Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Performance
Performance
CAIs, SCs, differentials, SSKs, exhausts etc.....
Old 09-10-2005, 09:02 PM
2K323CI 2K323CI is offline
Mein Auto: 323CI
Smile FS: For Sale Ess 6.5psi Super Charger For 323i/Ci $3000
The complete system is in excellent condition and under warranty, has 20k miles on it. Very reliable and stable, with everything in perfect working order. I'm selling the car so I don't need the super charger anymore. Attached are picture of the kit in my car and picture of the kit after I removed it. Price $3000 plus shipping $50 anywhere in the states. You will need to send your DME to ESS for reprogramming which will cost you $500 at the most and takes about a week. Some have gotten their DME reprogrammed for as low $300 so negotiate. This system may fit 328i/ci, but please contact ESS to confirm this and programming availability before you buy @ sales@esstuning.com
Specs:
Part number: 108-21x
Vortech V2SQ Supercharger unit.
One belt driven w/self tension system.
CNC Machined, hard anodized brackets.
Long life serpentine drive belt.
6 Larger Bosch injectors.
Recalibrated MAF (airflow sensor).
True OBDII, optimized performance ECU software with removed top speed governor and 6700RPM limit.
All powder-coated mandrel bent tubing w/ K&N cold air intake located inside front bumper.
Oil pressure and return system.
Oil breather assembly.
True OBDII, Stage 2 performance ECU software with removed top speed governor and 6900RPM limit.
Bosch bypass-valve system.
New, mandrel bent discharge and intake tubes with Bosch bypass fittings.
CNC machined, hard anodized 6.5 PSI supercharger pulley.
15 page, 34 step detailed and illustrated (51 photos) installation manual.
100% maintenance free operation.
Boost pressure: 6.5 PSI
Horsepower: 265 DIN (Stock 170)
Torque: 334 NM (Stock 245)
0 - 60: Man : 5,9 sec, Aut : 6,6 sec
Installation time : 8-10 hours
Questions:
twok323ci@sbcglobal.net or PM me. Thanks for looking!
ID:	56885   Click image for larger version
Similar Threads
Ess 6.5psi Super Charger For 323i/Ci FOR SALE 2K323CI Classifieds 0 07-18-2003 01:06 AM
