E34 (1989 - 1995)
Old 08-09-2005, 10:34 AM
sprite sprite is offline
Mein Auto: 525iTouring
Transmission Slipping
This is my first beamer. Looking to get a good deal on a later model- just waiting for my price and something to jump out at me.. Any hoo, the car is slow going into gear and like any other car your first instinct is to add fluid -BUT- I cant find where or how to administer transmission fluid- It is a 1994 with more miles than I can count. I want to save it for my son for next year so I'm trying to save money before I have to go to the dreaded overpriced dealership. I am a Do- it - Yourselfer but I have not received any help from mechanics because they want the money.. Can any one shed some light on this please
Old 08-12-2005, 09:15 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Moved your thread over here for hopefully better visibility and help.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 08-13-2005, 11:27 PM
imnprsd imnprsd is offline
Mein Auto: 1992 525i Wagon
Do a search on transmission slip... and see how to check the level of your fluid properly. As you know, there is no dip stick on you car.
Old 08-16-2005, 01:59 AM
Are you sure it's slipping. If so, I think the tranny should store a code for each gear this happens.
If you don't have a code, maybe you just need to change the fluid, filter and as my expereience has shown.. MAYBE YOU SHOULD CLEAN YOUR GEAR SELECTOR SWITCH BELOW THE SHIFTER LEVER!
Good luck.
Old 08-19-2005, 03:21 PM
jnmip jnmip is offline
Mein Auto: 93 525i
Checking AT fluid level
I did a search on "transmission slip" and didn't find anything on how to check level or add fluid. Please help
Old 09-05-2005, 06:02 AM
Prior to checking the fluid level, run through all the gears and pause for 5 seconds at a time, remove the side bolt in the back pan, and if a little fluid run out you are okay. Add fluid if nothing come out... drive it around the block... and recheck. If fluid runs out it was too full. Note: If it's too full the tranny may behaive funny and the gas mileage will be less. Too little fluid and the clutches will burn.
Similar Threads
1999 528i Auto transmission trouble Josephbmw E39 (1997 - 2003) 12 09-15-2009 01:37 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Swapping transmission bimmerlvr General BMW 12 06-03-2005 11:09 AM
Transmission slipping (clunks) in reverse aktam E46 (1999 - 2006) 2 03-08-2005 02:23 PM
323/325 328/330 etc. engine changes Optimus Prime General BMW 15 04-03-2004 06:56 PM
