E30 (1982 - 1993)
Old 09-08-2005, 08:35 AM
Bailey325i Bailey325i is offline
Mein Auto: 325ic
Replacing Dashboard
I need to replace my cracked dashboard from my 1990 325i. My plan is to obtain a clean dash from a junked car and go through the process replacing. Has anyone done this? I was wondering how difficult this process is, what kinds of tools I need and how much time a non mechanic like me will need to finish. Any comments would be appreciated.
Old 09-08-2005, 09:54 AM
fporro fporro is offline
Send a message via MSN to fporro Send a message via Yahoo to fporro
Mein Auto: 87 325iC
6 to 8 main screws,
removal time 1 to 2 hours.
instalation ? a lot,lot, lot, longer
cheers,
Frank
e30 parts
Old 09-12-2005, 07:23 PM
Bimrpwr's Avatar
Bimrpwr Bimrpwr is offline
Mein Auto: 85 VW Quantum
try this link...Looks very helpful and has pictures step by step..
http://home.comcast.net/%7Ecdeegan9/...shboard_1.html
Old 09-13-2005, 06:56 PM
daskew daskew is offline
Mein Auto: 325ic
Boy that tutorial (with pictures) on removing the dash is really a nice bit of information to have. Question: Do you have a similar tutorial on how to replace the carpet? It looks to me like the dash has to come out to do the carpet, plus a bunch more stuff. At least it looks to me like a bunch more stuff has to come out if you don't want to cut the carpet out. The part of the carpet that is at the front of the trans tunnel is "trapped" by a bunch of stuff (heater box?) on top of it. I have a new carpet coming (from the dealer) and I would like to install it without cutting it if not too big a project. However, everyone that I have talked to on this subject says "cut it". -Dave 1987 325ic "one owner -me"
Old 09-13-2005, 08:17 PM
ctim ctim is offline
Mein Auto: 1991 318i
wow, that looks like quite a project. nice in depth tutorial however.
Old 09-14-2005, 07:55 AM
Bimrpwr's Avatar
I dont know the steps for the carpet and i check this website which is very helpful. If it was me i would not cut the old one out, i would do it right and remove it and put the new in , but that is just me.
http://www.bimmerdiy.com/
Old 09-18-2005, 08:28 PM
REDLINEREP REDLINEREP is offline
Mein Auto: 1986 bmw 325e
carpet
oi replaced the carpet in my 86 325e and all i had to remove was the center console.
taking the original out isnt a great idea unless u got alot of time and money cause the padding under the carpet is a good 4 inchest thick and has alot dif shape, i looked for replacement padding but couldent find any. if u get relly lucky u might find some good padding in a junk yard but when i went every 325 had the sunroof removed and wet interior from rain.
Old 09-18-2005, 10:22 PM
PuebloPete PuebloPete is offline
Mein Auto: 1988 BMW 325iC
powellsd... very nice tip on that website... thanks.
Old 09-23-2005, 08:23 PM
HoffmeisterKink HoffmeisterKink is offline
Send a message via AIM to HoffmeisterKink Send a message via MSN to HoffmeisterKink
Mein Auto: '06 330i / '87 325es
I did the dash replacement awhile back (http://www.nvo.com/themaus/dashreplacement/). Took some photos of the horror. I spent the good part of a labor day weekend working on it. Taking everything apart was easy, putting everything back together just right is a major PIA that takes time and patience and some muscle. Here's some tips:
1. Do it when the temperature is above 65-degrees F. This will let you bend and flex the pieces into place without worrying about new cracks.
2. Tape and label all the wires. If you have a digital camera, take pictures of everything as you disassemble. That way you can have a reference in case you forget about where something goes while you're putting everything back in.
3. While you have everything out, replace all the little indicator bulbs in your gauge cluster and OBC. Replacements can be bought at Bavarian Autosport.
Good Luck!
Old 09-24-2005, 09:40 PM
e6figueroa e6figueroa is offline
Mein Auto: 1987 bmw 328i conv
oh boy
i put a brand new dash on my baby in 102 degree weather and i took 6 hours, nearly got heat stroke. i wish i had a tutorial, just trial and error. thank go thats over. good luck man.
Old 10-05-2009, 07:27 AM
Thamp7 Thamp7 is offline
Mein Auto: 90 325i
Dashboard
Where can I find a replacement dashboard...new preferably?
Old 10-05-2009, 12:26 PM
claver claver is offline
Mein Auto: 1997 328i
replacement, u might wanna check ur local junk yard, u may get lucky and find a good one with no cracks very cheap.
New on the other hand u can only get it at the dearlership, and runs at $1000+ as they make it with a new kind of material,
Old 10-05-2009, 01:11 PM
sde30 sde30 is offline
Top Down Squad
Mein Auto: 1987 E30 Convertable
thanks for the link, i gotta do mine soon
Old 10-06-2009, 09:10 AM
romeomike's Avatar
romeomike romeomike is offline
Running life's race...
Mein Auto: 91 318i
For what it's worth, the pictures don't display in "native" Firefox. However, they do show in Internet Explorer, or using a Firefox extension called IE Tab.
Good Luck!
I had a question about a recommended temperature setting for this job, and you answered it. Thanks.
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
Similar Threads
Replacing BMW Parts mannyqa Do-It-Yourself H.Q. 1 06-24-2005 11:53 AM
Dashboard icons.. Which ones are they? ranz_killa E46 (1999 - 2006) 5 02-23-2005 10:48 AM
Replacing Smog Pump/Secondary Air Pump - DIY? BrettInLJ 5 Series 3 02-08-2005 03:57 PM
replacing front turn signal light bulb with higher waltage - problem? BavarianDoc 3 Series & 4 Series 4 09-23-2004 07:20 AM
Small thingy on dashboard i 2004 5-series gunchr 5 Series 3 08-12-2004 02:01 PM
