E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Anybody every try to replace the plastic rear window on a convertible top. The guy selling windows online says it's doable in up to two hours with some help and been done in as little as 15 mins. Basically a zip out the old one zip in the new one. Can it be that easy...
In a nutshell: Yes. It's pretty easy. It took my wife and I about an hour. Getting the zipper lined up was the hard part. Make sure you sew the zipper shut at both ends to make sure you don't have to mess with it anymore.
Glue around window
I thought the installation calls for glueing the canvas to the rubber seal around the plastic window?
I am looking at purchasing a 95 318iC but the back window is split. Does anyone know if that model has the zipper type window or do I need to replace the entire top, which is around $1300, which I dont want to do right now but if its that easy to replace my decision has been made. Any input appreciated.
M =) |
i have a 96 328ic my window is sewn in was wondering how come.thought it was sapossed to be a zipper..do i have a new top..
Zipper coming undone during install
I bought the E36 replacement kit from the guy at Emiata.com. I'm finding that when I get the zipper started correctly (both edges lined up, coming together OK), when I get to a certain point there's too much strain on the window and zipped part begins to come apart.
Seems like either the replacement window is too small or I'm just doing something wrong. Help?!!
Hi
When I bought my convertible the back window was really bad. I, personally, would not have attemtped to do it myself as getting the teeth lined up is a nightmare. BMW stealers in the UK charge astronomical amounts for new windows so I sourced a local firm and they did it for only 130 GBP fitted. I would definitely get a professional to do it unless you have a very clever wife like the one that 'rasher' owns!!!!!!! [I can say that because I am a fellow wife!] |
Convert top
After buying the window from emiata, i tried and tried to get it in but couldn't get it zipped it. I thought it better I bring it somewhere before I destroy the top and window. I called around and found an auto upholstery that could put it in for 70 bucks. They got it in fine. They wouldn't warranty the window because it wasn't theirs but the guys said they could have made a window using the old one for a template and use the zipper on the old one also. They would then also warranty the window since they made it. All for about $225-$250.
Nes |
Found the solution after my post yesterday: if the window keep coming unzipped, it's because it is WAY off proper alignment. I compared my old window to the new aftermarket one just to make sure they were the same size. They were, but putting them side by side I found the problem. The starter zipper on the new window is about 3/4" to the right of the factory zipper, which means if you align the two together (factory says within one tooth of even) the entire window would be 3/4" to the right!
Once I figured all that out, the window went in fairly easily. Moral of the story for anyone who's going to DIY this job: if the window is aligned correctly, the zipper should run the entire length (corners included) pretty easily. If you run into strain, especially to the point where the track pulls apart, something's really wrong - start over. And don't forget Hofstadter's Law on this one! Cheers,
To the vert owner that has a sewn in plastic window. You most likely do not have a new top but the uphlostry shop that did the work simply cut the old one out and sewed the new one in. This does three things: it means you can never go back to the zipper plastic window again unless you replace the top, you get a little bit more visibility because they had to cut your opening larger and last you will have to go to an uphlostry shop to get a new window put in eventually.
Actually that is not a real problem if you take care of your top. To get long life out of the top use most any wax that doesn't have abrasives in it and clean the outside of the window after flusing the window with fresh water. Also when you close the top put something like an old sheet or thin cloth where the plastic window folds into the boot to keep it from rubbing. My window looks really good after doing this once or twice a year. Hope this helps.... |
Id be careful of buying from emiata. They have about 5 scam websites and sems only about 50% of people are recieving them
In our professional opinion, NEVER BUY AN AFTERMARKET WINDOW for a BMW. Only the OEM BMW parts line up right. It's a lot more expensive, but well worth the lack of problems.
We've been in the convertible top installation business for a while (25 years exp)...trust us on this one. |
Rear Window replaced
I would like to figure out how to post this in the DIY area with photos. That would be better than this abstract verbal description(dribble) –but here goes
. For now here is a quick bit of input. This will NOT get you the "concourse d'excellence" award for perfect car. It did save the day on installing the window. First rule (RTFM) READ THE INSTRUCTIONS until you understand every step, every part and tool like the "Folding Leg" and the 'blue tape' I would also take Blueskys reccommendation strongly and suggest staying with OME on this one. We got the old window out (no problems here) but the Piping all fell off or we just pulled off that which hadn't. We then cleaned things up well (used spirits of Vodka) to get all old tacky adheasive/sealer off. – Installing the new window –trying to keep the cardboard and protective plastic in place –was a big mistake and caused untold aggravation. We finally just were careful not to scratch the window with any tool or fingernails and ditched the protective crap. Aligning the zipper ends was much simpler without the proactive stuff. UNFORTUNATELY by the time we got to that stage-- after several failed attempts to get the "zip fastener slide" (the thing that actually joins the zipper halves together) attached to the cover side of the zipper the leading pilot edges was in threads and impossible to get into the slide. In ultimate frustration and after two hours, I started the process on the outside of the car leaning over the trunk . The slide went on –it zipped all the way around perfectly BUT it would not and can not complete the full circle because of the designed in overlap. Starting from the inside allows the final zip to overlap the first part. The way I did it the slide butted the closed zipper and began to force it open and prevented me from over laping (in this case underlaping) What I did at this point was attach the locking clip as per instructions and used a needle and thread to pull the un- attached zipper together. Nothing has been destroyed except the start section of the cover side of the zipper-I may re-address this and use some superglue on that little end of the cover zipper to see if I can get it stiff enough to go into the slide and try this whole thing again-- another day! ![]() Jim Last edited by jpmcguire; 10-03-2010 at 07:07 PM. |
See note below
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Autoup drivers window lowering rear windows? | anderp | X3 E83 (2004 - 2010) | 27 | 04-21-2005 12:18 PM |
| Rear window broken - won't go up | NJT | X5 E53 (1999 - 2006) | 3 | 02-22-2005 06:10 AM |
| e36 power rear vent window wiring | jswanson3 | 3 Series / 4 Series | 5 | 10-29-2004 01:37 AM |
| rear window switch | RChoudry | 3 Series / 4 Series | 4 | 07-19-2002 04:38 PM |
| Odd Rear Window Problem | GSR13 | 3 Series / 4 Series | 6 | 07-18-2002 08:25 AM |
