E36 (1991 - 1999)
Old 08-11-2005, 09:07 PM
RubyRed RubyRed is offline
Mein Auto: 1997 328i Convertible
Foglight Bulb Replacement Procedure
Hello all. I'm a long time lurker whose wife has a '97 328i Convertible. It's not her car that prompted the post, however. My daughter's boyfriend has a '97 328i Sedan and he called in desperation when he got the dealer's estimate for just replacing the foglight bulbs. He wants to do it himself to save some $$ but he lives 250 miles away, so I can't help him do it. Does anyone know a simplified procedure for the task that I can e-mail him, or a link to a site that has good step-by-step instructions?
Thanks in advance for any help you can give.
Vince
Old 08-11-2005, 09:28 PM
allen85t allen85t is offline
Mein Auto: 93 suckbaron
Thumbs up
Just did this *today* myself, dead easy DIY job, you can have it done in 15 minutes no joke, all you'll need is a flathead screwdriver of reasonable length.
To the "inside" side of the foglight (towards the car centerline) there will be a lttle square gap in the grille/bumper, where you can see a hex-bolt (or a phillips screw head) for adjusting the foglight aiming. Pop your screwdriver in there, blade vertical, and just move it around gently an inch or two in until it hits something solid but with a little give, and push gently.
If you're in the right spot, you'll be pushing on the clasp that holds that side of the entire foglight in, and it will pop out. Slide it out and towards the centerline of the car and it the whole thing will just come out.
Unplug the foglight wiring, just a simple clip there.
Twist the shroud on the back about 1cm and it'll come off, the bulb is inside held down by small metal tension wires. Just unplug the hot wire from the old bulb, release the tension wires, and it'll come right out.
Replace, the bulb and wires, slide the foglight's "outside" pins into the grooves, then push on it, holding onto the bottom of the air dam with your other hand, until it "clicks" back in. All done.
If you need, I can take some pictures.
----DO NOT JUST "PRY" THE FOGLIGHT OUT AS SOMEONE HERE ONCE RECOMMENDED----
This will break the very small and fragile plastic clip that holds the "inside" side of the foglight in, and the foglight will not stay in if that clip is broken. I got the whole kit from BAV and lucky thing, since I broke one of them in this fashion myself today and had to replace the whole foglight assembly which is obviously meant to be done with the air dam / bumper off the car -- hard to get those screws out with it on.
Anyway, if that's not enough, I could take a few pictures for ya. Good luck!
Old 08-12-2005, 02:51 PM
Thumbs up
Thanks for the quick reply. I will pass on your most excellent instructions.
Vince
Similar Threads
2001 325i Headlight Bulb Replacement skyhook E46 (1999 - 2006) 7 11-10-2011 11:01 AM
Consumer Alert-bmwxenon.com bmw528im5 General BMW Questions 6 02-21-2005 12:00 PM
replacing e60 foglight bulb surewin 5 Series 3 11-29-2004 02:46 AM
F/S: New 6500k 9006 HID replacement bulb James92se Classifieds 0 11-19-2004 12:49 AM
Foglight Bulb Replacement absolut ci Do-It-Yourself H.Q. 2 11-26-2002 09:33 PM
