Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 08-23-2005, 01:24 PM
archer33 archer33 is offline
Mein Auto: '75 3.0si
Angry help! overheat on a '75 3.0si
i just bought a '75 3.0si and on the way home (30 min) it overheated! went into red, pulled over and all coolant leaked out bottom. had to get 4 gallons of water in it before it stabilized enough under the red to get it home- another 10 min. had to repark it last night and it went into the red after 5 min. when i opened the radiator cap, the water spewed 3 feet in the air, covering the top and back of the car. what could it be? if it's the head gasket, the brooklyn mechanics are saying it would be up to $3,000! i only paid $1,200 for it!!
does anyone know a good brooklyn mechanic?
Old 08-23-2005, 01:53 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
1. If your coolant leaked out the bottom, I would start there. Also eliminating the possibility of leaks elsewhere. Including water pump or any other place you have a cooling line.
2. Remove and inspect thermostat. This is the most usual culprit to overheating.
3. Once you do 1 and 2 let us know how things are.
Maybe someone fom Brooklyn can direct you to a mechanic. It would be of great benefit if you bought the manual for your car. A Google search will lead you right to it.
Good luck! And remember any car at that price is bound to have some trouble.
Do you have any pics?
Old 08-25-2005, 10:30 AM
///M Blitz ///M Blitz is offline
Mein Auto: M6, M3, DINAN 750iL, Z8
Without seeing, I have no clue as to what it could be, BUT I bet it's not the head gasket if its leaking like that. I would expect water pump, hose, or something like that.
///M Blitz (AKA Dan)
- 88 M6 (33K mi - original owner)
"The best M6 in the World" - BMW Car mag. (Nov. 05)
**First place "Stock Class" Bimmerfest 2006
**First place "Stock Class" Bimmerfest 2011
- 89 DINAN 750iL (69K mi - original owner)
**Second place "Stock Class" Bimmerfest 2008
- 98 M3 (65K mi - original owner)
- 03 Z8 (8K mi - original owner)
- 12 X5 Diesel (dd)
Old 09-04-2005, 08:47 PM
uzj100 uzj100 is offline
Mein Auto: Landcruiser, M3
Not a bad idea to have a leak down test done on it anyway. Also, you may wish to take the valve cover off and re-torque your head bolts. You can get a "cooler" thermostat too
HTH
Old 09-05-2005, 05:24 PM
racermat's Avatar
racermat racermat is offline
Mein Auto: '76 3.0 Si
Lightbulb Overheated
Hey, Try this link to BMW master mechanics list (IAIBMWSP).
http://www.iaibmwsp.org/
The guy who built my '76 3.0Si is on that list, Marc Norris. He may lead you in the right direction. He had a long battle with my car to get the temp down.
Good luck!
Racermat
AKA MatMan
Please sponsor my ordinary average lifestyle.
-STILL FOR SALE-
'76 3.0 Si AC/PW 4Spd
6 cyl. rocketsled
http://www.m2differentials.com
"Putting our parts in your rear end since 2009!"
MatM@M2Differentials.com
Similar Threads
Slight Overheat wisdom1 E36 (1991 - 1999) 4 03-16-2007 03:58 PM
Diagnosing an engine overheat problem on an M Coupe. rennich E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 9 06-04-2005 05:12 PM
overheat pong 5 Series 1 02-24-2005 06:50 AM
Jerry Goldsmith passes away at 75 jgrgnt Off-Topic 2 07-22-2004 08:33 PM
Nice '75 CSL vid nate Motorsports, Racing & Track 6 12-18-2002 07:01 AM
