Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 07-12-2005, 11:22 PM
SW1 SW1 is offline
Mein Auto: M5
Clutch issues
I recently purchased on 02 with 15k on it. Clutch has been repaced twice and is problably in need of a 3rd, snce I got into it a little when first purchased. I added the Dinan signature exhaust system and differential. Since the clutch is a weak point, any ideas on upgrading it? A local shop here, says they can have a new OEM stripped and replaced with Kevlar, a $300 up-charge. Has anybody heard of this?
Also, has anybody used the Valentine mirror or GPS radar detector systems sold by beastmotorsports?
Old 07-13-2005, 12:42 PM
KevinM's Avatar
KevinM KevinM is offline
Mein Auto: '02 M5, Sterling Gray
Welcome to the board!
There is more information on M5 clutches that can be imagined at m5board.com; I recommend you go there and do a search.
Most members there who have upgraded their OEM clutch have used one of UUC larger varieties, of where there are 3 stages to choose. Most of these members are very happy with the upgrade (athough some complain of a slight ticking noise at idle).
An OEM M5 clutch (as weak as it is) really should last about 50K miles or longer if you don't let it slip under hard acceleration, so I think the most popular replacement for the OEM clutch is another one! If you plan to track the car, drag race alot, or are just hard on the clutch, go for a UUC setup.
Kevin
2016 F80 M3 Mineral Gray/Golden Brown (ED 6/3/16)
ED delivery thread: http://f80.bimmerpost.com/forums/sho....php?t=1291837
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
1999 Mercedes ML320 (hauler...)
Old 07-13-2005, 12:46 PM
SW1 SW1 is offline
Mein Auto: M5
Understandable, but is also 3 grand, the kevlar is only a $300 upcharge, bringing total install to $1500, parts and labor. I was checking to see if anyone else had done this. Also, is the UUC any different than the Dinan?
Old 07-15-2005, 12:28 PM
KevinM's Avatar
Not sure about the Dinan question. If anyone has done a kevlar upgrade on an OEM clutch, it will be someone on the m5board site. However, I don't recall ever reading about that in all the clutch related posts I have seen.
Kevin
Old 07-16-2005, 06:49 PM
KevinM's Avatar
You might be interested in this - a M5board member is trying it. Seems like a good compromise to me.
http://www.uucmotorwerks.com/perform...lutches/PO.htm
Kevin
Similar Threads
Problems with my SPEC clutch and their response... Dustine39540 E39 (1997 - 2003) 8 07-30-2014 04:33 PM
2002 M5 Clutch Replacement Issues RakNaks 1M & M2 2 04-04-2005 02:36 PM
$#%#ing Clutch! Any ideas? STEVE46 3 Series & 4 Series 2 09-06-2004 12:12 PM
E39 530i clutch action question* roadie 5 Series 9 08-27-2004 01:39 PM
