Old 08-24-2005, 07:22 PM
Carolyn6060 Carolyn6060 is offline
Mein Auto: 1997 BMW 528i
Suspected Electronic Immobilizer Failure
When I got in the car in the garage it won't crank. The radio, horn, keylocks, lights, and everything else works but it won't turn over.
I've heard about failure with this 1997 528i in the electronic immobilizer. However, after all day in a European Automotive Shop they are no further than when I had it towed. Our local dealership does not have good BMW folks there now and I don't want to take it to them.
Any advice? Could it be the EWS control box?
Carolyn
Old 05-30-2006, 08:47 PM
knucklehead knucklehead is offline
Mein Auto: 1995 325ic
I know the answer !!! pick me !!! close the doors. Put your Master Key in the door. turn it to the 1st position right, then 2nd position right, then 3rd position left. this will reset the starter immobilization sequence which is part of the anti theft system monitored by the EWS system. then put the key in the ignition and fire it up!
Old 05-31-2006, 05:45 PM
lac540i lac540i is offline
Mein Auto: 540i
hey there do you if the reset procedure is the same for the 540i 1998. My engine cranks but will not start
Old 06-23-2007, 11:27 PM
zingalie zingalie is offline
Send a message via Yahoo to zingalie
Mein Auto: 2001 530I
probably is EWS!
Old 06-24-2007, 07:52 PM
R540 R540 is offline
Mein Auto: 1997 540i/6
my car did this and it ended up being the ignition. this was after a new key, ignition cylinder, and immobilizer. good luck
1997 540i/6-19" Beyern Mesh, Angel Eyes, M5 spoilers front/rear, Intrax springs, 15% tint.
Similar Threads
e36 328i '1 Brake Light Failure' - intermittent SmootheEar E36 (1991 - 1999) 27 12-30-2011 02:08 PM
'1 Brake Light Failure' Weird Situation hunt1200 E36 (1991 - 1999) 20 05-20-2011 04:54 PM
Brake light failure warning Jon Shafer E36 (1991 - 1999) 17 08-19-2009 05:16 PM
Electronic gas pedal "clicks" before bottoming out Dave 330i General BMW Questions 14 12-06-2004 06:03 AM
Electronic Failure Statistic 2001 in Germany Alex Baumann General BMW Questions 13 01-10-2003 01:43 PM
