E36 (1991 - 1999)
Old 07-31-2005, 08:07 PM
e36bmw328 e36bmw328 is offline
Mein Auto: '98 328IA
Radio--code Wait ???
my radio code displays CODE WAIT after i tried to enter it a few times. the number 2 on my radio doesn't work, unfortuntely my radio code contains it, so after 3 or 4 attempts it showed this display. i need my music! any clues? thanks
Old 08-01-2005, 02:01 PM
ImperialDuckM3 ImperialDuckM3 is offline
Mein Auto: E36's
BMW's radio has a build-in anti-theft. What happen after you car loses power. The radio will display a "CODE", which you must enter correctly. It will give you 3 tries before it goes into "CODE WAIT" mode.
To solve this problem, you must leave the keys and turn it to ACC (don't have to start the car) for at least 1 hour. If you start the car and shut it off, you would have to do it again. So its important if want your radio back.
Disconnecting the power (battery) will not work or unpluging the unit. So you would have to still wait the 1 hour before you will see the "CODE' again.
Good luck
Old 08-01-2005, 07:59 PM
andy325 andy325 is offline
Peace
Mein Auto: '95 325ic 5-spd
Wow, your #2 on your radio doesn't work, man, that sucks.... your choices seem limited to you either fixing #2 or maybe seeing about getting the code changed??
Old 08-02-2005, 05:01 PM
Can you change the code somehow?
Similar Threads
Z3: "CODE WAIT" on radio after entering code? SoCalZ3 E36/7 Z3 (1996-2002) 55 10-25-2016 07:08 AM
Radio Code in 2001 X5 3.0 ? dasco X5 E53 (1999 - 2006) 2 12-30-2004 10:32 AM
Installing Stereo need radio code? Wretchy 3 Series & 4 Series 3 02-29-2004 09:33 AM
Question re: radio code AndDown 3 Series & 4 Series 24 07-19-2003 10:56 AM
