X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
#76
The DIY is great especially the picture for the drain plug, I'd hate to get that wrong. One question I have is do people find they get more fluid out if they raise both the front and back of the car so it is level when the oil drains?
#77
You have to be careful to reset the right one. As you know, the OBC routinely displays the service which is closer to coming due. Not sure which order they present themselves during the reset procedure, could be random, but if you see Inspection Reset? come up you have to decline the reset and wait for Oil Service Reset? to display. (Unless of course you are doing the Inspection yourself too.) |
#79
Good info, will be doing it this weekend.
#80
Newbie Thank You....great photos tell a big story to a little project. Thank you again.
#81
Here are my contributions to this thread: 1. Raise the vehicle but level it in order to get the most used oil out of the pan. 2. Use only LL-01 approved oils. The OP used Mobil 1 5w-30 which is not LL-01 approved. There is a difference especially for proper operation of VANOS. 3. Do not use LL-04 oils, these are not to be used in US in gas engines due to the high sulfur gas we have in the US. LL-04 is only to be used in diesel engines.
2007 530 xi 2004 X3 3.0i 2006 530i |
#82
Oil change pumps
I recently completed my first DIY oil change on my '06 X3 and I thought I'd share my experiences.
I used to hate the big mess that resulted from changing the oil on my Land Rover Discoveries, as the side-mounted drain plug created an oil-fountain that was hard to predict, and the spray distance difference from start to finish was larger than my collection pan's diameter. A real pain. So, I recalled I had an electric oil change pump I purchased a while back for my boat, but never installed. It's a Reverso brand, reversing DC oil change pump. I mounted it on the lid of a 5 gallon bucket, and put a cigarette lighter plug on a long wire. It looks a lot like Reverso's ready-made unit: ![]() With a fairly small diameter dip tube, it sucked all of the oil out in about 6 minutes. After changing the filter and refilling the engine with oil, I was able to reverse the pump to put the waste oil back in the containers. I don't know that the dealer will take it back, but I know Walmart will. I also have a Tempo Oil Boy fluid extractor on my boat, that a friend gave me. I works beautifully! I changed the oil in my sailboat's little diesel in about 15 strokes of the pump, all 4 quarts. The tool really works well, handles well, and stores well. It's also quite cost effective. http://www.tempoproducts.com/2004/pump.html While it appears Tempo has discontinued the product, West Marine sells the exact same item for $80. http://www.westmarine.com/webapp/wcs...classNum=10440 When it was generally available as a Tempo product it could be had for about $55. Oh well! Still a lot less than an electric pump, which costs over $400. http://reversopumps.com/oil-change-s...cket-gp-311bkt Any of these will make the oil change much quicker, easier, safer and cleaner. The convenience will mean you won't put it off! Now I'll actually change the oil in my lawn mower, chipper, air compressor, etc., etc. For oil, I see the OP used Mobil 1 5W30. While the recommended BMW High Performance Synthetic Oil is 5W30, the recommended substitutes do not include the OP's choice, but rather, for Mobil 1, the 0W40, per this excerpt: "BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market:
Here's the BMW doc: http://www.bmwusa.com/Standard/Conte...ngineOils.aspx I used the BMW oil at $8.52 from the dealer. The dealer supplied filter kit was $18. Next time, it's Mobil 1 0W40 from Walmart at $6.54, and a filter from my local NAPA store for $12. - a $13 savings. Further, I don't think it's necessary to change the filter housing O-ring every single time. If you remove the sump plug, then certainly use a new copper crush washer. (If you don't have one, you can anneal the used one by heating it to cherry red (evenly) and quenching it in water). So, oil change interval? I'm thinking 6,000 miles or so. I was unable to figure out how to reset the oil change service reminder separate from the inspection reminder. If anyone can please clarify that I would appreciate it! Cheers, jv |
#83
For those of y'all who are curious: Bosch supplies the oil filter for BMW. Picked one up today at Advance Auto Parts. Same kit, same appearance, made in Germany. A few bucks cheaper than the dealership, plus convenience for those who aren't close to a dealership.
