM
Z4phillygirl's Avatar
Z4phillygirl Z4phillygirl is offline
Happiness is....
Mein Auto: Alpine White '05 Z4 2.5i
My oil light came on a week ago and it just needed more oil. Took about a quart. I have about 7000 miles on my new Z4. I think the same thing happened within the first 7000 miles with my 2001 325i.
Old 07-11-2005, 10:51 AM
sunnykk's Avatar
24/7 Bimmer Addict
I probably missed it. I will go check again after work and fill up some oil. Thanks for your post.
Sunny Khatkhate
Old 07-11-2005, 11:02 AM
My TARDIS is a BMW
Mein Auto: '02 325i
Now, if you find out, using the proper dipstick check routine, that the oil level is fine, you could have a bad oil level sensor (they have been known to be defective straight from the factory).
Old 07-11-2005, 11:17 AM
edsmax's Avatar
Very true. Although based on the fact that the original poster does not remember seeing the clip you provided from the owners manual, it is probably just low on oil. My 330 seems to "eat" a quart of Mobil 1 every 3500-5000 miles religously.
Old 07-11-2005, 03:31 PM
eston eston is offline
Send a message via AIM to eston
Mein Auto: 2001 330xi
As does mine.
Old 07-11-2005, 04:16 PM
sunnykk's Avatar
24/7 Bimmer Addict
Wow, I am not used to this. My other car is a Accord that I have had for 6 years now and I have never had the oil level go low. I was a little surprised when I saw the oil light. But it looks like that is normal for the oil level to go down for a 330i. Thanks for all the replies and I will make sure that I do my searches before I post.
Sunny Khatkhate
Old 07-11-2005, 04:44 PM
LDV330i LDV330i is offline
Mein Auto: 2014 335i M-Sport EB
sunnykk, did you trying doing a search on BF?
This issue has bee repeatedly discussed in many threads. I recall responding to an indentical thread just last week.
To save you some time, there are 2 issues:
  • Around 5,000 mile mark some cars just seem to have the light come on when the oil level appears to be correct. That happened to me but after of couple of weeks I did end up having to top of the oil level.
  • The other possibility is that the oil level sensor may be contaminated.
Old 07-11-2005, 05:53 PM
sunnykk's Avatar
24/7 Bimmer Addict
Thanks for the heads up. My bad for not doing a search.
Sunny Khatkhate
Old 07-11-2005, 06:01 PM
machmeter's Avatar
machmeter machmeter is offline
Adolescent On-Call
Mein Auto: 330i
Originally Posted by eston
As does mine.
me 3.
Old 07-11-2005, 06:13 PM
SpeedFreak!'s Avatar
SpeedFreak! SpeedFreak! is offline
Certified Organic Fanatic
Send a message via AIM to SpeedFreak!
Mein Auto: 2004 330i ZHP & 2005 X5
Just so its perfectly clear... it is perfectly normal for your car to need about a quart of oil at this point. I am at 8000+ and have added oil twice. BMW uses oil as a part of there Premium Fuel Octane Enhancement Mixture... J/K ... seriously... when you see the Amber oil light after turning off the car... this is your car's polite way of letting you know it is suddenly time to check your oils level... and that you are 3/4-1 quart low...
Since you're at 4000 mile... I would have to say that the sensor problem (if it was a bad unit) would have reared its ugly head by now.
Yeah... so I'm a junkie. Isn't that Step One?!
Old 07-11-2005, 06:34 PM
icky's Avatar
icky icky is offline
Send a message via MSN to icky
Mein Auto: 2006 325xi
mine came on once due to a faulty oil level sensor.
then just came on a few days ago and it was low bout a quart. these cars love their oil.
so if its low, add oil, if its not, see dealer!
Old 07-11-2005, 07:03 PM
johnnygraphic's Avatar
johnnygraphic johnnygraphic is offline
Mein Auto: 330i Performance Package
I've always driven Japanese cars which, by nature, do not drip, eat, burn or otherwise consume oil at all. I could probably go 20k miles without touching the oil.
I was shocked and stunned when I saw the yellow light in my new 330i. When I parked, I pulled out the manual and found out that I was low on oil. I pulled into the local dealer (about 5 miles away) and had them top off the oil. Very nice & felt kind of special knowing that they're doing something for 'free'.
The next time it happened, I just rolled into a auto parts joint and bought a few quarts of Castrol. It's relatively cheap and takes a whole lot less time to top off than going into the dealership and wait for assistance-even if it is free.
It seems that it is a 5k mile oil top off kind of thing for me too.
Sunnykk-Just keep a quart or two in your trunk & top it off when the light comes on & you'll be fine, or you can pay a friendly visit to the dealership if you so incline.
Johnny
Old 07-12-2005, 06:45 AM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
I assume you used the synthetic Castrol? Some say the Castrol you can buy at the autoparts store is "different" than the Castrol from BMW... Personally, I carry a bottle of BMW oil with me, in my spare tire well, for just such a situation... in fact, BMW offers a bottle holder for those who are overly fastidious...
http://leatherz.com/Merchant2/mercha..._Code=Interior
Old 07-12-2005, 07:01 AM
norihaga's Avatar
norihaga norihaga is offline
Achtun*, Spitfire!
Mein Auto: '93 E30 318is Touring
Now THAT'S a piece of information they didn't include in the manual.
Old 07-12-2005, 07:03 AM
My TARDIS is a BMW
Mein Auto: '02 325i
True, but the manual does have the initial bit of info that the original poster was looking for.
Similar Threads
take a look at this oil filter! ketchup E39 (1997 - 2003) 463 12-29-2015 05:44 AM
Oil change Guest84 Off-Topic 21 08-12-2014 03:30 PM
The same old code again!!!! kenkorsak E36 (1991 - 1999) 6 01-21-2014 04:58 PM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 04:52 PM
Oil Light petah50 3 Series & 4 Series 12 12-30-2004 01:05 PM
