E46 M3 (2001-2006)
Old 08-27-2005, 12:06 AM
FlyingDutchMan FlyingDutchMan is offline
Mein Auto: 02' M3
Chassis Modfest Part 1 (SBAG Pics)
I finished up the last pieces of my chassi modfications. Having already installed a complete GC supension, brakes etc I had a few odds and ends to finish up.
Part 1
TurnerMotor Sport Rear Subframe mounting points weld reinforcment kit
Turner Motorsprot Rear Subframe Grand Am Cup Bushing Kit
Ground Control Rear Trailing arm spherical bushings
Ground Control Upper Inner control arm shperical bushings
There we four reasons for doing these mods. 1) Reinforced the rear subframe mounting point, there has been a BMW SA on this. Common prolbem in the E36 and E30 M3's also. 2) Reduces/eliminate any rear roll steer- or "skate board" steering under conrnering accel/decel loads. 3) Eliminate any toe chance from trailing arm bushing deflection under corner load. 4) Eliminate any chamber changes as a result of stock rubber upper inner control arm bushing deflection.
WIth all the specialty tools and air power and welders this project took two of us 8 hours start to finish.
The bottom line is that these mods make th car more predictable in its' handling and make it possible to put a more accurate alingment on the rear supension
Picture one is the removal of the rear end. Peter Van Wingerden at Santa Barbara Auto Group did all the work. (Home of Bimmerfest.)
Name:	Rear Sub Assembly Removed 2.jpg
Old 08-27-2005, 12:07 AM
Mein Auto: 02' M3
Picture of the stock Subframe Bushing Puller...BMW Specialty tool
Name:	Stock Bushing Puller.jpg
Old 08-27-2005, 12:09 AM
Mein Auto: 02' M3
Stock Rear Subframe bushings...
Name:	Close Up of Stock Subframe Bushings.jpg
Mein Auto: 02' M3
New Turner Motorsport Grand Am Cup semi solid delirn bushing kit installed...
Name:	Close Up of TMS GAC Subframe Bushings.jpg
Old 08-27-2005, 12:11 AM
Mein Auto: 02' M3
preping the subframe mounting points for the reinforcement plates...
Old 08-27-2005, 12:12 AM
Mein Auto: 02' M3
Rear Turner Motorsport mounting point plated in place ready to be welded in...weld thru primer
Name:	Rear Rear Subframe mounting points in place.jpg
Mein Auto: 02' M3
Close up of the front mountinog point plate welded in..
Name:	Close Up front front rear subframe mounting point.jpg
Old 08-27-2005, 12:13 AM
Mein Auto: 02' M3
Big Picture view of all four mounting point plates welded in...
Name:	Weld in Kit 2.jpg
Old 08-27-2005, 12:15 AM
Mein Auto: 02' M3
No into the trunk where we had to weld the sheet metal on the backside of the rear subframe mounting points... First we had to cut through a layer of sheet metal that forms the trunks shape, to get to the metal that actuall supports the subframe mounting point.
Name:	Inside the trunk.jpg
Old 08-27-2005, 12:16 AM
Mein Auto: 02' M3
Close up of area to be welded, marked by red dots. This brings two layers of stock sheet metal together with the Turner Motorsport rear reinforcing plates welded on the undercarriage earlier...
Name:	Detail Trunk Weld.jpg
Old 08-27-2005, 12:18 AM
Mein Auto: 02' M3
On to the Ground Control parts... rear traling arm bushings installed, we used the same installation tool picture on the rear subframe bushing to remove the stock bushings and press and bolt these ones in...
Name:	GC Trailing Arm Bushing.jpg
Old 08-27-2005, 12:19 AM
Mein Auto: 02' M3
Detail Picture of the Ground Control upper inner control arm bushing...
Name:	GC Upper Inner Control Arm Bushing.jpg
Old 08-27-2005, 12:20 AM
Mein Auto: 02' M3
Upper arm ready for reintall...