#84
Nice!
Thanks! Bosch 72202 is $12.99 at Advance Auto Parts. I have Amazon Prime, which is 2 day free shipping, and there it's $11.35, minus a $2.00 rebate making it $9.35. It's a mail in rebate good through 10/29/2011 for up to four filters.
#85
and be careful of the drain, the oil comes out like a gusher sideways! I had it up on a lift and totally missed the oil catch tank and made a mess!
#86
Hmmm, my 3.0si has the oil coming straight down. It is a fast flow!
Madurodave My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi Retired: 1998 BMW Z3 Member of BMWCCA! |
#87
http://www.ecstuning.com/BMW-E83-X3-...ngine/ES10355/ |
#88
whereas the 2004 -6 has it more traditionally located on the curved part of the base. So that makes the difference in how it comes out - all over your hand, or right up your arm. Flow rate should be similar. There needs to be good protection from shearing off the drain plug by objects in the road/trail, and that's easier to provide for when the drain plug is on the back edge of the pan as opposed to more directly underneath. The 2007+ likely has a more rigid aluminum shield there and/or a smaller cutout for access. |
#89
Thanks, Vipz
2010 X3SI; Alpine White; Saddle Brown; Light Burl Walnnut; Premium; Navigation; HD Radio; Heated Front Seats; Servotronic; 1995 325i Convertable; Red, tan interior. |
#91
Haven't changed my oil yet but are the ramps necessary? Can I get under there without them?
#92
However, my dealer is 30 miles away...so 60 miles / 20mpg = 3 gallons of gas, or another $12! I would need to buy ramps at $40 and a new oil drain pan as my current only holds 5 qts. Didnt pull the trigger, so went to dealer. ok, enough babbling.
Jim 2011 335i Convertible M-Sport - Silver - Saddle 2007 550i Sport - White - Tan |
#93
Although it can probably be done without, the ramps make the job much easier. A valuable asset for anyone that would even consider working on their own vehicles.
Jarrod Weaver Georgetown, Texas 1987 - 535is 2004 - 525 2006 - X3 3.0i |
#94
i asked my service department about 0w-40 last time i took my car in for a different issue and they said nope just good old synthetic 5w-30
"Mobil 1 0W-40 is recommended for all types of modern vehicles, especially high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks. Mobil 1 0W-40 is especially suitable for extreme conditions, where conventional oil often may not perform." Word for word from the mobile1 site, 1 use 0w-40 in my 2.0T and mobile1 5w-30 in the x3. Just want to point this out there for any1 considering changing their own oil and choosing between the different grades.
2007 E83 3.0si
#95
Tell us more about this mobile1 oil you are using? I've never heard of that one. |
#97
Just to fan the oil debate fire, as long as you are changing oil in between CBS changes, Mobil 1 5W-30 synthetic will be just fine. Many owners use the same oil.
If you are strictly going to follow 15k mile oil changes, I guess it is safer to stick with LL01 oils - then you can put blame elsewhere when you get sludge problems due to extended oil change intervals. Just my 0.02!
#98
Mobil 1 5W-30 does not meet the BMW HTHS spec, which has nothing to do with how long your OCI is.
Do you have any evidence that following BMW's OCI recommendations with a LL-01 oil leads to sludge? I have 3 BMW's, all follow the BMW OCI, none have even the slightest trace of sludge or deposits. The same tired pictures of a valve train covered in elephant snot do not count as evidence. That is caused by antifreeze leaking into the oil. |
#99
Thanks for a very specific instructional post. The photos and description were of high quality.
Tim |
#100
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil change interval | kashrahman | E60 (2004 - 2010) | 11 | 03-22-2012 03:03 PM |
| Is my 4.8is a lemon??! | ZenX5 | X5 E53 (1999 - 2006) | 68 | 09-15-2007 08:08 AM |
| Post break in oil change | vadimv | E46 (1999 - 2006) | 10 | 01-30-2005 10:42 PM |
