E34 (1989 - 1995)
Old 08-16-2005, 07:02 PM
Butch525 Butch525 is offline
Mein Auto: 525i
tail light burned out, literally
I recently purchased a 95 525i with 112K on the odometer. I received a tail light warning this evening on the dash and checked it out at home. The socket where the bulb locks in was slightly melted - I couldn't tell whether it was fresh or not. Anybody had this happen?
thanks
butch
Old 08-27-2005, 09:37 PM
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Send a message via AIM to bimmerd00d Send a message via MSN to bimmerd00d Send a message via Yahoo to bimmerd00d
Mein Auto: 1998 540i 6-speed
You used the 1157 bulb it sounds like. You must use the European lamps in the E34 taillight assemblies, they're VERY sensitive to heat, and the 1157 bulbs are too hot for them. If you want the correct ones, head to the dealer and get a correct set, they aren't too expensive there. These are the part numbers for Sylvania bulbs available at Autozone.
1993 BMW 500 Series
Low beam headlamp
9006
9006ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005ST Silverstar High Performance Lighting: the whitest and brightest Halogen
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
7528
Front turn signal
7528
Rear turn signal
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
5008
Stop light
7506
High mount stop light
7506
Fog/Driving light
H1-55W
H1ST Silverstar High Performance Lighting: the whitest and brightest Halogen
License plate
6418
Back up light
7506
Front sidemarker
2825
Dome light
6451
Trunk/Cargo area
6411
Under hood light
6411
Instrument-general
2721
Old 01-04-2013, 05:56 AM
Kolegra Kolegra is offline
Mein Auto: E34
1990 535i Auto
I`ve just had my light burn out too, replaced it with the correct bulb, but it still doesn`t work.
It also has some melted like plastic around the holder.
Also I unhooked my other taillight to see if it was melted too but now that one doesn`t work either.
My reverse and flashers/turning signals work fine.
I unplugged the connector so I'm wondering if that may be the problem,
Do I need to reset the computer with a handheld diagnostic tool or something?
Thank you!
Old 01-04-2013, 08:49 PM
virgontour virgontour is offline
Mein Auto: 535i
prob the bulb may be wrong wattage, then also look around were wires go into plug incase there now wearing thin from the melting
Old 01-05-2013, 06:14 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
The other place to look for a problem is where the wiring runs through the trunklid arm. Often the opening and closing of the trunk over the years can cause wires to break where they have been bending.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 01-05-2013, 09:14 AM
Mein Auto: E34
Thank you for all the advice!
I managed to find the problem.
Apparently the slight melting of the taillight rigging put the connectors out of place.
Don't turn the bulb holder ALL the way, just almost all the way.
Make sure they connect.
I`m just glad that I didn`t have to pay for a new taillight.
Thanks once again and please close this issue.
Similar Threads
? about replacing burned out head light bulb NJ325ci E46 (1999 - 2006) 12 09-07-2005 04:01 PM
tail light problems on E36 slamtry E36 (1991 - 1999) 2 08-04-2005 04:40 PM
Anyone thinking about putting pre-2002 tail lights on '02 sedans? epc 3 Series & 4 Series 0 01-28-2002 01:32 AM
