Old 07-19-2005, 10:23 AM
david540i david540i is offline
Mein Auto: 97 bmw 540i
97 540i A/C Noise
i get this werid noise like a fan is hitting against something when I first turn on my A/C. But it doesn't look to be a raditor or a/c fan. This happens for just a few seconds after turning it on. Also happens at times depending on egine rev. The higher I rev the louder or faster the "fan hitting noise" is.
The A/C blows cold at times too. If the car is in motion with the engine revs up, theres no problem. But if im at a red light, after a few seconds....warmer air is coming through the vents.
Can anyone PLEASE HELP or HAVE ANY SUGGESTIONS?
DAMN TEXAS HEAT ISN'T HELPING
PS: after examing the noise it seems to come from the lower left front of the E39 540i engine.
Old 07-19-2005, 01:44 PM
crazy4dss crazy4dss is offline
Mein Auto: 1997 BMW 540I
It sounds like your having a compressor issue. Only the compressor would rev up or down as the engine does. Check to make sure when the clutch on the comp. engages its not hitting anthing tha might be loose around it. If you can see anything externally then your problem is internal but it would the compressor
Similar Threads
'97 540i Front End Noise Action1 E39 (1997 - 2003) 8 09-24-2014 11:06 AM
Hissing noise from the A/C? rs2k General BMW Questions 18 07-06-2014 10:39 PM
what are the recalls on 95 e36?? nads12345 E36 (1991 - 1999) 28 11-27-2013 01:10 PM
A/C noise PLEASE HELP!! david540i E39 (1997 - 2003) 7 05-22-2006 07:54 AM
Any 530i Engine Recalls? DANABANA 5 Series 3 01-22-2004 09:07 PM
