Towing Z3 on a trailer - how to tie down? Ron? - Bimmerfest - BMW Forums
Old 08-11-2002, 05:39 PM
mijgilbert mijgilbert is offline
Mein Auto: 2001 Z3 3.0i
What's the safest way to tie down a Z3 to a car trailer when towing it? I'm going to tow my Z3 about 7 hours to Watkins Glen - I'm sick of putting all of the miles on the car to and from the track. Anything else I should be aware of? Ron, you are the guru on lifting the cars - how about strapping them down?
Thanks,
Mike
Old 08-11-2002, 05:47 PM
Randy Forbes's Avatar
Investigative Tinkerer
If it were me, I would use those nylon web straps that go over the tops of the wheels/tires.
If your car is (significantly) lowered, you may encounter trouble getting them over the top of the tires.
I used to always tie my Healey down at the front with chains and use a load-binder to tension it at the rear. This method is tried and true.
Whatever you do, DO NOT LEAVE THE CAR IN GEAR while the trailer is in motion.
The constant rocking back and forth on a single pinion tooth in the differential can cause it to fracture.
Ask me how I know...
Randy Forbes
2001///M Rdstr Steel Gray
Old 08-12-2002, 12:22 PM
D///Mill D///Mill is offline
Send a message via AIM to D///Mill
Mein Auto: 2000 Z3 "///M coupe"
Arrow Trailer towing your Z3 ... INFO
For more info on this topic, go to:
http://bimmer.roadfly.org/bmw/forums...=966785&page=1
FYI
