E46 (1999 - 2006)
Old 08-08-2005, 04:16 PM
beemermtec beemermtec is offline
Mein Auto: 330ci
shaky wheel
hi guys i think my discs need changing cos im getting a bad vibration thro my steering wheel when i brake,even low speeds gives me a shudder! anyone else had the same? also can anyone tell me if its easy to do disc change on my own!!!! any help would keep a happy man very old ! ta mateys.
Old 08-08-2005, 05:20 PM
bimmere46 bimmere46 is offline
Mein Auto: 2001 325i
Could be a warped rotor...If it gets worse when braking, that would be my guess. Replacement is fairly simple and could be done by someone with basic skills.
1. remove wheel
2. remove brake caliper
3. remove rotor (there is a small allen screw holding rotor to hub)
Old 08-09-2005, 01:33 PM
marco328 marco328 is offline
Mein Auto: 99' 328i (E46)
You might also have you control arm bushings. I also had a shutter during braking even after I had changed all four rotors and pads. Someone mentioned the lower control arm bushings so I went out bought the pair and had my mechanic replace them and prestoe problem solved. Before you go through the expense have the rotors checked at local machine shop to see if they're warped. If they aren't then it's the control arm bushings. Rotor removal is fairly easy.
Hope this helps!
Old 08-11-2005, 04:04 PM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
Hope this helps!
DEFINITELY CONTROL ARM bushings. MAke sure you check andchange them first before touching the brakes.
Also, you dont have to change the whole control arm, unless there is significant play of other ball bushings that are located on the control arm.
Similar Threads
M Wheel And Bluetooth Question Bayern-tr 3 Series & 4 Series 6 11-07-2004 12:35 PM
M sport/M3 wheel and SMG LMC 3 Series & 4 Series 16 09-19-2003 08:41 PM
Wheel vibration and pull when braking NickD 3 Series & 4 Series 8 09-05-2003 07:34 AM
FS: Carbon Fiber Wheel Cap Decal Kit vinnymac Classifieds 0 05-29-2002 10:36 AM
