E60 (2004 - 2010)
Old 07-22-2005, 02:21 PM
Alleninfolsom Alleninfolsom is offline
Mein Auto: 00 528i/04 530i
Angry Run flats and dealer info
I recently replaced the tires on my 04 530I. Since the selection of performance tires in "run-flat" configuration is limited(and well-overpriced) I opted for a set of really sticky, great-handling Michelins. Problem: the computer tells me I have a flat tire....all the time. My friendly BMW dealer tells me that the car MUST have run-flats or "the computer will become screwed-up" and I should have him(the dealer) immediately strip off my brand new Michelins and purchase a set of the "proper tires for the car" from him. Sorry, but I have a very hard time believing that the "computer" has superior knowlege regarding the construction of a tire's sidewall. Doesn't the computer simply monitor the air pressure.Period. I need help since the wife is about to take the dealer's advice and throw away about nine hundred bucks worth of excellent meats. Thank you.
Old 07-22-2005, 02:38 PM
Me530's Avatar
Me530 Me530 is offline
Happily Driving
Mein Auto: 2011 550i M Sport
The car doesn't need run flats. There are either two tires that have different air pressure or you need to reset the Flat Tire Monitor, which I think is described in the manual.
Old 07-22-2005, 02:49 PM
AriciU's Avatar
AriciU AriciU is offline
M Enthusiast
Mein Auto: 645Ci
Adjust the pressures then reset the FTM. If it still does it then your dealer has to update/fix your software.
BMW 645Ci
Stratus Grau
Pearl Cremebeige Leather
Old 07-22-2005, 04:34 PM
casper casper is offline
Mein Auto: F10 550i
Your dealer is even more ignorant than mine, and mine is very ignorant.
I have non run flats on my 545 and they are fine (quiet).
The tire sensor monitors the rotation speed of the tires, when a tire loses air it has smaller diameter and it rotates at a different speed.
Just set the pressure correctly and reset the sensor, if it still continues to indicate fkat tire, you may need a newer version. Mine did that originally, it would give me false flat warnings, when I upgraded software the problem was corrected.
Old 07-22-2005, 06:22 PM
Smile
Thanks for the info. How can a DIY reset the flat tire monitor? This blog amazes me.
Old 07-22-2005, 08:08 PM
Me530's Avatar
Happily Driving
From the manual (2005 electronic version):
The initialization finishes during driving,
which can be interrupted at any time.
When driving resumes, the initialization is continued
automatically. When driving with snow
chains or with the compact wheel, do not initialize
the system.<
Control Center, for principle details, refer to
page 16.
1. Open the menu.
2. Select "Vehicle settings" and press the
controller.
3. Select "FTM" and press the controller.
4. Start engine, but do not start driving.
5. Select "Set tire pressure" and press the
controller.
6. Select "Yes" and press the controller.
7. Start to drive.
The message "Initializing" is displayed.
The initialization finishes during driving. Then
the message "Status: Active" appears on the
Control Display again.
Old 07-24-2005, 05:15 PM
motor motor is offline
Mein Auto: 530i 2003
530i tire replacement advise
can someone recommend new tires for my 2003 530i that are not as hard driving/handling as the origional 235/45/R17 conti sport contacts..I am looking for a "softer" ride if possible.
thanks,
Old 07-24-2005, 07:18 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Well, I don't know if these will fit your criteria but I like them a lot:
Goodyear DS-G3
Check out tirerack.com and read up on customer comments for tires and see if you can find what you like there.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 07-25-2005, 08:59 AM
tire suggestion
thanks..I'll check it out
Similar Threads
Run Flats, Clean Wheels, etc. Blueangel Tire Rack's Tires, Wheels, Brakes & Suspension 9 09-13-2005 10:24 AM
Run Flats on a 330xi Blueangel Ask-A-Dealer 2 10-28-2004 08:50 AM
