Rear End Rumble? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 08-18-2002, 09:54 AM
BL_xiT BL_xiT is offline
Mein Auto: 2002 325xiT
Rear End Rumble?
Question to iT or xiT owners - Does your wagon also have a rumble/harmonic/noise from the rear end when decelerating between 2000 and 2600 rpm?
Having driven front wheel drives for the past dozen years I wonder if this is just normal rear end rumbling that is more noticable because there is no trunk to hide the rear end noise in my wagon.
This is especially noticable going downhill, slowing down while the engine decelerates from 2700rpm to 2000rpm. Above or below that rev range no noise.
Having put 14,000+ miles since purchasing in May I thought I would get used to it.
Most of the time the stereo masks it (the noise).
Other than that this vehicle is just a complete joy.
P.S. Count me among those that would have spent whatever extra BMW would have charged for the 3 liter engine.
2002 325xiT White / Nat Brn Lth SP PP Step HK Xe
Old 08-18-2002, 11:12 AM
RichNY RichNY is offline
Turbo Addict
Mein Auto: '14 X3 28i
Tires, maybe?
I have a RWD 328i sedan, but all of the noises I have similar to that can be attributed to the tires. If it's getting worse over time, that's even more an indication as I've found tires tend to rumble more as they get older.
Is the sound consistent even over different road surfaces?
Good luck!
Old 08-18-2002, 02:14 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
I'd have to agree with Rich on that one.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 08-19-2002, 10:09 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Did you recently rotate your tires? If so then definately it's the tires. Especially when they're not even in wear you'll get pretty nasty rumble when decelerating.
It could also be the differential whine.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
