Old 07-19-2005, 07:36 AM
azman818 azman818 is offline
Mein Auto: e30m40, e36m52
Bluetooth In Carphone Pre Wired E39
THIS E39 IS FROM JAPAN WHERE FM FREQUENCY IS 76-90MHz.
OUTSIDE JAPAN WHERE FM IS 86-108MHz MOST PEOPLE INSTALL BAND EXPANDER.
I'M THINKING OF USING A BLUETOOTH PHONE WITH FM TUNER.
IF I RETROFIT BLUETOOTH INTO THIS CPT7000 PRE WIRED E39 2001
WILL I BE ABLE TO GET PHONE RADIO BEYOND 90MHz INTO CAR.
ie. WHILE MY E39 RADIO WILL NOT TUNE PAST 90MHz, I CAN TUNE TO 95MHz
ON THE BLUETOOTH CONNECTED PHONE AND HAVE IT HEARD ON THE CAR STEREO.
WILL ANY BLUETOOTH EXPERTS PLEASE GIVE SOME ADVISE. THANKS.
Old 07-19-2005, 08:10 AM
King's Avatar
King King is offline
Mein Auto: X5 4.4i
I have not heard of a blutooth phone being used through the FM tuner. Your bluetooth setup (BMW bluetooth ULF module or aftermarket module) should have nothing to do with the FM tuner. The BT system will only tie into the radio to mute audio when a making a call.
Old 07-19-2005, 08:26 AM
THANKS, KING
NO NO NOT BLUETOOTH THRU FM TUNER
IT'S BLUETOOTH PHONE WITH BUILT-IN FM RADIO THAT CAN TUNE BEYOND 90MHz.
SAY, YOU NOT MAKING A CALL, BUT TURN ON THE FM ON THE BLUETOOTH PHONE
CAN YOU THEN GET THIS OUT ON THE CAR STEREO THRU THE BLUETOOTH CONNECTION?
Old 07-19-2005, 11:05 AM
SRFast's Avatar
SRFast SRFast is offline
Mein Auto: 2003 BMW 530i
Originally Posted by azman818
THANKS, KING
Please turn off CAPS LOCK.
No. Only wireless phone services are supported on the BMW BT ULF. No special phone features (MP3 player, FM radio) is supported/acessible via the BT ULF.
Hope this helps....JL
2003 530i 5spd/SP/PP/CWP/PDC/RSAB/Xenons
Old 07-19-2005, 11:23 AM
JL, sorry, the CAPS annoying.
Thanks for your info. Even the latest version BMW ULF module
do not support extra phone features MP3/radio?
Can I AUX IN while phone is snap-in?
(I do seem desperatae, right?).
Old 07-19-2005, 12:16 PM
King's Avatar
Mein Auto: X5 4.4i
How come you are not able to get FM reception through the car radio? Did you import your car into Japan?? If so, you can buy a new radio module for Japan and replace the one in your vehicle.
Old 07-20-2005, 08:07 AM
SRFast's Avatar
Results of tests using a Motorola V635 GSM phone with built in MP3 player, plug in headset and BT headset:
1. When the plug-in headset is connected, BT connection cannot be establiahed/activated to BT headset.
2. When the phone's MP3 player is playing (audio from speaker) and the BT headset is switched on, the BT connection is made, but the MP3 audio is cut off. I surmise audio is devoted to the BT session. MP3 audio is resumed when the BT session is terminated.
Based on these results, it appears only ONE audio output is allowed.
Similar Threads
Bluetooth Code for pairing. bmwxdrive X5 E53 (1999 - 2006) 5 03-05-2005 08:08 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
Stealth Bluetooth installation in 2003 E39 DZeckhausen 5 Series 23 09-26-2003 11:39 AM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 10:26 AM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 05:46 PM
