Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 07-27-2005, 02:47 PM
gwells67 gwells67 is offline
Mein Auto: '67 Mustang
adding bluetooth, assit or no assist setup?
It appears that I can add bluetooth to my car through one of two methods (2005 325cic, no assist or nav) I can get an assist/bluetooth unit (114 or 993) and the antenna OR I can get just the bluetooth unit (389 or 268 or 552) plus the install kit.
The bluetooth + assist option will require taking the car to the dealer to activate (two codes 639 and 633L); the other method will not have this step. Which is the better way to do this for my specifc car? What's the difference in features? I don't think assit will work unless I pay for it. Do both options work with the same phones? Do both options support voice prompts?
FYI-BMW does not make an install kit specifically for my car, but I don't think that matters. My Mic is present in my steering column.
2007 M6 Convertible, Black Saphire, Black Top, Portland Brown Extended Leather, Soft Close Doors, Comfort Access, Heads Up, Enhanced Premium Sound, HD Radio, Sirius Radio, Ipod Interface
2003 Z4 2.5i, Titanium Silver, Black top and interior, Xenons, Heated Seats, Sport Package, Premium Sound, Sirius (Fiancee's Car)
Old 07-27-2005, 03:39 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
The main difference is that all the Bluetooth phones approved by BMW are for use by the factory Bluetooth, not necessarily fully compatible with the Bluetooth ULF accessory.
Do a search and check that the phone model that you want to buy (or have right now) is fully compatible with the type of BMW Bluetooth unit that you will ultimately choose.
You will not be able to get the Assist working because your car does not have the wiring (rearview mirror buttons), the Blutooth feature and Voice Command (-114) will work, though.
Old 07-29-2005, 07:14 PM
rbriber rbriber is offline
Mein Auto: 2004 330i
A couple of other points
Here's my understanding (though others will correct me);
The BT/Assist combo has voice control as an extra add-on part (~$200?).
The retrofit "BT only" ULF module has voice control integral.
Some phones do not work well with the BT only module, in particular the V710 Motorola phone from Verizon, though it can be made to partially work with some versions of the ULF part. Unfortunately there are about 5-6 different versions and details on which ones work (and how well they work) with the V710 is confusing.
It is rumored to be quite hard to find the BT/Assist combo module at dealers for sale as a part, though I have read of people who have found it and had it put in (by the dealer I think).
I would go with the BT/Assist combo, pay for the extra voice control module and have the dealer activate it. It is much more likely work with a wide range of phones and be supported in future years. It will be a higher total cost in $ but probably less in
I have a retrofit BT ULF module (the earliest 552 part number) which I had installed in place of the Assist module which came with my car (2004 330i). It works (with limits) with my V710 phone, but it has its quirks.
Good luck.
Similar Threads
Bluetooth setup and functionality on the 2005 E46 weave E46 (1999 - 2006) 100 11-27-2010 07:38 AM
Bluetooth Code for pairing. bmwxdrive X5 E53 (1999 - 2006) 5 03-05-2005 09:08 PM
BMW Assist, Bluetooth compatability update Fritz 3 Series & 4 Series 25 12-09-2004 11:15 AM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 11:26 AM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 06:46 PM
