E34 (1989 - 1995)
Old 08-20-2005, 11:59 PM
kaweahnet's Avatar
kaweahnet kaweahnet is offline
M Obsessed
Send a message via AIM to kaweahnet
Mein Auto: 2006 ///M Roadster
Can't open door.
E34 w/M20 motor (1990) BMW 525i in question here.
I can't open the drivers side rear door. The lock button won't pull up (I tried really hard), nor will it activate with the regular locking mechanism (key in the drivers door). The car is new to us, so any help would be nice before I forcibly remove the doorpanel from the inside while the door is closed (it won't be pretty).
Additionally, Is there a lock/unlock button in the car somewhere?
Old 12-31-2006, 11:44 AM
bibolt bibolt is offline
Mein Auto: BMW European 320I, 1988
Hi, kaweahnet and others
did you find the solution for this one, bcz I have the same problem with my e34 520i, 1989 and I am not able to open the same door.
pls if you have found the answer, let me know.
Old 01-05-2013, 10:39 AM
Kolegra Kolegra is offline
Mein Auto: E34
same problem
1990 535i
any solutions or ideas?
Thank you!
Old 01-05-2013, 06:07 PM
Mein Auto: 1989 525i M20B25
If you cant pull the lock up, then it is double locked and the panel must be removed.
Remove the back seat bottom as shown in this video to help facilitate removal:
Old 01-06-2013, 10:21 PM
BMWFatherFigure's Avatar
Old School
This sounds like a mechanical lock problem. At the risk of sounding like a #$%^&er try taking the driver's seat out before you remove the door trim. Pain the butt job I know but less chance of damage to the door card in the long run. I bet some one had a go at stealing the car and has damaged some part. With the seat out you might be able to pull the door seal off and inside the car - more space for the card removal.
Current:
E38 Parts Car
Previous:
Old 01-07-2013, 03:49 AM
Banned
Mein Auto: car
The trunk's lock is part of the central locking mechanism of the car. I've experienced situations where the driver's key does not unlock certain doors but the trunk lock does.
Another weird door situation is that my remote lock only works for all doors at one go when I manually lock the trunk by turning it clockwise to the right. Then, unlocking the driver's door manually or by remote activated all the doors at one go.
These permutations are not intuitive and were discovered pretty much purely by accident, so perhaps you have not tried them on your side as well.
Similar Threads
Valet key - limited number of usages?? Door lock weirdness?? Adventure Rider E46 (1999 - 2006) 5 06-05-2005 07:42 PM
Driver Side Door Won't Open talongm3 Do-It-Yourself H.Q. 0 08-11-2004 07:56 PM
Passenger door lock msilva 3 Series & 4 Series 8 01-30-2003 08:44 PM
ne1 have water at door sill after rain/car wash? pt00323i 3 Series & 4 Series 2 12-24-2002 11:46 AM
pics of bimmer that was broken in to.Thought you could not open door when locked? 325CI~02 3 Series & 4 Series 10 02-22-2002 08:33 AM