Name:	Upper Inner Rear GC Control Arm upgrade.jpg
Old 08-27-2005, 12:24 AM
Mein Auto: 02' M3
Once the rear end is reintalled here is what it looks like...you can see the Turner Motorsport weld in plate clearly here and the Grand Am Cup bushing. Note Swaybar is disconnected. This is the drivers side rear - rear subframe mounting point. Much sturdier than stock, its not going to tear out of here.
Name:	Close up of TMS GAC Bushing and Plates.jpg
Old 08-27-2005, 12:28 AM
Mein Auto: 02' M3
I'll follow up with Part 2, finishing up the front chassis.
Turner Motorsport Front Subframe Reinforcment Kit
Turner Motorsport Solid Engine and Tranny mounts.
Par3 3 Driveline mods
UUC Evo 3 shortshiftre upgrade with DSSR
UUC Clutch and Flywheel
BHS Underdrive Pulleys
These parts are completed by I can't post pictures until the magazine article have hit and are off of the newsstands.
Old 09-22-2005, 10:01 PM
Riuster's Avatar
Riuster Riuster is offline
Riuster = Rooster
Mein Auto: 02 M3, 07 X3 and 04 TSX
fantastic write up...now all i need are the tools.
02 CB/Blk Lthr, Cold/Prem. Pkgs, HK, Xenon, Rev. Alert, SMGII, ACS comps, Hamann Comps, OEM Bar, Intros Aero Pol 19s 2-3 In.lips, w/275 Potenzas, Koni S, RMS, AA GEN3, SS Midpipes, DDE lights, LED Retrofit, Lthr Steering, OEM Sheepskins, Kewood Amateur 7000, XM 2, V1, GT2, Garmin 7200, Carputer-SONY T140 with Xenarc display, CSL splitters, ACS diffuser
BMW 2007 AW X3, prem and cold pkg.
Acura 2004 CG TSX
Old 09-22-2005, 10:12 PM
Jon Shafer's Avatar
Bimmerfest Founder
Mein Auto: E92 M3 Cp
Excellent Sander!
Old 09-22-2005, 10:34 PM
Andre Yew Andre Yew is offline
Mein Auto: 2000 E46 328Ci Bright Red
For all the bad stories we hear about other dealers, SBAG (formerly Cutter Motors) is amazingly tolerant and sympathetic to modified and tracked cars. This thread pretty much proves it, but my experience with them, along with other people in SB I know who have modified and tracked BMWs, has been pretty positive, too.
--Andre
Old 09-23-2005, 05:45 PM
Mein Auto: 02' M3
--Andre
True...at least they'll work with you if you ask nicely...
It would be kind of hard to be intollerant of modders, aka BMW enthusiasts, and then credibly host events like Bimmerfest. Jon Shafer deserves a lot of credit for helping to set the tone there years ago.
Old 01-29-2006, 10:26 PM
black318i black318i is offline
Mein Auto: 318i
Did you remove the gas tank befor welding in the front plates? Also did you use a MIG welder?
Old 01-29-2006, 10:36 PM
Mein Auto: 02' M3
No, we didn't. We actually filled the tank with fuel, because liquid fuel is less flammable that gas vapor.
You don't really get that close to it, we did keep lots of air and wet rags around the area being welded to keep things cool.
Old 01-31-2006, 09:30 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Very cool write up!
Old 02-01-2006, 03:52 AM
PhilH PhilH is offline
Mein Auto: 2010 S4, 2004 X3 2.5i
I agree, great pictures too.
--My Garage--
Prior BMWs: 2003 330i, 1993 525i
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
Working Vacation Part 2(Warning: Many pics) Guest84 Off-Topic 10 04-22-2003 06:53 AM
need help finding a certain part. evilfactoryowne General BMW Questions 0 10-10-2002 06:41 PM
Need part number for redesigned pedal to fix sticky pedal... bmw325 3 Series & 4 Series 13 09-04-2002 08:55 PM
part two of pics ;) ashecnc Automotive / Photography 10 07-19-2002 07:09 PM
