Old 08-21-2005, 02:20 PM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
Removing console, need tips...
I can't remember how the gauges come out. Can someone (Daniel?) give me a hand? Also, the lighter plug...
Old 08-21-2005, 03:12 PM
ARC///M's Avatar
ARC///M ARC///M is offline
Mein Auto: BMW 01 M Rdstr 00 M Coupe
how deep are you going!
The main gage console removes with two torx I think and then three connectors behing that need to be lifted. do not scratch it and we have done it with the steering wheel in.If you want the independent gages from behind.
Old 08-21-2005, 04:04 PM
DannO's Avatar
Sorry, I didn't describe my problem well. I'm talking about the clock / temp gauges in the center console. About 10 mins after posting I figured it out, of course. After struggling with it for quite a while.
For the archives... the gauges are held in place with a threaded sleeve. To remove them press on the glass of the gauge to hold it in place and reach around the console with the other hand. The sleeve is knurled kind of like the lid of a glass jar to make it easy to grab and twist. Just unscrew it all the way and the gauge will slide easily out the front of the console. Then you can disconnect the wire and set the gauge aside. In order to keep the connections straight I reconnected the gauge behind the console. Once the console was removed I disconnected the gauge subharness and set it aside with all gauges attached.
The lighter / power plug just uses blade connectors. Just pull them off.
Old 08-21-2005, 04:36 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
You probably have this all figured out by now, and recall some of it from stripping the Pollenator. You figured out the push-on-the-gauge-glass trick. I'll recant some other tips anyway...
When replacing the console, don't forget about the guide pins at the top, make sure they're going nicely into their holes as you put it back in. And that they're out of their holes before you start moving the back of the console upward. Wouldn't want to break those.
Be very careful removing/replacing the hazard switch. The surround is very thin and cracks easily. $.05 of plastic, but BMW wants $10 for one. I added a disconnect to my hazard switch so I won't ever have to remove it again (it now stays in my center console).
The lighter plug and bulb... do those second-to-last on the way back in, with the buttons still out (but connected). You can then reach in there with a couple of fingers of your right hand to put the bulb back in. There's no other good way to do it that I've found, that wire is short and the bulb falls out of the socket easily.
Chime should go in last, lying in the footwell and reaching in from behind to put it in place. Take note of its orientation and the little locating pin before you put the console back in.
Wise to label the heat seater harnesses since they're the same connectors left and right. A small Sharpie is good enough, writing 'L' and 'R' on the connector shells.
Daniel
2002 M roadster
Old 06-02-2014, 09:44 PM
ClayMan ClayMan is offline
Mein Auto: 325is
Is there an easier way to remove just the gauges? (e.g., without removing the radio or the entire center console?)
Old 06-02-2014, 11:31 PM
dwm's Avatar
dwm dwm is offline
Nope.
Daniel
2002 M roadster
Similar Threads
Removing exhaust tips mjb E46 (1999 - 2006) 4 05-13-2005 06:36 PM
Help - Having difficulties removing center console... TurnAround E36/7 Z3 (1996-2002) 6 02-20-2005 03:00 PM
Removing cover under console armrest... X5Jay X5 E53 (1999 - 2006) 4 01-29-2005 07:57 AM
Question about removing ashtray from center console Kiwi E36/7 Z3 (1996-2002) 4 08-12-2004 01:32 AM
Removing swirl marks and some tips.. AlpWhite04 The Detail Department 41 03-15-2003 11:40 AM
