E34 (1989 - 1995)
Old 08-08-2005, 07:15 PM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
How Do You Reprogram The Odometer?
Parts of my instrument cluster display burned out so I picked up a new instrument cluster off Ebay. However, when I plugged it in my odometer is now reading 220,000 miles on it. Everything else works perfect, but I don't want to add 60,000 more miles to my vehicle just because I changed out the cluster. Does anyone know how I can re-program the odometer or order a cheap part and then reprogram my display?
Old 08-08-2005, 08:46 PM
obmd1's Avatar
obmd1 obmd1 is online now
only one screen name
Send a message via AIM to obmd1
Mein Auto: Toyota 4runner
tricky question. I think there are laws against this kind of thing.
Old 08-10-2005, 09:15 AM
shortbus shortbus is offline
Mein Auto: E34
on the other hand - if it is done with honest intentions... such as this case. How would he do it?
Old 08-10-2005, 09:18 AM
Desertnate's Avatar
Desertnate Desertnate is offline
Spelling Impaired
Mein Auto: '10 Mazda3 HB
I always thought the mileage information was stored in two places in the car and the display simply displayed the information from one of those modules. Simply swapping out the display shouldn't case a problem because it is simply an interface.
"In the long history of the world, only a few generations have been granted the role of defending freedom in its hour of maximum danger. I do not shrink from the responsibility...I welcome it!" - JFK
Old 08-10-2005, 09:20 AM
Mein Auto: E34
I don't know I never tried. But, he did say he plugged it in.
Old 08-10-2005, 09:22 AM
BMW_Brand BMW_Brand is offline
Mein Auto: 2004 BMW 325i ZSP
Was typing out the same response...
I would assume the cluster only displays information stored in chips located elsewhere in the vehicle.
So it all seems fishy.
You sure it's in miles?
- JT
Old 08-10-2005, 09:27 AM
Here's some info, check it out => http://www.bmwe34.net/e34main/mainte...capacitors.htm
- JT
Old 08-10-2005, 11:14 AM
ArtemLepilov ArtemLepilov is offline
Mein Auto: 1991 BMW 525IA
Check it out guys - i tihnk that i read in a german manual for an E34 board repair from 1988 somewhere that there is a special plug and it stores all the info in the chip that plugs into it - its some weird three letter name for the plug... So i tihnk what you need to do is swap those plugs and you are all set... ;-)
Let me know how it goes.
-Artem
Old 08-13-2005, 11:40 PM
I found the solution for pre-1996 digital odometers:
There is an ERPOM in the instrument cluster circuit board that stores the Odometer miles. This EPROM can be reprogrammed easily if you have the right tool or find a shop who will do it for you, but most want to charge about $200 for this service. In my case, I disassembled the circuit board from my old instrument cluster (it's the blue portion of the cluster, held on by two plastic 1/4 turn, plastic thumb screws) and swapped it with the new (Ebay-used) cluster. Now my odometer reads it's origional miles. This also confirms that the LCD driver board does not store the odometer information, and that there is no other chip in the DME or in the LKR (as there is in 1996+ models) which control the odometer.
Note: Since my old LCD has some burned-out pixels, I also swapped out the LCD glass by bending the metal tabs on the bessel. From this point, the LCD has a connector on the front (behind the glass) which makes replacing the LCD very easy. This may also a fix for any LCD problems due to pixels which may not be working correctly -- assuming the circuit board LCD drivers (row and column) are working properly.
Old 09-10-2005, 10:04 PM
Mein Auto: E34
great find and thanks for reporting back!
Similar Threads
Is anyone out there registered for vin# checks? BMWKLR E90/E91/E92/E93 (2006 - 2013) 7 11-26-2006 07:29 PM
FS: 99 BMW M Coupe 55k mi $23995 chip4 Cars - Private Party 13 11-12-2005 02:38 PM
Odometer says 1739 miles, I-drive trip computer says 1725 miles.. what should I do? spaceman E90/E91/E92/E93 (2006 - 2013) 8 08-26-2005 07:18 PM
what do you guys think? Seungboy E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 6 07-26-2005 07:47 AM
Odometer: design oversight? SONET General BMW 23 05-09-2003 02:28 PM
