E36 (1991 - 1999)
Old 07-18-2005, 11:14 AM
dinscoe dinscoe is offline
Mein Auto: where do i live?
Unhappy bmw 325i fuel gauge problem
Microsift Sans Serif
HELP. Just filled my gas tank yesterday. After that the fuel gauge now reads "E".
What do I need to do to fix it? Any idea of cost? Can you do it yourself? Had an oil
change done the same day at Jiffy Lube and they put dry gas in the lines, would that
cause it? Thanks.
dinscoe@cox.net
Old 07-18-2005, 11:48 AM
GreenBeem93 GreenBeem93 is offline
Mein Auto: 1993 325is
I have the same problem...hope someone can help
Old 07-18-2005, 11:55 AM
xspeedy's Avatar
xspeedy xspeedy is offline
mmm... carbs!
Mein Auto: 2007 E90 335i
Likely a faulty sending unit.
Old 07-18-2005, 12:05 PM
bauerhockey66 bauerhockey66 is offline
Mein Auto: 95 E36 M3
Try not topping off the tank after you fill it up, Ive heard that can mess up the gauge for some reason. But the sending unit could be bad also.
95 Dakar Yellow E36 ///M3 - 69,000 miles, no really, seriously.
Old 07-19-2005, 04:21 AM
my_e36 my_e36 is offline
Mein Auto: e36 323i coupe
sounds like a fuel sender unit.
I heard there's 2 sender units in the tank, 1 take care of the top half and the other for the bottom half.
If you try to Google, you will find something about re-soldering the connections at the sender unit.
BTW, as you will be working so close next to your fuel tank, don't do anything stupid!
Old 07-19-2005, 08:27 AM
The fix for mine was simple......
when you are driving, lock your doors.
I think it has something to do with the fuel door acuator, it reads better when it is locked
Old 08-24-2005, 02:28 AM
electro5 electro5 is offline
Mein Auto: bmw 318i
Fuel level low
I had the AA out to my bmw as it wouldnt start. He traced the fault to a sticking fuel pump. He did some tests with the wiring and now my fuel level gauge shows empty( with the warning light on also).
I have fitted a brand new pump unit which includes a new sender, gauge still showing empty. The gauge was working fine before the AA man messed about. The sender unit off the old one is also working fine.
Does anyone know if there are additional fuses for the gauge, although there is 12volts at the sender unit.
Any help appreciated. Ken
Old 08-29-2005, 03:15 AM
obd2guru obd2guru is offline
Mein Auto: BMW 528i MB e55 amg
http://www.bimmerfest.com/forums/sho...d.php?t=106001
If everithing fails try the hammer. obd2? obd2guru.com
Old 12-03-2012, 10:36 AM
monstersales monstersales is offline
Mein Auto: 2001 330 cic
Question monstersales
1999 323 sedan changed the feul pump w sending unit still shows empty w low fuel light on???
Old 12-03-2012, 10:43 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Obviously the first thing to do is go back and check your connections.
1998 BMW 328is
1966 Pontiac GTO
Old 12-03-2012, 04:24 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Bumped a seven-year-old thread to post his first question....but at least he searched!!!!
monstersales, welcome to the fest!
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 12-03-2012, 04:45 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 BMW 325i Convertible
cause it? Thanks.
dinscoe@cox.net
I had the same problem...this is what someone told me:
With ingnition off, pull fuse 46, turn ignition on and back off, reinstall fuse. Turn ignition on and see if it has cleared. It worked. The suggestion said if 46 didn't work, try the same procedure with #31. It depends which one is dash displays for your model. My 1995 325i liked #46.
IT WORKED beautifully for my 1995 325i vert. It is also suggested, whenever you fuel-up, don't just turn ignition off...remove the key to keep from having a repeat.
Old 12-15-2012, 06:27 AM
tigermanalan tigermanalan is offline
Mein Auto: e46 323i coupe
my cars is 1999 323i coupe wats happening is fuel gauge not accurate abs traction and hand brake light on spedo and mpg going funny to
Old 12-15-2012, 06:42 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Try the E46 section.
That's where Flavour Country is.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 12-15-2012, 07:10 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
Why he has an e36. "1999 323i coupe" is really a 99 323is he just wrote it wrong.
Alex//1999 323is - power e46 m3 seats, style 43 rims, 328 exhaust
For sale black e46 interior parts
“Dude, dolphins are intelligent and friendly!” — Wendy
“Intelligent and friendly on rye bread, with some mayonaise.” — Cartman
Old 12-15-2012, 07:36 AM
jonesin's Avatar
The Canadian Prick.
I was of the impression with the gentleman's impeccable grammar that his word must be gospel.
Similar Threads
MASTER LIST: dealers who like to do ED? pac European Delivery 297 11-07-2007 02:29 PM
BMW ConnectedDrive: ChrisTO General BMW 12 11-08-2005 06:41 AM
THE NEW BMW 1 SERIES with Photos (BMW Press Release) pixA4 E82 / E88 1 Series (2008 - 2013) 27 09-29-2004 06:50 PM
BMW Model Year 2004 Changes (BMW NA) WAM General BMW 1 08-06-2003 11:13 AM
Fuel Gauge Problem? MC 3 Series / 4 Series 31 06-04-2003 08:53 PM
