E36 (1991 - 1999)
Old 07-31-2005, 02:44 AM
emhc emhc is offline
Mein Auto: '93 318is
Exclamation Check engine light & Transmission Module Light
Hi, I'm new to this board here. The info is awesome.
Got a problem that's come up lately. The lights in and on the car glows and dims and the RPM meter dips down to like 500RPM, when the car is idle. Then the check engine light would flash a few times and then when the CEL stays on the transmission Module Light goes on as well and the car accelerates slugishly. I've been looking through the board and did the "stomp test" to find the fault code and I'm getting 1231, (Battery voltage/DME main relay).
Please help, I don't know what's going on! I checked the battery which was replaced last year and I've got the green light on the thing that says its sufficiently charged?
BTW, I have a 1993 318is.
Old 08-04-2005, 12:06 PM
Alternator
It was the alternator, simple as that. But the darn thing was that the dealership wouldn't fix it unless they did a diagnosis even after telling them exactly what I needed and wanted to do.
emhc
Old 08-05-2005, 06:12 AM
my_e36 my_e36 is offline
Mein Auto: e36 323i coupe
Stomp test will give you some info but not all info. Dealership plug the computer in can see a lot more than a stomp test can. They just want to make sure you car is fully fixed.
If you are adament that is all you need, you might want to go to a normal garage. Save yourself quite a few bucks.
Old 08-05-2005, 12:41 PM
Yup
Realized that that was probably what they did. While they were at it, they also found that the water pump was seeping a bit, do you think I can get away with leaving it for now?
Old 08-06-2005, 06:26 AM
when do you think the water pump will break down?
Old 08-06-2005, 05:55 PM
Don't know
My friend said that if it's not like squirting or leaking rapidly then I can get away with it for now.
Old 04-23-2015, 07:21 PM
Moss.M Moss.M is offline
Mein Auto:
So how did you know it's the alternator, caz I turned on the car was fine then check engine light came on along with transmission control module light, then turned it off, Tried to turn it on again the battery died.
Charged it, turned the car on, then same thing happened.
Got the code 36 battery voltage / DME main relay
Please help & from where should I start
Old 04-23-2015, 10:09 PM
hornhospital's Avatar
D'oh, You Kids!
He knew it was the alternator because he had it tested. You should do the same.
Quotes to live by:
Old 04-24-2015, 12:50 AM
Mein Auto:
Will test it tomorrow & let you what happened.
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
Check Engine Light On captnex E46 (1999 - 2006) 10 05-11-2005 07:53 AM
Rough idle and Check engine light??? dvs7310 3 Series & 4 Series 3 07-16-2004 09:48 PM
check engine light on krazykappy 3 Series & 4 Series 1 07-06-2004 05:27 PM
So I was spinning around on ice in a parking lot... (check engine light) JonW 3 Series & 4 Series 20 02-19-2003 03:01 PM
