Old 07-22-2005, 06:44 PM
bmw540i's Avatar
bmw540i bmw540i is offline
Technik Stg 1
Mein Auto: 01 - M62
Performance Intake Manifold
Hi guys, I have a 2001 M62 6speed and I know that earlier year M62's had better intake manifolds and some 740s. Can anyone tell me witch year was the best and what exactly do I need to buy. Is the intake manifold cover the only one or is there a Throttle body involved. Thanks for your reply
Technik ECU I Technik sways I Gruppe M I RD exhaust I O.Z. SP III I UUC evo II I
Old 07-22-2005, 08:05 PM
Brevity= the soul of wit
You could also buy a throttle body, but it's not necessary with an intake manifold. The intake manifold can be from any 4.0 or 4.4 liter V8 from '92 up to '99. You'll have to plug a few vacuum holes (for older cruise control, I think) when you install it depending on the year, but it bolts right up.
Old 07-22-2005, 11:00 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
thought it was only up to 98's since 99's had Vanos and the runners became more restrictive.
Old 07-23-2005, 06:41 AM
Steve D Steve D is offline
Mein Auto: 2000 540i/6sp
I have considered changing the manifold on my 2000 540 to a pre vanos type but I wonder what the drawbacks might be. Why would BMW restrict the air flow with vanos? Perhaps the higher air flow causes driveability problems?
Has anyone tried this?
Steve D
Old 07-23-2005, 07:59 AM
Steve D
I've had a '95(I think) 740 intake manifold on my car for about two years now. Why did BMW do it? 0-60 times and low end tourqe suffered after VANOS was added. Restrict a lil airflow and they're right where the consumer wants. Buuut, as with most automotive compromises, you give one place, you take another. High end power suffers with restricted airflow both in and out- especially in the nether regions of sustained airflow. Also known as high speed runs.
Old 07-23-2005, 08:01 AM
I am always confused. Didn't '99s have single VANOS? I cant remember if they narrowed them then or in 2000 with double VANOS?
Old 07-23-2005, 08:29 AM
rtw_travel rtw_travel is offline
Mein Auto: '98 540i/6
Here is my understanding:
For the 540's. 97& 98 have no VANOS. Single VANOS started in '99 (and I think continued through '03)
All M5's have double VANOS.
For I-6, 97& 98 have single VANOS. Double VANOS started in '99 (and I think continued through '03).
"Single" varies intake camshaft timing. "Double" varies both intake and exhaust.
Old 07-23-2005, 11:21 AM
bmw540i's Avatar
Technik Stg 1
Mein Auto: 01 - M62
What is the intake manifold made out of... Can I polish it for better performance. Thanks guys
Old 07-23-2005, 02:03 PM
tsaros tsaros is offline
Send a message via ICQ to tsaros
Mein Auto: 540i -6 -99
I´t time to sort things out regarding the Vanos issue
No E39 V8 car except for the M5 has dual Vanos.
Cars built from 96 up to 08.98 has no Vanos at all.
Cars built after 09.98 up to the end of production all have single Vanos.
I know that there is a BMW broschure that says otherwise but that is a missprint.
e60 535d -08 mostly stock for now.
My 540iM -6
E39 M5 OEM Wheels and Cross Spoke Composite II 42 18", CDV Deleted, Eisenmann Race 2x76mm,Rogue Engineering Short Shifter (+WSR), Rogue Engineering Camber plates, Stoptech SS Brake lines, Axxis Ultimate, Bilstein PSS9, M60 intake. (Sold)
My old 528i Touring -98
H&R+Bilstein Sprint, E39 M5 OEM Wheels 245+275, CDV Deleted, M50 intake manifold, BBTB (Sold 2005-07-15)
Old 07-23-2005, 03:50 PM
Ohhh yeah.. I think Beewang may have set us straight on that once before. Thanks for the reminder!
The intake manifold is plastic.
Old 07-23-2005, 04:16 PM
Now thats the first bow i have ever gotten, to bad i dident deserve it
Regarding the intake manifold, is it from a M60 engine or a non vanos M62?
My 540iM -6
Old 07-23-2005, 08:52 PM
Mine is from a '95 either 540 or 740. I forget which. And you deserved the bow.
Old 07-25-2005, 05:32 PM
Any DIY´s somewhere or do you have pictures of what to plug and not to plug?
I´m a mechanical carrot so any help would be appriciated very much
My 540iM -6
Old 07-25-2005, 08:06 PM
I didnt take any pics, but install is very straightforward. Just remove A and replace with B. You might have one small opening that doesnt fit with any fitting on the VANOS car (and you've run out) and that'll be the one to plug. We didnt find it till the car wouldn't idle for anything. Started snooping and voila!
Similar Threads
Intake Manifold AlexE46 E46 (1999 - 2006) 0 01-31-2005 03:17 PM
3er Performance Package Announcement RealM3 Ask-A-Dealer 0 01-26-2004 07:57 AM
325i performance in Germany? chrischeung European Delivery 2 03-24-2003 04:55 AM
What bits of the 330i Performance Package are "worth it" to you? OBS3SSION 3 Series / 4 Series 30 03-09-2003 07:59 AM
A Renaissance for the American performance car? JST Off-Topic 3 02-20-2002 11:10 AM
