E46 (1999 - 2006)
Old 08-16-2005, 04:49 PM
durbanite1 durbanite1 is offline
Mein Auto: E46 328i
Transmission Problem Gear 5 Ratio Incorrect Code 0735 ?
Hoping someone may be able to Help! '99 E46 328i
Had a "warning" Gear with an exclamation! in the center of the gear come up next to the Digital (P,R,N,D) indicator on the dash.The tranny felt like it might be bogging down?
I had to give alot of Gas Pedal to move forward.(I believe it may have been stuck in 5th gear)
I turned to car off, waited a min, and then started the car, and the warning indicator was gone?
Drove the car and all seemed fine! I immediately took the car and had the transmission fluid flushed.( for all those wondering about the "lifetime fluid", it was really a nasty color black @ 125K miles) Car drove fine.
Anyway, a few days later the warning light appeared again and the tranny did the same thing, except this time the engine "check" light came on. I pulled a single code P0735 which appears to be a "Gear 5 ratio incorrect" ?
Does anybody know what this is?, and if so, any suggestions?
Any help appreciated! durbanite@aol.com
Old 07-12-2006, 02:09 PM
silverbimmer3's Avatar
silverbimmer3 silverbimmer3 is offline
Mein Auto: '05 M3 ZCP; '06 530 XIT
OMG, why no body replied?????
i have the same situation!!
An experienced engineer in a shop told me to replace the tranny, and also told me the transmission oil change wil not solve the problem.
I don't want to spend $3500 on my old 99 323i with 116K miles....so I am looking forward there is some way to fix the transmission problem.......
thanks in advance -- please help!!!
Old 07-12-2006, 08:59 PM
ATLBMW ATLBMW is offline
Mein Auto: 2000 -E46 - 323i
trannys are such crap... I am at 77K and i have my warranty ready for when mine dies...
i had a 98 mistubishi eclipse the tranny died at 60K... trannies ar crap.
Old 07-14-2006, 04:10 PM
bimmere46 bimmere46 is offline
Mein Auto: 2001 325i
I'm really not much for auto transmissions. Can't seem to locate any info that would clarify that error. Lifetime fluid
Old 11-02-2008, 07:07 PM
ryansmagnum ryansmagnum is offline
Mein Auto: 2000 323
i have a 2000 323 have a code coming up p0735 if any one knows what it means or how to fix can you e mail me at ryansmagnum@gmail.com
Old 11-02-2008, 07:41 PM
Black2000328i Black2000328i is offline
Mein Auto: 2000 328i
Durbanite1. If your transmission fluid was black, then it
was burnt. Something had to happen to it for it to be black.
If you only had a pan drop filter & fluid change, then half
of the black burnt fluid is still in there. You may have to
change it again to see if it helps or get another opinion.
Old 11-03-2008, 03:57 AM
Nov99328i's Avatar
Nov99328i Nov99328i is offline
(o0\(III)(III)/0o)
Mein Auto: 99 E46 328i
You can order various transmission parts from OEM.com or other sites. I would change the speed sensors in the tranny if I were you. There are 2, a front and a rear, same part numbers. You will also need a filter and new fluid as well if you take the transmission pan off. I would try this first, only about $400 rather than complete tranny change.
ADR gunmetal 18's, Clears up front & sides, DVD system mounted in headrests + 1 up front, Dinan CAI + software
Mirror tint all around, M-TECH II front bumper, Front and rear Foglights
For my yoke is easy, and my burden is light. Matthew 11:30
Old 11-04-2008, 02:33 PM
Mein Auto: 2000 323
so when i drop the oil pan how hard is it to change the sensors and how do i fill the trany back up it has no dip stick
Old 11-04-2008, 02:36 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Check out the auto tranny fluid change DIY in the Wiki:
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
Old 11-04-2008, 03:55 PM
Nov99328i's Avatar
(o0\(III)(III)/0o)
If you follow the wiki to the "T", while you have it laid open, change the sensors.
Old 11-04-2008, 03:59 PM
Mein Auto: 2000 323
i dont want to sound like a ass but what is the wiki
Old 11-04-2008, 04:02 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Read my signature.
OR the sticky post at the top of the forum that says, "Read this before posting questions"
OR
just click on the link in the email above where I mentioned the wiki.
Old 11-04-2008, 04:41 PM
Mein Auto: 2000 323
i feel like an ass. i looked at it and it shows how to change the oil i need to know if i will see the speed sensors when i drop the pan.
Old 11-04-2008, 06:09 PM
Nov99328i's Avatar
(o0\(III)(III)/0o)
Yes, there is a speed sensor in the front and one in the rear (depending on tranny type). Figure out which tranny you have and then go to www.realoem.com and have a look at where they are. My tranny is here http://www.realoem.com/bmw/showparts...97&hg=24&fg=15 They are held on by one Torx bit screw. They plug right in to the wiring harness.
Old 11-08-2008, 11:01 AM
Mein Auto: 2000 323
thanks for the help im going to try it
Old 08-01-2009, 12:47 PM
ivandmorales ivandmorales is offline
Mein Auto: 323i
Hey guys, I got the same problem... so here's my question: Did you ever fix the problem and if you did, what did you do?
please help !
Old 08-02-2009, 01:19 PM
spazmataz's Avatar
spazmataz spazmataz is offline
Mein Auto: 2002 318i m-sport 5 spd!
Had that same error a few weeks ago... This was after a tranny fluid change... Just did it over and the code or error hasnt come back since!
Old 08-02-2009, 04:03 PM
Mein Auto: 323i
It seems to be that the error code is link to more than one possible issue as I have read that, yes in deed it can pop for a transmission oil level issue but also for throttle position sensor etc : (
Old 06-08-2010, 08:34 PM
iMay iMay is offline
Mein Auto: 323i
having the same problems/code.....any solutions??
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
